HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Projects
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 07-31-2008, 03:20 PM   #1 (permalink)
Default re-setting a torsion axle
My father took a small road, when bringing one of the mares back from the Vet for pregnancy checkup.
He took the corner too tight when taking a right hand turn onto a small, pre-fab concrete bridge over a stream, and hit the side edge of the bridge with the right front wheel of the trailer.
After it ate 1 tire completely (wire was coming out and tire burst !) he bought a brand new tire/rim because he needed to bring another mare to the stallion. Its spring time, and the ladies just dont wait till we get our trailers fixed
The swing arm of the front axle was bent, setting the right front wheel roughly 7ï½° out of line with the rest of the tandem.
I tied a chain over the axle, to prevent pulling the swing arm out of the main axle body. its only 4 strings of rubber holding the wheel in place, sideways, and they do that pretty nice when the suspension is loaded.
Then i used a piece of C-channel, so i could pull from the axle stub, instead of pulling on the edge of the brake anchor plate, which will most probably bend it and seize the brake.
It stopped the 5245 in low gear 4wd making black spots on the pavement. I backed up and jammed it a bit, setting it back all at once.
It toes in a little now, but i assume the rolling resistance of the tire will pull this perfectly straight on the road.
I made a picture of the C-channel i used, because it was completely tordated afterwards... At least its cheaper than a new 1 ton brake axle (350 Euro for me, 500 euro for end-users)
I did get it near perfect in direction of travel, though the tire still leans in a bit...
The last half degree of misalignment maybe wears the brand new tire, in the time that the other 3 (currently at 40% thread) are worn too...
My dad wants to buy a new one within 3 years anyway, so it will last its time.
Oh, and notice the rust chipping off the silo pole where the chain was attached: I'm glad we sold the pigs because therefor the silo is no longer in use
p.s. the black spot in the silo pole, indeed, is a HOLE ! I'm glad i didnt pull the darn thing over
re-setting-torsion-axle-afb006.jpg  re-setting-torsion-axle-afb007.jpg  re-setting-torsion-axle-afb008.jpg  re-setting-torsion-axle-afb009.jpg  re-setting-torsion-axle-afb010.jpg
__________________
Free scrap is a good investment !!!
__________________
1967 Zetor 3011, rebuilt trans, engine to be rebuilt this summer
1986 Zetor 5245, my old man's tractor, i just own the loader
1998 Volvo S70 TDI
2007 Volvo 440 1.9 TD based dirt buggy, under construction
Renze is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.15624 seconds with 9 queries
