HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Projects
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-09-2008, 06:27 PM   #1 (permalink)
Super Member
Location: First organized permanent settlement in the northwest territory
Default DRAIN PIPE & CULVERT Leaf Screen
This is what I use to keep leaves from getting into my Culverts and Drain Pipes and plugging them up.
__________________
Tractors
2003 Kubota BX1500/2004 Kubota Bx23/New- Kubota BX1500
60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
60'' MMM/Clamp on Forks/48'' MMM
LBrown59 is offline   Reply With Quote
Old 06-09-2008, 06:46 PM   #2 (permalink)
Gold Member
johnnylight's Avatar
Default Re: DRAIN PIPE & CULVERT Leaf Screen
Nice Idea.
I would also used it for keeping the critters out.
field mice etc..
nice job.
__________________
John - TC34DA 757C backhoe/FEL/rake/QA fork/rdm/toothbar/subsoiler
johnnylight is offline   Reply With Quote
Old 06-09-2008, 10:10 PM   #3 (permalink)
Super Member
Quote:
Originally Posted by johnnylight
Nice Idea.
field mice etc..
*nice job.
* Thanks.
If I had it to do over agan i would not have drilled the holes in the cap as the screening is plenty of opening into the pipe.
The screening is held in place by two large hose clamps one on each end of the screening.
__________________
Tractors
Old 06-09-2008, 10:23 PM   #4 (permalink)
klm
I'm looking for ideas for cleaning out a 14" X 20' culvert. Sure don't want to dig it up. Keep thinking about some sort of roto-router driven off the tractor pto.
klm is offline   Reply With Quote
Old 06-09-2008, 10:58 PM   #5 (permalink)
Super Member
Quote:
What is the culvert made out of?
Is it double wall smooth bore?
The state will clean out my smooth bore double wall plastic culvert if it gets plugged up.
__________________
Tractors
Old 06-10-2008, 04:17 AM   #6 (permalink)
Gold Member
RedDirt's Avatar
klm,
Any chance of blasting it out with a water stream? I've got one too that needs cleaning. Luckily, I have a fire hydrant within fire hose distance but a tank truck could supply water too. I think a 3/4" to 1" dia sked 40 pvc pipe with a 45 degree and hose fitting on the end would allow one to rotate the stream in a desired direction. I'd make four 5ft screw-together "rigid hoses", start at the far end and blast away. I have a non-adjustable fire nozzle that fits on a garden hose that shoots a fairly powerful stream at our unregulated 80psi source. These nozzles are available at many hardware stores like Orchard Supply or ACE.
RedDirt is offline   Reply With Quote
Old 06-10-2008, 10:51 AM   #7 (permalink)
Super Member
3RRL's Avatar
klm,
I had the same problem and posted here a couple years ago for solutions.
I had no water source near the plugged culvert, but I got the Fire department to come out and use their high pressure hose to un clog it. He got to it from both sides until he blew a hole through the clog. It was mostly sediment dirt, so once the hole was in it, the next rain opened it up again.
__________________
Rob-
...The Older I get...the Better I Used to be...
3RRL is offline   Reply With Quote
Old 06-11-2008, 02:06 PM   #8 (permalink)
klm
It's actually an old steam pipe, smooth sided about 1/4" steel. Never thought about asking the state/county or fire dept. Both good ideas, will give it a try. There is no water source nearby.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
