Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1
    Elite Member AlanB's Avatar
    Join Date
    Jan 2004
    Posts
    2,532
    Clarksville, TN, USA
    NH 1925
    Default Garage / Barn Door height for Tractor / backhoe
    I am danger close to building my workshop / garage / barn.
    Going to be 60 X 40 with 12 1/2' eave height.
    Going to start with a slider on each side, centered. (the 60' length)
    Thinking of going with a 10' door, so I would have room ot put a wing overhang on it later if desired while staying under the other roof.
    Looks like my hoe will sneak under a 10' door if I lay down the hoe part, could stand it back up after I was through the door.
    Anyone have some insight or reccomendations as too which way too go before I commit?
  2. #2
    Member
    Join Date
    Feb 2008
    Posts
    42
    Youngsville,PA
    05 JD 3320 300cx
    Default Re: Garage / Barn Door height for Tractor / backhoe
    Same as your garage can never be big enough, your door can never be big enough. How about a door on the gable end(short wall) so you can pull in long stuff, like truck and trailer. Even if you can't afford the doors frame in the headers. Then as your budget allows all you will have to do is remove some siding and a few purlins or studs. Much easier than adding the headers afterwards. Good luck, eddy622611
  3. #3
    Platinum Member BarryinMN's Avatar
    Join Date
    Feb 2003
    Posts
    860
    Minnesota
    JD, Allis-Chalmers, Zetor
    A 12' polebarn sidewall = 10' door free span.
    10' door free span = 8.5' freespan with a rollup garage door & opener.
    You say sliders now but with use will want a GDO.
    Gable end doors will reduce the rain snow falling on the driveway apron. If concrete no problem but dirt/mud will drag in the barn.
    Veneer Tree Farmer
  4. #4
    Member
    Join Date
    Feb 2008
    Posts
    42
    Youngsville,PA
    05 JD 3320 300cx
    A 10' door with a 12' ceiling is about as high of an overhead door as you can go with standard radius tracks. Low clearance tracks are more money and don't work as smooth. You can go up to 20' wide. Good quality overhead doors with operators installed by a professional is the only way to go. Upfront cost seams high, but if you figure 365 days a year it dosen't take to many years till your down to pennies a day as far as cost goes. Do only one at time if that is all your budget will allow. This is money you will never regret spending. Especially as you get older. If you can swing it go for it you will glad you did. Happy New Year, eddy622611
  5. #5
    Platinum Member atgreene's Avatar
    Join Date
    Aug 2007
    Posts
    873
    Sebago, Maine
    2005 TB135 Excavator with Thumb, Quick Attach System, Ripper tooth, 3' Hydrauic Tilt Clean-up Bucket, Skeleton Bucket, 1986 Kubota 4150 with Loader and Quick Attach with Woods Forks, JD B, 1963 IH 504
    A 10' x 10' door is small when it comes to equipment. I built a 42' x 42' pole barn and added over head doors. 2 10x10 and 1 12x12. The 10'ers will just allow my GMC 5500 in, but real tight on mirrors. New F350's etc.. have the wide mirrors etc..... It's a pita to pull in mirrors every time you go through. I'd recommend 12' wide no matter what you do. I wish I had.
    Good luck.
    2009 Kubota M7040, cab
    2005 Takeuchi 135 excavator
    1963 Oshkosh 4819
    2013 GMC 3500 6.0 w 9-2 Boss V Fisher poly Sander.
    IH 504, JD B, Ford 2n, Farmall cub, Gehl 1475 Round Baler, JD 640 rake, Vermeer 2500 Bale Wrapper, Zetor 185 Drum Mower, New Idea 217 manure Spreader, Kuhn 4 star tedder, Farmi 501 winch.
