HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Projects
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 05-15-2008, 03:22 AM   #1 (permalink)
woodlandfarms's Avatar
Default Road Trail Building advice
So, I know the answer is a Bulldozer. This being said, I would love to get some advice on how to build a road / trail with what I have.
The big thing is I am unsure of is how to approach the fairly steep grade. I am going to ask permission from my neighbor to put the trail partly onto his property but in case he does not...
What I have is a 60 HP Hydraulic tractor that can do severe slopes, a 72" box blade, a bucket, and a quasi backhoe....
I am wondering how other people have made a road on such an incline with what they had and how they did it. I assume I am going to start from the top and work my way down, but what method works the best. Bucket it out, or try and box blade it?
Oh in the topo picture, 1" is about 100 feet. The red is the existing road, the blue what I want to accomplish...
Look forward to any advice.
__________________
Power-Trac 1850, grapple, hoe, 90" mower, 72" box blade
woodlandfarms is offline   Reply With Quote
Old 05-15-2008, 07:33 AM   #2 (permalink)
Super Member
Egon's Avatar
Default Re: Road Trail Building advice
You can start at either end. The bottom is preferable if you enough tractor to dig easily. I have to work from the top down to give my Toy Tractor the help of gravity as it's quite small.
Use the bucket and establish a level area, then dig and side dump making sure you keep the working base level side to side. Finish off with the box blade. Use caution as you side dump as you do not want to go to far forward and over the lip.
This is basically how a dozer with angle blade would do the job on really steep side slopes. It can be interesting to see one have part of the slope fail and he goes for a hundred foot or so slide down the hill.
__________________
Egon
50 years behind the times
Livin in a
Worn out skin bag filled with rattlin bones
Egon is online now   Reply With Quote
Old 05-15-2008, 08:26 AM   #3 (permalink)
I like to use a slope and cut the drive with a side to side angle to shed water. As to the machine, I like tracks for consistent cuts. If you're adding stone, an excavator (backhoe) is an option, but it's slow. Focus on the water, and make sure the road bed is in subsoil.
jmf
jmfox is online now   Reply With Quote
Old 05-15-2008, 08:56 AM   #4 (permalink)
Gold Member
Treemonkey1000's Avatar
You might just take a drive on one of the local back hiking roads or logging roads to see how they scooped out their road. Given of course they had bigger equipment. Is there any chance of moving out a little from the steeper slopes shown on your map to less agressive inclines? The other guy mentioned watch for signs of water that you would have to manage for drainage.
__________________
1st Peter 6-9
Treemonkey1000 is online now   Reply With Quote
Old 05-20-2008, 12:57 AM   #5 (permalink)
New Member
Another thing to keep in mind. How deep is the soil on that slope? In some the areas down river, the Lewis River for those not fortunate enough to live elsewhere, the bedrock is quite close to the surface. I found this out the expensive way when my polebarn was being built. The rock outcroping a 150' from the site is part of the ridge that runs under my shop. The excavator broke a tooth on his bucket when he hit it.$$
Also remember we get a lot of rain the first week of June, I'd make sure the ground is dry. Good luck and have fun!
__________________
Michael in Cougar
1300D FEL, tiller, box scraper
DR 15hp field mower
AD18 is offline   Reply With Quote
Old 05-21-2008, 12:12 AM   #6 (permalink)
Gold Member
ampsucker's Avatar
looks like from the existing road you're climbing 50-100 feet in elevation but it's over several thousand feet of distance, then following the ridgeline pretty much from there.
you didn't mention what your final goal is. is this just a hiking and 4 wheeling trail or something more?
for a gradual but steady climb without sharp turns, it's very important to crown the road so the water flows off it into the ditch on either side and the road itself doesn't become one big ditch. when you remove alot of vegetation, you also remove resistance to water flow. your road can easily become a river in heavy rains. plan on buying some culvert pipe wide enough to go under the road bed if you have locations that require this.
if keeping it woodsy, i would recommend not disturbing the soil more than necessary. cut the trees and brush and leave the stumps and root balls intact. plant a cover crop you can bush hog and erosion won't be too bad. you can drive on it, walk on it, 4-wheel, etc. brush killer will kill the stumps and you can fill in any holes as they rot away. you can always add crushed rock at any time to rough areas and larger rock to stabilize mud zones.
if you want something nicer, you should probably bulldoze the root balls out and grade it all down to eliminate sink holes as the tree roots rot away, pack it, lay white rock with a vibrating roller and then chip and seal or asphalt. hope you have deep pockets if that is where you're headed!
no matter what you do, a good ditch and a proper crown is your friend.
amp
__________________
PM me with your email address to receive my Monthly Lawn & Garden Calender of Reminders. Helpful tips in your email each month.
