patrick_g
Elite Member
I have a shed on the side of my garage-shop. the garage-shop is 36 x 48 divided into two 36 x 24 portions, one is a three car garage and the other is my wood shop. the shed is 21 x 48 and is on the south side of the garage and wood shop. The shed is enclosed on three sides and has a 3:12 shed roof (or is that 2.5:12 ??? anyway about 9 degree slope) It is not large enough for the tractor with implements installed.
I left the south side open thinking if it rained and snowed into the interior too much I could enclose it. Now I am enclosing it. It will hereinafter be called the metal shop. Wood and metal working are incompatible and I NEED a separate metal working space. The tractor and implements and trailers and ... will go into the 35 x 70 metal bld being moved near to the house.
The shed is engineered steel trusses on 12 ft centers with engineered truss type columns dividing the space into 4 bays of 12 ft each.
I am doing the drop ceiling in Hardy panel (fiber cement board in 4 x 8 sheets 1/4 inch thick) and also on the walls for fire safety (welding and such.)
Here are a few pix to show the work in progress...
Picture of cluttered shop was included by accident.. The door leads to the metal shop however.
Dark picture is inside the metal shop looking out the hole for the overhead door (inline with overhead door leading into wood shop. The wood shop has nearly everything on wheels so I can move stuff out of the way and bring a vehicle into the shop to work on it under A/C or heating.)
The picture showing 3 recessed windows shows the newly built wall. There are 6 windows, 2 per 12 ft bay (3 of the 4 bays) with the 4th getting an 8 ft tall 10 ft wide overhead door.
The picture with the ladder in is is inside the metal shop showing window holes which now have windows installed, pix later.)
The windows are recessed 2 feet. The apace below the windows will be shelves.
The ceiling gets pretty low next to the windows. I am 6'2" and with boots on I have good head clearance at the windows. Ceiling goes up over 12 feet at the common wall between the shed and the wood shop and garage. I will be blowing in F/G ceiling insulation to get an R value of at least 45 and using batting for the 2x6 wall cavities. Lowe's had a sale on widows with no upcharge for low E glass and argon fill for the windows which are in rough openiings of 48x17 1/4 (sliders.)
I can extend the A/C duct from the wood shop to the metal shop. I haven't decided if I will "zone" the metal shop or what. I can heat and cool it as part of the wood shop with little mod to A/C or install some dampers and a thermostat and it can be its own zone. decisioins decisioins. I have a propane line to the shop so can easily put in a separate heater or maybe even a barrel heater fired from wood scrap from the wood shop (supplemented as needed with cordwood.)
Pat
Pat