    Local 740 Portland ME
    20 Scottish Highland Beef Cattle, 3 Herefords, 3 Goats, 2 Alpacas, 2 Llama, 140+- layers, and lots of maple trees.
    Facebook: Phillip View Farm
  6. #6
    Elite Member SnowRidge's Avatar
    Join Date
    Jul 2003
    Posts
    3,091
    East Tennessee
    Power Trac PT-425 / Branson 3520
    Gable end with some overhang to keep the rain out. Doors on both ends so that you can drive through if need be and get a nice breeze in the summer. 10x12 minimum. Bigger if you can swing it. Gable end doors let you pull long rigs inside and leave the side walls for storage, tool, and/or work bench areas. The doors don't have to be the same size on both ends, nor do they have to be centered.
    A 3/4 HP Craftsman GDO will operate at least a 10x16 door with no problem. Have the door professionally installed, but install the garage door opener yourself. Consider setting the electric eyes high enough that they won't shoot under high ground clearance equipment parked in the doorway. Nothing like having someone accidently push a button and having a door come down on your nice shiny tractor. This will violate the safety gods rules, so think about it before you do it. You may also be able to add a second set of eyes.
    If you can, orient the building so that the open doors get you light and breeze where and when you need it. Having just the right doors on your shop is great. Being able to close them from the house when a sudden shower pops up is priceless.
    Besides it's fun to watch stray cats and dogs come tearing out of there, when the doors start coming down unexpectedly.
  7. #7
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,430
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    When I was having buildings put up, I found out it didn't cost that much more to go up. I bet if you check you well find a 14' side wall well not be that much more. Then you can have a nice 12X12 door and you well like it.
    I had one put up that had 16' or 18' side walls I can't remember for sure, but the price went way,way,way up. Also on the 14' you get some real nice storage room over the bath room, office, ect.
    If you put your door in the side wall made sure you have nice over hang. I think that was said before.
    My shop now is only 10' now but not pulling big stuff in it, wish it was 14' just for the storage up above.
  8. #8
    Gold Member
    Join Date
    Jul 2006
    Posts
    416
    Ohio
    Have a few of this and that...but I bleed green!
    I recall your wife does landscaping... any thoughts that she may want to load the truck/trailer- skid loader(Bob) or tractor or backhoe on a trailer the night before or come in from a day she got rained out and leave things loaded and under roof? We have 10' under truss and its VERY close with a tractor on a deckover with the ROPS not folded, we fold them down so we don't take out any lights. Or would she want to store bulk shredded dirt in a corner of the barn using the dump trailer? I don't know how high those things need to clear to dump.
  9. #9
    Silver Member wolfpack2's Avatar
    Join Date
    Dec 2004
    Posts
    238
    SE Michigan
    JD 4520
    I had to make the same decision a few years back. I wound up with a 48 x 60 x 16 with 14ft doors. The max legal height in my state is 13 ft 6 in, so I can now fit any legal height load inside. The truck and trailer in the picture were parked inside all loaded up and ready to go the night before we left with it for a 600 mile trip. Another advantage is my dad's 5th wheel will fit inside when we need to work on it. It was also a lot easier to pour the concrete floor as the trucks just drove in. The extra height will cost a little more, but it is well worth it in the end and it will also have a better resale value. My dad built his several years back and now wishes it was taller as his trailer will not fit inside. Good luck with it.
    Attached Thumbnails Attached Thumbnails Garage / Barn Door height for Tractor / backhoe-2007-f350-tc40d-jpg   Garage / Barn Door height for Tractor / backhoe-inside-barn-2-jpg
  10. #10
    Elite Member CurlyDave's Avatar
    Join Date
    Dec 2005
    Posts
    4,480
    Grants Pass, OR
    JD TLB 110
    Quote Originally Posted by AlanB View Post
    The day will come when you will forget to lay down the hoe and you will have a repair job more costly than a door high enough to just drive right through.
    I will never build a booby trap for myself.
    40 Acres on a hill - fantastic view. JD 110 TLB, 4-n-1, 12" bucket, 18" bucket, Addington thumb, rock bucket (doubles as root grapple)
    Not only do we not understand the universe, if someone explained it to us, we would not know what he was talking about.
    Isaac Asimov
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
