Building a bridge
   / Building a bridge #1
buggyman1
Kentucky
Kubota B2150Hst
I'm in the process of building a wooden bridge to cross a small creek. The main goal was to make it strong enough to cross with my Kubota B-2150 with the backhoe attached. This is prob. overkill, but... it has 125, 60# bags of concrete in the main footers, plus two other beam supports. I used 2x6's for the slats, and four 6x6's for the main beams. It's 20 feet long, and 6 feet wide.
   / Building a bridge #2
So, have you made the maiden voyage yet with your tractor? The bridge looks well built to me.
You have basically a >10' span between supports? Is it 4 6x6x10' beams sitting on the center support?
   / Building a bridge
I got the tractor stuck digging the footers, as I had to back right in the creek to get close enough to dig. I built a concrete block wall (solid block) to build one side up even with the other. I bolted two 6x6 beams together on each side of the tracking with 1/4 inch thick steel brackets i made. The other footer is even with the ground, and is bolted right to the 6x6's.
   / Building a bridge
No its 4 6x6's 20 feet long...2 bolted together.,on each side..the longest span between supports is about 7 feet
   / Building a bridge
It has 2 more supports under it (4 in all) the other 2 are 6x6 posts with cross beams.
   / Building a bridge
Heres some pics of the sides and one end finished. I really like how the end with the pavers turned-out (my girlfriend's idea). I'm planning on doing the other end as well. I did drive the tractor on it, but couldn't go all the way across because of the unfinished end, and I was a little nervous (scared to death, outriggers down ready to jump eagle eyes on any wood moving the first popping sound...bail scared)....no drama thank God.
   / Building a bridge
The pavers are 4 inches thick. I tamped the ground, then put 6 inches of gravel, tamped again, then a layer of sand (about 2 inches) a thin layer of mortar, then the pavers, dry laid. I then poured dry mortar over the top of the pavers and worked it in, and sweap off the excess with a broom. I then sprayed water on it after i let it set overnight. I plan on repeating it (the mortar) at least once more.
   / Building a bridge #8
Your bridge looks good.
I built one over my little creek that is smaller by just laying some PVC pipe and filling in over them. I put in a 4x4 held in place by a couple of heavy metal stakes to help keep it from being eroded when the water overflows it in storms. It has worked well, but I occasionally have to buy some more rocks to fill in some spots. It's a much smaller creek than yours is.
Where we walk across it another place, I just built a wooden bridge and tied it at each end to trees on each side. Otherwise, it would wash downstream in a flood. This is what our Ivy Creek Natural Area has for a bridge in one spot. It isn't strong enough to support a tractor.
   / Building a bridge #9
Nice bridge and very well built!
   / Building a bridge #10
What part of the country are you in? Any frost/ice/spring floods? Would love to build something like that but too timid.....
40' CONTAINER (A51244)
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2025 CFG Industrial MH12RX (A50123)
2025 CFG...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T270...
