Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
  1. #11
    Gold Member
    Join Date
    Apr 2009
    Posts
    311
    Mason MI.
    B2920
    Default Re: Plans for a small bridge?
    Heres the bridge I built on my property last fall. I made it out of used T-Bar joist I primed and painted.
  2. #12
    Gold Member
    Join Date
    Mar 2009
    Posts
    329
    New Jermany
    none now
    We have an old flatbed, found an older one that had already been plated w/ 3/8 steel plate spanning around 20 feet at the Motorcycle club. The stake pockets make it eazy to add handrails...they drive their ford tractor w/ 72" flail over it...
    I do like the one pictured above...
  3. #13
    Join Date
    Dec 2007
    Posts
    1,461
    Eastern Ontario
    Jinma 284(Spirit fel), MF 135 (MF200 fel)
    I have a similar situation with half of my property on the other side of a large creek and about 30 acres of beaver pond. I have to do some work on the dam as soon as the high water recedes . For access to the other side I went downstream and put in culverts. Guess I did not trust my own engineering skills to risk tractors and trailer loads of wood. Good sugggestions here though! One of my neighbours used four old utility poles with four inch rough decking and rock cribs on each end. -- makes me nervous to take the ATV across it but he drives vehicles across it fairly regularly.
  4. #14
    Join Date
    Jan 2008
    Posts
    2,444
    Coachella Ca.
    2016 Kubota 4060
    I'm always one for liability issues. As simple as things may seem, the minute someone gets hurt they own your property, sorry but that our society today.
    Whatever you do, do it by the book so if and when something goes wrong your covered.
    What sounds simple is a ATM card fo ran attorney.
  5. #15
    Super Member woodlandfarms's Avatar
    Join Date
    Jul 2006
    Posts
    5,489
    Los Angeles / SW Washington
    PowerTrac 1850, Kubota RTV x900
    Quote Originally Posted by iplumb View Post
    this is an interesting idea.. What do you think a bridge of this design could support?
    Power-Trac 1850, grapple, hoe, 90" mower, 72" box blade
  6. #16
    Super Member
    Join Date
    Apr 2006
    Posts
    6,484
    Wise county Texas
    Kioti DK 35 now
    My brothers FIL had a similar problem , deep live creek. he got a good deal on an old reefer trailer, cut of the top and drug the trailer floor over the creek. We have used that bridge for 15 years and have hauled 20 round bales over it at a time, it doesn't even flex much.
    He set 2 steel post on the up river side and welded chain to the trailer. (on each end)
  7. #17
    Elite Member
    Join Date
    Apr 2005
    Posts
    3,980
    nicholson, pa
    John Deer 318
    http://www.fpl.fs.fed.us/documnts/fplgtr/fplgtr125.pdf timber bridge superstructures
    Timber Bridges timberbridges
    Printable Covered Bridge Plans covered bridge
    I plan on making a small covered bridge, it will be 22' long with three spans of two 2x12x10 and 2x12x12's bolted together. (the boards will be staggered so that the joints do not match up). These will have a 4' ramp cut into them at each end. Horzontally they will be held together by threaded rod with washer bolts and steel plates and 2x12s every two feet. the decking will go on top of this frame and then the covered part will be put on with 4x4's holding up a wooden shingle/shake roof.
    i am in the buying part of the project stage.
    things to remember
    1'' of height per foot of lenght
    25' more holding power when a steel plate is used.
  8. #18
    Gold Member stravis's Avatar
    Join Date
    Apr 2009
    Posts
    258
    Henderson, GA
    2009 John Deere 5101E Limited
    I sincerely appreciate all the help, folks.
    Forgeblast, the timber bridge link is exactly what I'm looking for. I think that would work perfectly. Any ideas where to find poles like that in Georgia?
  9. #19
    Join Date
    Nov 2001
    Posts
    905
    Green Bay, WI
    Kubota F2400, Kubota F2100, Farmtrac 360, Tool Cat
    Do you live near a precast concrete supplier?
    A couple 4' wide planks would be great.
    Can you buy some new or used steel beams?
    Good Luck
    Yooper Dave
  10. #20
    Elite Member
    Join Date
    Apr 2005
    Posts
    3,980
    nicholson, pa
    John Deer 318
    If you could find some smaller pieces of telephone pole i bet you could use them.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
