HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Projects
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 05-28-2008, 08:53 PM   #1 (permalink)
Elite Member
schmism's Avatar
Send a message via AIM to schmism
Default pull'n cable
So i needed to run some power to 3 or 4 diffrent locations around the yard.
Most under 50' runs but when you looked at all 3 or 4, it was quite a few feet of wire.
Initially i thought about trenching and renting one, but really seems like overkill for such a project.
The old guy next door has this modified diching/plow thing. (like a patato plow) that ive used before to cut some WIDE trenches about 10" deep, it works but is overkill for wire. (cuts a great drainage ditch though)
I had heard about people riging middle busters to do this, and a real cable pulling machine is nothing more than a thin plate of steel that you attach the wire to.
So when cutting the fence line the other day i noticed another impliment he had laying in the weeds.
Figured if i could remove one of the 2 fingers, replace one of the bolts with an eye loop then icould pull some wire with it.
So thats what i did.
http://www.snjschmidt.com/pics/05-28...%20(Large).jpg
figure it will pull about 8-10" deep. good enough for the short runs to the
-well/pump house
-chicken coupe
-new above ground pool
-back to the service pole for a nightlight
area's were i suspected roots i cut first with no wire as i ususally couldnt pull it in one pass, but other parts of the yard that were clean were easy to pull in one pass.
after i was done i ran back over the seam with the wheels and pushed it back down, min disturbance to the yard . in a week you shouldnt be able to tell i did anything in the first place.
__________________
Steve - TC33D 4x4 FEL, dual rear remotes with toys
schmism is offline   Reply With Quote
Old 05-28-2008, 09:11 PM   #2 (permalink)
Wombat125's Avatar
Default Re: pull'n cable
Sounds like that worked really well, although the proof is in the continuity check.
I was thinking it would be crafty to fab up some kind of hollow ripper and then mount a spool holder above it. I think they use something similar for laying sprinkler system hose.
My friend used to work for SpiderPlow, but that might be just a touch overkill for this application.
Wombat125 is offline   Reply With Quote
Old 05-28-2008, 09:55 PM   #3 (permalink)
Elite Member
schmism's Avatar
the tension on the wire is actually quite small. We were able to pull the wire back and forth over about 30' quite easly by hand.
__________________
Old 05-28-2008, 10:11 PM   #4 (permalink)
Willl's Avatar
Quote:
Really !, wow, I wouldn't of thought it would not be that easy at 10' let alone 30.
You guys with minimal rocks like that have it easy, I wouldn't get 3' out here.
But if I could, I'd copy the way kennyd did it.
__________________
My PhotoBucket
If you can read this, your 'Ignore List' isn't working.
Willl is offline   Reply With Quote
Old 05-28-2008, 10:29 PM   #5 (permalink)
Elite Member
kennyd's Avatar
But if I could, I'd copy the way bx24 did it.
bx24? That is my picture, My tractor, My attachment, and My yard!
Here are two post's where I detailed it: ONE and TWO
__________________
JD 4110HST
FEL, 60" MMM, 60" Rear Blade, Ballast Box, I-Match, #380 Snow Plow, FEL Forks, Goossen 3PH Chipper/Shredder, Markham LD-48 Grapple and much more "stuff"
kennyd is offline   Reply With Quote
Old 05-28-2008, 10:41 PM   #6 (permalink)
Willl's Avatar
Oops, my bad. Didn't even read his post, just snatched the pic and posted it.
This post.
Credit goes to Mr.Kennyd, not bx24. I'll edit.
__________________
My PhotoBucket
Old 05-28-2008, 11:23 PM   #7 (permalink)
davitk's Avatar
Today's project (I copied kennyd)
pulln-cable-dscn0216-1.jpg  pulln-cable-dscn0227-1-1.jpg  pulln-cable-dscn0229-1-1-1-1  pulln-cable-dscn0234.jpg
__________________
Happiness is 2 rolls of duct tape
davitk is offline   Reply With Quote
Old 05-29-2008, 08:44 AM   #8 (permalink)
Gold Member
I've got 1 telephone wire that goes across my yard. It's down about 14 inches. I've cut it and had to fix too many times. Wtih the number of lines you're running you could learn to curse like I did. If I was doing it and want those lines there for many years I'd over kill and go a lot deeper than that tool will take your wire.
Bill
Botabill is offline   Reply With Quote
Old 05-29-2008, 09:29 AM   #9 (permalink)
davitk's Avatar
Quote:
Bill
18" is code.
__________________
Old 05-29-2008, 12:05 PM   #10 (permalink)
Charlesaf3's Avatar
Location: Boston & Martha's Vineyard, People's Republik of Massachusetts
I've had coppying kennyds setup in mind for a while. I was going to solve botabill's issue by laying in conduit and fishing the wire through that - anyone tried that with a wider pipe on the back of the subsoiler?
__________________
Charles
Kubota B3030
Kubota M59 w/hydro thumb
Neat stuff - ATI Preseeder, Hydraulic PHD, Wallenstein BX62r Chipper, Millonzi Grapple, CA 4n1 Bucket. Delta Hook Rear QA system.
Too many other random attachments to list (or to own, per my gf) and a really bad tool addiction. But at least I haven't bought a dump truck or bulldozer. Yet.
Charlesaf3 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
