HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Projects
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
LinkBack Thread Tools Display Modes
Old 11-18-2007, 11:01 AM   #11 (permalink)
Default Re: Want to see yet another pole building?
Great work Steeldust! At least it's warmer than usual this time of year. There's nothing like working out doors in the PNW in the winter. It sucks.
I hear you on the good rain gear. It's a must have up here.
When your done your pole barn would you come down and do mine for me? I just keep procrastinating on it.
__________________
There is no hope for America in the 2008 election!
PBinWA is offline   Reply With Quote
Old 11-18-2007, 01:08 PM   #12 (permalink)
Super Member
3RRL's Avatar
Very cool project.
Looks like you're very resourceful and used to doing things by yourself....get er done. I admire that.
Your pole barn is looking great. Keep the pictures and fine explanations coming.
__________________
Rob-
...The Older I get...the Better I Used to be...
3RRL is offline   Reply With Quote
Old 11-18-2007, 05:08 PM   #13 (permalink)
Chuck K.'s Avatar
Very nice.. With the way concrete prices are going I may go the pole barn route... Keep sending pics.
__________________
Kubota L5240-HST
LA854 FEL
Wood's BH90-X w/hyd. thumb
6' King Kutter, shredder
6' Taylor Way box blade
4' QA pallet forks
Leinbach PHD 12' auger
Grapple shoppng
Chuck K. is offline   Reply With Quote
Old 11-18-2007, 06:20 PM   #14 (permalink)
beersngars's Avatar
Very nice work. Keep the pics coming. Also, I assume the posts are set in concrete?
beersngars is offline   Reply With Quote
Old 11-19-2007, 12:22 AM   #15 (permalink)
SteelDust's Avatar
Quote:
Thanks for all the comments.
Most of the loft decking went down today. I'll have to make a mental note never to lay T&G OSB subfloor in the rain again. The OSB swells just enough to make fitting the tounge tightly into the groove quite difficult. I somehow managed to tear the insulation on my circular saw cord today, luckily the circuit is GFCI, and it was tested today. I was using the back up cordless circular saw to cut hardibacker recently, so that blade is trashed and really slowed things down.
The posts are in 56" deep holes with 8" of concrete poured into the bottom. I then backfilled the holes with bottom ash from the plant I work at (has the consistency of sand) Most up here either backfill with sand or 5/8" minus rock with lots of fines. Either way, add water and agitate as you are filling and they're rock solid when finished.
__________________
Massey 1533, 1525FEL, 2005 Rotary, Pallet Forks. 8.5 acres of timber and pasture
SteelDust is offline   Reply With Quote
Old 11-19-2007, 12:28 AM   #16 (permalink)
SteelDust's Avatar
Quote:
Originally Posted by EddieWalker
Looks awessome!!!
I reallly like the second story and how strong you are building it. Looks like it will last forever!!!!
Thanks for the updates and I'm looking forward to more of them.
Eddie
The original plans that I based this building off of spec'ed 11 7/8" LSL beams for the loft rim joist. That was to achieve a 80 psf load rating. Looking at the data I figure using Structural grade 2x12 in doug fir easily gives me a 60 psf load rating for the loft floor. Which should be more than enough for what I'll need to store. In fact, with they type of hay I store, I don't think I'll have the height in the loft to load it to 60psf.
__________________
Old 11-19-2007, 01:27 PM   #17 (permalink)
Tororider's Avatar
Looks like a great barn. I think I will forward it on to my brother in law as they are hoping to find some property to build on, and they might be able to use the loft as living quarters for a short time until they can get their house build.
That barn looks like a tank, built really strong, nice work.
__________________
Tororider
John Deere 4310
Frontier Finish Mower, Back Blade, Wallenstein Bx62 Chipper, King Kutter 6.5' Disc Harrow, IM 5' Brushhog, Land Pride 7' box blade, front end pallet forks
"You call for faith, I show you doubt to prove faith exists. The greater the doubt, the stronger the faith, I say, if faith overcomes doubt."
He who dies with the most toys... still dies; but he may have more fun than the guy with less toys, hehe.
Tororider is offline   Reply With Quote
Old 11-23-2007, 12:50 AM   #18 (permalink)
SteelDust's Avatar
Quick update. Decking on the loft floor is done (edges of OSB are nailed down, still have to go back and nail on the center studs and pound the 500 or so odd nails needed to fill up the joist hangers, 16 nails per hanger ).
I finished it up this morning as soon as the OSB thawed out, and before I had to put the turkey in the deep fryer. I'll most likely cut the center rafters, attach the gussets, and set them on Saturday. Hoping to start putting up the purlin blocks and maybe setting purlins by Sunday. It'll be nice to have the roof done and have a dry place to finish her off.
Hope everyone had a good Thanksgiving.
__________________
Old 11-23-2007, 08:57 PM   #19 (permalink)
Timber's Avatar
Send a message via Yahoo to Timber
I love this project, Nice work there
__________________
Kubota B7800, Sundown Loader Forks, Landpride PHD, Sundown 66" Box Blade, 800 pound Ballast Drum with chain storage,ATI Grapple, 60" Landpride Brush mower
Timber is offline   Reply With Quote
Old 11-23-2007, 09:55 PM   #20 (permalink)
Gold Member
Quote:
Perhaps I should not be asking this. Did you attach anything to the posts to limit uplift or is that not something particular to your area?
Typically, with PT posts, many (not all) the builders in my area nail or screw on some pieces of PT about 8" long to the posts. Once the posts are well tamped in or in your case, backfilled with the ash, the blocks resist frost heave which is a possiblity where I live.
Nice project.
QRTRHRS is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
