HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Projects
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 09-15-2007, 02:29 PM   #1 (permalink)
Gold Member
dbdartman's Avatar
Default Quick, CHEAP, bucket "forks"
Yesterday, I needed to move some large pallets that fence sections were on. First I tried clamping some 2X8 scraps on the bucket, but that didn't work at all. Then... inspiration!!! Cut down a couple pieces of of 2X6, add a couple screws each, & voila, cheap & dirty "forks" that slip into the bucket & are capable of moving the pallets! See attached.
__________________
dbdartman is offline   Reply With Quote
Old 09-15-2007, 02:43 PM   #2 (permalink)
Elite Member
kennyd's Avatar
Default Re: Quick, CHEAP, bucket "forks"
"Necessity is the mother of invention"
__________________
JD 4110HST
FEL, 60" MMM, 60" Rear Blade, Ballast Box, I-Match, #380 Snow Plow, FEL Forks, Goossen 3PH Chipper/Shredder, Markham LD-48 Grapple and much more "stuff"
kennyd is offline   Reply With Quote
Old 09-15-2007, 05:38 PM   #3 (permalink)
Super Member
Egon's Avatar
Neat!
I use a couple of old truck leaf springs bolted to the inside bottom of the bucket for forks.
__________________
Egon
50 years behind the times
Livin in a
Worn out skin bag filled with rattlin bones
Egon is offline   Reply With Quote
Old 09-15-2007, 07:18 PM   #4 (permalink)
I like it! Good thinking. I may use the principal and make a set out of metal. Thanks for the idea.
__________________
Live Right
Till the soil
'till I am soil
higgy is offline   Reply With Quote
Old 09-16-2007, 03:29 PM   #5 (permalink)
Gold Member
dbdartman's Avatar
A few more pics of the cheap bucket forks at work. After this load was dumped, out came the screw gun, out came the screws, & into the dumpster went the forks. My brother insists I now qualify for at least honorary "red-neck status" (with all due respect to those from Georgia to Arkansas).
Oh, the "project" was clearing the construction debris that's been piled behind the garage since construction started on the house. Now that all the wood is gone, I just have to dig out all the concrete dumpings & left-over wall block (some will be used as rip-rap in a drainage ditch, the rest buried) & cut up & trash any remaining plastic & garbage (the 2 guys that built the pole barn last winter left an amazing amount of trash behind ).
__________________
Old 09-16-2007, 03:37 PM   #6 (permalink)
Gold Member
dbdartman's Avatar
Quote:
Just be aware that any weight on those forks is exerting an upward force on the top of your bucket, & a downward force on the bucket edge. You may want to consider reinforcing the top front edge of the bucket with a piece of angle iron on the inside, & limit your lifting to no more than a couple hundred pounds max.
__________________
Old 09-16-2007, 05:00 PM   #7 (permalink)
BTDT's Avatar
I chuckled when I read this and looked at your bucket. Looks like it's overdue for some reinforcement. Good job, I wouldn't have thought it would carry that big of a load without failing (your wood forks).
__________________
Praise is not something you do to get closer to God, praise is a response to God being close to you.
BTDT is offline   Reply With Quote
Old 09-16-2007, 05:20 PM   #8 (permalink)
Gold Member
dbdartman's Avatar
Quote:
LOL! Believe me, that bucket looks worse than the pics show! Should have seen it before I spent about an hour with a couple 3lb & 8lb hammers! This old 4400 was "rode hard & put up wet" regularly long before I got my hands on it. It's perfect for my regular mowing requirements & the occasional hole (the back hoe is more fun than should be allowed).
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
