HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Projects
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 07-04-2009, 01:04 AM   #31 (permalink)
Default Re: Lasting Non-toxic Fence Posts..Do They Exist?
casted concrete posts
Carykong is offline   Reply With Quote
Old 07-05-2009, 01:04 AM   #32 (permalink)
Elite Member
schmism's Avatar
Send a message via AIM to schmism
Quote:
+1
(and more text hear because i guess just +1 isnt enough of a message to post for some stupid reason)
__________________
Steve - TC33D 4x4 FEL, dual rear remotes with toys
schmism is offline   Reply With Quote
Old 07-22-2009, 04:22 PM   #33 (permalink)
Quote:
Originally Posted by Redneck in training View Post
I just recalled that reinfoced concrete posts were common in Europe. They had three holes making it easier to pull the tension wires even over long sections.
Betonov sloupky | E-pletivo.cz - ploty, pletiva a oplocen s dopravou zdarma[id-Slbet3]-betonovy-sloupek12x12cm-delka-280-cm.html
The post is about 4"3/4 X 4"3/4" X 9' and cost about $10. Don't know if something similar is available in USA.
I smell a business opportunity for you!
archerm3 is offline   Reply With Quote
Old 07-22-2009, 05:44 PM   #34 (permalink)
JC-jetro's Avatar
Best Kansas can offer and totally green.
JC,
Limestone posts,
Bluestem Stoneworks - Kansas Limestone History
__________________
Ford 1700, 60" Woods Rotary Cutter, home made 3-pt boom ,King Kutter( 5 ft Tiller,Middle Buster,Single Row Cultivator,Carry All and 30" Dirt Scoop).
JC-jetro is offline   Reply With Quote
Old 07-23-2009, 02:13 PM   #35 (permalink)
Gold Member
Quote:
Originally Posted by patrick_g View Post
Concrete posts are not hard to make.
1. Cut a plastic pipe in half lengthwise.
2. Reassemble with hose clamps.
3. Plug the bottom end with a wooden plug with holes to hold rebar
4. Fill with concrete
5. Rod with a spare length of rebar to remove trapped air. (alternatively smack form with a hammer or vibrate it B_U_T don't get carried away as you don't want to separate out the aggregate from the mix.
6. Cap the top hole with a holed cap to hold the rebar in position.
Some additional thoughts:
1. Add a plasticizer water reducer to the mix to get a very mobile easy flowing mix without having to add extra water which will lower the strength.
2. Keep the rebar two or more inches from the outside of the form. (if you overlap/splice rebar overlap it at least 25 times the diameter of the rebar)
3. Don't put rebar near the center of the assy as that rebar will hardly do anything for strength/stiffness (bending resistance) Three or four rebar in triangular or square pattern is good. rebar position can be maintained by tieing with stiff wire.
4. Do the math... this is a 6 inch or larger diameter post.
5. you can put waterproofer in the mix if you want the post to last for your grandkids grandkids.
6. You can bore holes in the forms (right angles to long axis) and insert smaller plastic pipe to accept cables, sucker rods, barbed wire or ... if you want really neat appearance.
After the mix sets up sufficiently to not be harmed by removing the forms you remove the hose clamps and peel off the plastic pipe to reuse over and over.
Oh, the little pipes to make wire ways through the posts... they need to be split lengthwise on one side, not cut in two like the big pipe. They can be driven out of the post with a drift and a hammer and reused.
Another nice touch is to add concrete dye to the mix and get a much better looking post.
Pat
Great Post. and posts.
My father in law built his own concrete post about 40 years ago and they are still going strong. Here is what I think are his instructions, but I am liking your scheme as well. I still have the forms he used in my shed but haven't taken on building any yet.
lasting-non-toxic-fence-posts-fencepost.jpg  lasting-non-toxic-fence-posts-fencepostattch.jpg
__________________
Nashville/Hickory
Kioti DK55c, Hustler SuperZ, 72 Box Blade, Stihl HT101, International Machines 7ft Mower, Liebherr 631B
rvaitor is offline   Reply With Quote
Old 07-23-2009, 06:36 PM   #36 (permalink)
AchingBack's Avatar
Certainly others on here have heard of or seen a ripgut fence. Everytime I attempt to bring up a link to articles, I am thwarted by some cyberghost. On my desk is a copy of The Mother Earth News, March/April, 1980, page 116. This article is listed on the web at The Mother Earth News, but the link is broken, as are a most others listed on Google.
If you have access to the materials, this could be the answer to anyone with unfriendly digging conditons, or concerns about soil contamination from treated posts.
__________________
I thank God for these gifts: Mahindra 2615 HST w/loader and backhoe. Markham tooth bar, Bush Hog SQ60 rotary cutter, Bush Hog 3507 angle blade, Bush Hog LLR84 landscape rake w/gauge wheels, Rankin loader mounted forks, 2 DR field and brush mowers.
SIBKISS - See It Big Keep It Simple Stupid
AchingBack is offline   Reply With Quote
Old 07-23-2009, 07:04 PM   #37 (permalink)
Gold Member
/pine's Avatar
Here in the S.E. the DOT is replacing all the wildlife fencing along the Interstate highways...They are upgrading from 6' (I think) to 10' (I think)...I am not sure if this is happening only in the south or not...If they are doing the same thing in your area you might check with whoever is supplying the DOT for a source...I am fairly certain they are using galvanized pipe stock/caps
__________________
Slash Pine
/pine is offline   Reply With Quote
Old 07-24-2009, 12:12 PM   #38 (permalink)
ampsucker's Avatar
didn't the OP want an 8 foot high deer fence? that would mean about 12 foot posts w/ four in the ground. is that really practical w/ concrete? i mean you would need to place each pole with hydraulics as they would weigh well over 300 lbs each.
amp
__________________
Kubota BX24 (loader, hoe, 60" belly); Ford 800 tractor; Scott's/Deere 42" mower; 5' and 6' rear blade; 54" Howse tiller; 20' 7,000 lb carhauler trailer; 2 other trailers; 5' dethatcher; 10" single bottom moldboard plow; middle buster plow; 600 lb roller; 3pt auger; front tire chains; Stihl and Honda small engine equip.
Growing with you season by season.
ampsucker is offline   Reply With Quote
Old 08-01-2009, 03:40 PM   #39 (permalink)
Elite Member
"Deer Proofing Your Yard and Garden" by Rhonda Massingham Hart.
Second Addition.
Pat
__________________
Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun.
patrick_g is offline   Reply With Quote
Old 08-02-2009, 12:01 AM   #40 (permalink)
POC
POC's Avatar
I think I'll start planting some Catalpa and Black Locust trees. Maybe my daughter could sell them as a side line of work.
__________________
Hoosier Heights Farm
Southern Indiana
Mahindra 3215, 111 FEL, 3710 BH
JD X300 Lawnmower (I refuse to call it a "tractor")
Ford 600/800 mix-n-match
IHC A-160
POC is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.33194 seconds with 9 queries
