Laying Pipe
   / Laying Pipe #1
WVBill
Usa
Sold my Kubota B6100 when I moved to WA
I know this topic has been "done" before - just wanted to share pictures of my project yesterday evening. Took about 2 hours start to finish to lay almost 400' of 3/4" black poly pipe in 2 runs.
Pictures part 1 attached.
   / Laying Pipe
Laying Pipe part 2
Pictures part 2
   / Laying Pipe #3
Re: Laying Pipe part 2
Nice place you've got there WVBill. So all of that poly pipe you put in was for watering the outlying areas? I am going to need to do something of that nature eventually. Are you just hooking up outdoor spigots to the ends of those pipes?
I'm not much of a plumber so I get easily confused while working with water.
   / Laying Pipe #4
WVBILL
Generally, I don't like to use mechanical implements when laying pipe. I do , however, sometimes have dinner at a fine restaurant and have a bottle of wine.
Sorry, I couldn't help myself.
RonL
   / Laying Pipe #5
Nice job. I have a similar project to do. What type of plumbing fittings did you use to hook the poly pipe to the outdoor faucets? How deep is the pipe?
I want to just have those frost free faucets coming out of the ground at various intervals. Looks like a subsoiler might do the same thing as the rig you have there.
   / Laying Pipe
I haven't finished plumbing yet but I bought 3/4" barb - to - 1/2" fpt "el" fittings that I'll put at the end of the run. Then a 24" piece of 1/2" galvanized pipe will rise out of the ground with a faucet on top. I'll sink a 4' green fence "T" post into the ground right next to the 1/2" pipe riser for support.
I suppose I could skip the galvanized risers and just run the black poly up the support but 1) I wasn't sure about the UV resistance of black poly and 2) I didn't want to have to worry about hitting it with the weed whacker blade.
The poly pipe is only about 8" deep - doesn't run under any vehicle traffic areas. I'll blow it out with compressed air each fall.
On the supply end I'll add a npt - to - hose converter to the current outside sill cock and use a courrigated copper pipe to connect to the galvinized riser pipe. This way, I'm not altering the house's plumbing so no permits/inspections/etc. are required.
   / Laying Pipe #7
WVBill,
<font color=blue>On the supply end I'll add a npt - to - hose converter to the current outside sill cock and use a courrigated copper pipe to connect to the galvinized riser pipe. This way, I'm not altering the house's plumbing so no permits/inspections/etc. are required.
</font color=blue>
Could you explain this a little more. Sorry for my ignorance. That is exactly what I'm looking to do (I think).
   / Laying Pipe #8
Bill
They are a great tool hey !!
I can only use mine when the ground is soft, and have to cut the trench first like you say, then go back and lay the pipe in another pass.
I laid 400' of 1" pipe no worries.
My pipe layer has a much larger diameter pipe than yours and is supposed to lay up to 1 1/2" pipe.
Well the other day I tried to lay 1 1/4" pipe and it kinked all the time.
It was a cold day and I didn't have a ROPS or a helper so couldn't get the pipe nice and high like yours but I was dissappointed none-the -less.
I doubt if I could do 1 1/2" - It is way too rigid for the layer I think.
Cheers
   / Laying Pipe #9
Just a compliment on such a nice place and such great photos with text... First class!
   / Laying Pipe
tdenny: I used this set up on the other side of the house. I'll take a picture tonight and post it with explanation.
Niel: It was 90 degrees F the day I laid my pipe and I set it out in the sun early in the day so it was good and warm. Funny thing: it was crimped on both ends of the 400 foot roll at the factory and when I went to cut it just prior to laying it the air pressure had built up from the heat of the day and as I sliced into the pipe the air release was quite a surprise!
Even on a hot day, I don't think 1 1/2" pipe would be flexible enough to make it through the bend of a pipe layer tool like ours.
emery - thanks.
2019 DODGE RAM 3500 (A58214)
2019 DODGE RAM...
KUBOTA SVL75-3 SKID STEER (A52709)
KUBOTA SVL75-3...
2000 Mitsubishi Fuso FE639 Cab and Chassis Truck, VIN # JW6AAE1H3YL003648 (A57453)
2000 Mitsubishi...
2013 Hyundai Veloster Hatchback (A56859)
2013 Hyundai...
CAT D8 (A58214)
CAT D8 (A58214)
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
