#11 (permalink) |
WVBill, Where do you live, How deep did you run the pipe? I only ask because I am looking into laying some water pipe but it has to be down about 18" due to frost. Are freezing winters a problem for you? If so how do you plan on draining the pipe?
tjl |
#12 (permalink) |
tjl:
I'm in the Eastern Panhandle of West Virginia. Yes, freezing in the winter is an issue. The pipe is only about 8 - 10" deep and would freeze in the winter. Last summer I laid 125 feet of regular PVC pipe out to my barn about 10 - 14" or so deep. In the fall, I used my air compressor to blow the line out. This spring - no leaks so it worked. I plan to do the same thing on these black poly pipe runs. I guess one could also gravity fill the pipes with a non-toxic anti-freeze. I figure 4.13 Gallons to fill 180' of 3/4" pipe. pi x radius squared x length x gallons per cubic inch = gallons 3.14 x .375 x .375 x 2160 x .004329 = 4.13 [img]/w3tcompact/icons/clever.gif[/img] |
#14 (permalink) |
good looking place!! is that the B6100 you went to california and brought back?? i have a subsoiler with a pipe welded on the back to do exactly the same thing, around here 6-8 inches and it won't usually freeze, but the subsoiler will put it down deeper than that when needed.
heehaw |
#17 (permalink) |
WVBill,
Thanks much for the picture. That look simple enough. I have a similar setup with the soaker hoses I use in my front flower beds. Mine is definitely not as sophisticated as what you've got there. I think I'm going to use your idea to put some water pipe out to my goat's house as well as other areas. |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
