HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Projects
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 08-18-2008, 03:50 PM   #91 (permalink)
WilliamBos's Avatar
Default Re: Want to see yet another pole building?
Beautiful Barn!! Keep the pics coming.
Will
__________________
Thanks,
Will
MF 1523, 1505 MMM, Wallenstein WX310 Log splitter, Kubota Turfbuster, Buhler-Farm King 50" Snow blower.
WilliamBos is offline   Reply With Quote
Old 08-25-2008, 01:30 AM   #92 (permalink)
Megado's Avatar
Quote:
Originally Posted by SteelDust View Post
Megado, here is the detail pic that you asked for, I'm still unsure exactly how I'm going to trim aall this out. I will have a trim board (to hide all mistakes) at the siding/OSB union. Beyond that, we'll have to see. I'm really considering closing in the soffit completely....
SteelDust - thanks for the detailed pic. That's how I suspected you had done that intersection but just wanted to confirm. It's interesting that you're butting up your siding planks. I'm planning on doing my cedar siding as a board & batten install. That's how the two houses on my property are done so I wanted to have the barn match. It will be interesting to compare our two different styles once completed. I'm thinking of leaving my soffits open but will address when I get to that point.
Quote:
Oh...I also broke a 34 year streak today, I got stung by a wasp for the first time in my life. Wife and friends had given me the nickname the "wasp whisperer", I guess I lost that title today. The good news it that it barely swelled up, so at least now I know I'm not allergic to them
Be thankful you're not allergic to them. Unfortunately I am and seem to swell up like a balloon whenever I get "hit" by one of those boogers. Not sure which is worse...getting nailed by a wasp or those dang pesky scorpion's we have here in Texas!
Jim H.
Megado is offline   Reply With Quote
Old 08-25-2008, 06:40 PM   #93 (permalink)
SteelDust's Avatar
Jim H.
I went back and forth on what to do with the soffits as well. At least 90% of the time the top half of the dutch doors on the 3 stalls will be open. This should allow for plenty of airflow. If something changes or that is not enough. I'll come back with a 3" hole saw and cut soffit vents. I think this would look better and be easier to screen off.
As far as the siding being waterproof.... Keep in mind the planks are tongue and groove. It's not just cedar board butted up against one another. The T&G fits tight enough together that I've had to hammer each piece in place. Also, the siding is as dry as it ever will be. As the humidity increses any swelling will just serve to make a tighter joint. If I run into one that is not a tight fit, it goes into my "rip down for trim" pile. After I got the first wall up, I blasted it with a garden hose from a few different angles. The only leaks I found were from a couple of knot holes. That problem can be solved with a bit of caulk. I also laid the siding so the the prevailing wind will drive the rain away from the joint, instead of into it.
__________________
Massey 1533, 1525FEL, 2005 Rotary, Pallet Forks. 8.5 acres of timber and pasture
SteelDust is offline   Reply With Quote
Old 08-25-2008, 09:35 PM   #94 (permalink)
Super Member
Robert_in_NY's Avatar
Eddie and myself also are referring to the butt joints where there is no tounge or groove. Water running down the wall will hit these joints and while it may not leak now the water will soak into the boards there are start rotting them. You are going to have to put a good sealer on these walls and keep up the maintenance in order to slow this process.
__________________
God must love stupid people; He made so many
Robert_in_NY is offline   Reply With Quote
Old 08-27-2008, 02:02 AM   #95 (permalink)
SteelDust's Avatar
Quote:
Ahhh yes, I can see the concern there. I mitered each of the butt joints at a 45. I'm cutting all the siding on a compound miter saw anyhow, so flipping the saw over to the 45 stop isn't all that much added work.
I've always found you get a much cleaner, tighter joint when doing this, especially with T&G. I arrange the joint so that the top board overlaps the lower board by about a 32nd of an inch (barely visible). When you tap in the next row of siding this forces the two slightly offset tongues into alignment, thereby pulling the joint even tighter. Aligning the joint this way also creates an uphill path for water to flow if it's to soak into the joint.
Yes, the barn will be stained with a high quality, semi transparent, water repellent stain. It will be reapplied as necessary. More work, yes, but in my mind worth it for the aesthetic value over metal siding.
__________________
Old 09-02-2008, 12:27 AM   #96 (permalink)
SteelDust's Avatar
Just a quick update, nearing the end of the exterior siding. I apologize for the picture quality, I'm not sure what is going on with the camera. I decided to make it easier on myself and beak up the siding on the large, completely sided rear wall. I'll run a belly band across the entire length to cover up the seam and give it a better look. It will be nice to have it closed in, the only problem being is that it's getting dark in there pretty early in the day now. Looks like I might move up the electrical. Once the siding is done, I think it'll be onto stalls and the exterior paddocks. I can put trim up during the rainy season if it comes to that. I need to get the paddocks graded out and finished before it turns into a mud hole.
View from inside the loft.
__________________
Old 09-02-2008, 01:33 PM   #97 (permalink)
MAN!!!!!! Is that a nice barn!!! Good job my friend!!
yzbdsbp is offline   Reply With Quote
Old 09-02-2008, 11:17 PM   #98 (permalink)
Steeldust,
Great job!
Are the openings in the loft for feeding hay down into the stalls?
Are you going to put up rails?
Again, great job man.
ldabe is offline   Reply With Quote
Old 09-03-2008, 12:21 AM   #99 (permalink)
Gold Member
keving's Avatar
Beautiful. I really like the design and all that wood.
__________________
keving
M7040 Cab
keving is offline   Reply With Quote
Old 09-03-2008, 02:25 AM   #100 (permalink)
SteelDust's Avatar
Quote:
Originally Posted by ldabe View Post
Steeldust,
Great job!
Yes, I'll be able to feed hay down from the loft. I will put rails up when I'm closer to having things finished off. Right now, they'd just be in the way.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
