SamWalton
Ahh, Stego wrap and the high dollar red tape sure bring back memories. That is some good stuff, especially the thicker wrap.
For what it is worth (probably not much) I favor putting chases in the basement walls prior to the pour. It was a few years before I got around to using one of the ones I put in for adding a patio BBQ gas outlet but it sure make gas easy to run.
Another lead to a little "fun" as I used an engine driven pump with 2 inch water hose to turn my back fill sand into a slurry as an alternative to using small lifts and a vibratory plate compactor. I overflowed one of the open chases and put a wheelbarrow load of sand into the basement. I also recommend more chases than you think you need as it is easier to plug an unused one than to drill another and worry about hitting rebar after the concrete has curred.
Patrick
Great Minds think alike.
We added many conduits through our footings and conduit runs to the utility room. We will soon be set in stone and I feel we have exceeded the recommended conduits per square inch specifications but were glad to do so.