Kubota BX24 (loader, hoe, 60" belly); Ford 800 tractor; Scott's/Deere 42" mower; 5' and 6' rear blade; 54" Howse tiller; 20' 7,000 lb carhauler trailer; 2 other trailers; 5' dethatcher; 10" single bottom moldboard plow; middle buster plow; 600 lb roller; 3pt auger; front tire chains; Stihl and Honda small engine equip.
Growing with you season by season.
ampsucker is offline   Reply With Quote
Old 05-22-2008, 08:23 PM   #7 (permalink)
Super Member
3RRL's Avatar
Well, if it was me, I would use your boxblade to rough and that road.
Do you have top and tilt?
How strong are your lower lift arms? They will need to be very strong so as not to bend them in the manner I'm suggesting.
Getting a level surface on a slope with the fel bucket will be a little pit of a task since you can't tilt the bucket when your tractor is on the side slope. I would start where your existing road is. Have you ever seen how a bull dozer cuts a road into a hill side? They start on the hill side and tilt the blade so It's sort of level. The dozer is tilted a little, but the blade is level. Then they take a cut out of the hillside using a "scalloping" method.
So they take a cut into the hill and turn out of it, pushing the dirt from the high side to the low side. I would use the boxblade cutting in reverse by tilting the side link so your boxblade like the dozer blade. Once you get a level spot you can use the FEL bucket or keep doing the scalloping with the boxblade. I have done many roads and trails like that. Just be aware that your lower drag links need to be stout enough to handle it. I bent mine but reinforced them and now use that method all the time.
__________________
Rob-
...The Older I get...the Better I Used to be...
3RRL is offline   Reply With Quote
Old 05-22-2008, 08:31 PM   #8 (permalink)
blagg's Avatar
Location: Pendleton and Meacham, OR the coldest place in Oregon
Wear your seat belt
__________________
08 Grand L3540 HST, R-1's, LA724 w/quick attach, Home made ballast barrel. 6' box blade, 6' landscape rake, Markham tooth bar Oh, and 74 inch Farm King snowblower
blagg is offline   Reply With Quote
Old 05-22-2008, 08:50 PM   #9 (permalink)
I have the ability to tilt my box blade by about 15 degrees or so. PT is not a dirt tractor like what you guys have, it is more like a skip loader than the guts tractor. But, it can move dirt so I will give it a try.
Thanks for all the advice. Will take some pix as this is one of my summer projects...
Carl
__________________
Old 05-22-2008, 11:20 PM   #10 (permalink)
Gold Member
I agree with ampsucker...what are doing with this road? How you will use it makes a big difference on how you make it. You also look to have a 50 foot drop(rise) in the first 150-175 foot of road from the red area...that is steep! I know you already said you don't want this answer...but...
Rent a dozer for one day. You can rent a smaller dozer (if your trees aren't huge) for about $250 a day around here. You could get at least a Case 550/650 or Cat3. You get a six way blade and all your contouring can be done in just a few passes. The learning curve on the new machines is very steep...one handle does all your blade work. They are MUCH more stable on slope than anything resembling a tractor. Contour the area, run with a blade tip next to each side to make a ditch, spread gravel if needed, then get home safely and have a well deserved cool one. We want to hear from you again...and those slopes are steep!
Sorry for giving the answer you didn't want...I just think it is the safest and much less risk/wear-n-tear on you and your machine. I would be happy to help...but driving me and my little dozer from ohio to you would cost a bundle! Let us know more details...and take some pics...
Peter
jdmar is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
