Go Back   TractorByNet.com > General Forums > Projects
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 08-28-2009, 11:10 PM   #101 (permalink)
Default Re: Bridge#2
Quote:
Originally Posted by jimmyj View Post
Buggyman, your bridge is amazing. Thanks for sharing this and congratulations on a job well done!!!
Thanks...lots of help from people on TBN.
buggyman1 is offline   Reply With Quote
Old 08-28-2009, 11:14 PM   #102 (permalink)
Quote:
Originally Posted by johndeere4300 View Post
You did a great job on the bridge!
Do you have another place to build a bridge ?
With two bridges on your property now.. That should increase the value of it!
Thanks for sharing your work!
Thanks...lol no more bridges, at least on my place.
Old 08-28-2009, 11:28 PM   #103 (permalink)
Hauled 8 ton of gravel (57's) today, put about 6 ton on the long-end of the bridge. I made lots of trips across the bridge with the fel loaded with gravel. No problems at all. I finally got to drive all the way across it. I'll let it settle some, and then put the finishing touches on the backfill. I may start on the rails tomorrow, not sure how i'm going to do them...any ideas?
Old 08-29-2009, 06:31 AM   #104 (permalink)
Great Thread , Thanks for the detailed steps & great pics buggyman1 . Allthough the second night time pic has a spooky look to it , Looks like a ghostly figure on Your tractor . Bob
cowboy357 is offline   Reply With Quote
Old 08-29-2009, 09:15 AM   #105 (permalink)
nhkabotab7800's Avatar
very cool to follow this thread....wood rails? i would suggest a stifener on the outer edge of the wood planks to keep from twisting, perhaps that can be incorporated in the rails?
nhkabotab7800 is offline   Reply With Quote
Old 08-30-2009, 07:22 PM   #106 (permalink)
New Member
I am in the process of getting ready to do a project like this on my property. I was thinking culvert, but it will still flood, so I am going bridge. I need to raise my road level where I cross my creek up at least 4 feet and span it about 20 foot on each side. The creek is normally about 2-3 foot wide and about 3 inches deep, but when it floods bad enough to destroy my current bridge it gets about 11 ft.+ and about 30-40ft. wide. It's crazy... I am looking to build 2 pillars about 4 ft. above ground on each side about 20ft. back from the banks, build the road up to it, span it with either the trailers or railcar, and use my current bridge for center support, so I can get to my house when flooded. Where would one look to get either 2 flatbed semi trailers or a flatbed railcar. How much will they cost. What will a project like this cost? Any ideas? See pic...
__________________
Thank you,
inthesticks
My Personal Quote: If you buy property with a creek on it find out the same of the waterway. Example: The creek running diagonally through my property is 2 inches deep and 1.5 foot wide under "normal conditions" when it rains more than 2 inches in an hour it gets about 12 foot deep and 50 foot wide, hence the name "Deep Creek" No really, I got pics....
inthesticks is offline   Reply With Quote
Old 08-30-2009, 11:29 PM   #107 (permalink)
Great project. I need exactly the same thing over my creek, about 25 feet across. As for the rails, what if you decided how many and where you want posts, then replace those slats with some that extend maybe 24" out past the width of the bridge. Then use this extra length to place diagonal braces for the railings?
__________________
Alan L., TX
South of Bugtussle
North of Mustang
On the banks of Buck Creek
We don't rent pigs.
Alan L. is offline   Reply With Quote
Old 08-31-2009, 11:57 AM   #108 (permalink)
jayste's Avatar
Location: Close to the Oklahoma hills where Woody was born
Buggyman, you should now be refered to as Bridgeman1!
__________________
Jay
"I'm just tryin' to keep everything in balance, Woodrow. You do more work than you got to, so it's my obligation to do less!"...Captain Augustus McCrae, Texas Rangers
Have I not commanded you? Be strong and of good courage; do not be afraid, nor be dismayed, for the LORD your God is with you wherever you go. Joshua 1:9 NKJV
jayste is offline   Reply With Quote
Old 08-31-2009, 12:37 PM   #109 (permalink)
RobertBrown's Avatar
I may start on the rails tomorrow, not sure how i'm going to do them...any ideas?[/quote]
Are you wanting the rails to keep people on the bridge or tractors? A suspended cable supported by 4x4 stanchons every 4 ft or so may be adequate. It wouldn't be good for small children unless you put 2 or three on each side however. That design would be relatively quick and easy and probably not too expensive.
If your like me you're probably tired of building bridges and would like to put this one behind you and move on to the next project.
Something like this....
RobertBrown is offline   Reply With Quote
Old 09-01-2009, 04:33 AM   #110 (permalink)
Here's a pic of all those dreaded bolts.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Page generated in 0.06609 seconds with 9 queries
