A small pole building for the PT
   / A small pole building for the PT #1
BillCroasmun
Gold Member
Edinburg, Ohio
PT-180
Well after several years of reading on here about others building homes for there tractors it is now my turn. :) I need to replace one of those Harbor Freight portable garages that pretty much desinegrated after it's third season. Held up great at first but once the material started to "thin" it went quick!
I started looking into large sheds that were large enough to hold the PT and a few attachments (plus a few other outdoor items that were in the portable garage) and went into sticker shock. I only have roughly $2000 to put into this and have two criteria: It has to be largest enough for the tractor and "cute" enough for the wife. After looking at various wood, vinyl and metal options that didn't seem to meet those two criteria (within budget) I stopped by a local Carter Lumber to see if they could quote me a pole building idea I came up with. The attached drawing is what I took them and it came in right around $2000 (and I never told them anything about my budget at all). Bingo!
The second mocked up photo is what I think it will look like. Roof footprint 24x24. The shed will be the 16x16 back corner. This will give it a 6' front overhang and an 8 foot "pavillion" like area to the side. We've always wanted a pavillion and this will give us the affect by just adding two more posts and 4 more trusses. (Plus down the road I can probably build a gazebo somewhere else on the property and box in this 8x16 section... shhh don't tell the wife).
Floor will be slag like the drive. No plumbing, electricity or anything too fancy.
I'm in the process of trying to find someone nearby with an auger, once I do that I should be able to start fairly soon.:D
   / A small pole building for the PT #2
The price sounds pretty cheap for so much material? is this a kit? looks like a good deal for what you need. The only problem might be the height, shows it at 12' at the peek of the roof, will that give you enough door clearance?
Good luck, JB.
JB,
No not a kit. I just took the drawing up there and the guy I talked to has a lot of experience building pole barns so he priced it out on the fly by building it verbally ("First thing I'd do is set the 13 posts {ring up 13 posts}, then I.d attach the...{ring up next item}, etc."
I'll post the material list later to see if anyone see's anything missing. I think the only things not included was hardware (nails and hinges for doors), cement for post holes and paint. It included flashing, roofing materials and trim boards.
As for the height, the side walls are 8' and the roof is eng trusses every 2'. That means I won't have any usable space above the 8' really. For me this will be OK. I don't have any large agricultural tractor and ROPS. I have a Power-Trac PT-180 and even with my custom cab it will clear a 7'6" door with space to spare. I have thought about making the side walls 8' 10" by just moving the T1-11 up 10" and running a pressure treated 10" board around the bottom perimeter. That would allow me to handle 8' lumber or sheets of plywood inside with a little room to spare if standing on in.
Bill
   / A small pole building for the PT #4
Hey! That looks great. Can't wait to see the material list.
Keep us posted.
   / A small pole building for the PT #5
When I built my 24' by 24' building m wife kept telling me that I'd want one bigger I said "no way". Well it was full in short order, you may want to think bigger.
Thanks ldabe.
ToadHill, At this particular location even if I could afford to go larger there's no room. It will be sandwiched in between my well, drive, trees, etc. I have other areas on the property where bigger would fit but this one I want adjacent to the drive for convenience (especially in the winter!)
Here's the material list, although I just remembered this is only for the 24'X16' area. The extra 8' of "pavillion" I added after this list was worked up.
11 - 4x6 14'
6 - 2X10 16'
2 - 2x10 8'
9 - 24' COMM 4/12 2'OC 1'OHBE
12 - 2x4 16'
18
- 5/8x4x8 YP TEX 1-11
14 - 1/2x4x8 OSB
2 - 2x6 16'
9 - F4 1/2 WHT ALUM DRIP EDGE
3 - 6"x12' ALM FASCIA WH
1 - 15 FELT
15 - 25YR O/C SUPREME ONYX BLACK BDL
8 - 7/8x4 8' R/S CEDAR #3 & BTR
14 - SIM H2.5A RAFTER TIE
1 - 11-1/4"x20' VENTSUR RIGD ROLL VT
3 - 7/8x4-16' R/S CEDAR #3 & BTR
3 - 2X4 16'
4 - 2X4 12'
   / A small pole building for the PT #7
This may be to easy:cool:
Just get a used shipping container :D
It will be lot's less than 2K delivered
MrJimi, If that would of met the wife's cuteness requirement I'd seriously consider one... I guess you could hang a few flower boxes on the side. :D
Maybe that's why wife doesn't let me help decorate the house. :rolleyes:
   / A small pole building for the PT #9
Bill, there is a guy in Tampa that fixed his up and I know your wife would just love it, It has shrubs painted on the sides and really looks nice
maybe some of out Tampa guys will take a picture of it for you, It's down 580 west on the right
and you have to look hard :D
   / A small pole building for the PT #10
Mr Jimi, I would like to see a picture, sounds like a great idea.
Hey Bill, l can't wait to to see this get started. Looks good on paper for sure. I'm a little jealious already ;) Did you mention a custem cab? I must have missed that one. Got a pic? :eek:
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
2000 INTERNATIONAL 4900 CAR HAULER (A59575)
2000 INTERNATIONAL...
UNUSED FUTURE MSG24 24" HYD MINI STUMP GRAB BUCKET (A58376)
UNUSED FUTURE...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
Toro Groundmaster 3500D Front Deck Mower (A57149)
Toro Groundmaster...
2016 PipeHunter Vacuum T/A Trailer Jetter (A56857)
2016 PipeHunter...
