bigballer
- Joined
- Jun 2, 2006
- Messages
- 666
- Tractor
- 2006 Kubota L3400
i need to spend alot of time clearing deadfall in my woods but given all the other projects i had to get done this summer didn't really get to it. i figured if i could access the woods in the winter i could spend alot of time out there the only problem is the only way for me access is via the pasture which is the spillway for my seasonal ditch. i decided to cut a swale with my boxblade to keep the water in a semi tight path but in the winter it's still too soft out there to run my tractor. so to get around that i decided if i added a culvert to my open ditch i could get into the woods via the upper part of the property and actually be somewhat productive over the next 5 months.. this would also give my better half yearround access to the roundpen for her horse training - added bonus. So this was todays project.
i picked up a 13' stick of 12" double-wall ads pipe - $5.75/ft.
kinda a steep slope (about and 15" drop over the 13', the ditch was open for the most part but i did have to clear some blackberry vines.. gotta love the NW..
after a dry run i discovered the i would need to do some grading around on the woods side of the road, pretty steep looking:
minimum coverage for this pipe is 12" and to start with i am looking at 15" but will probably end up with 18"-20" since i'll build up the road a bit..
