Go Back   TractorByNet.com > General Forums > Projects
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 09-07-2009, 06:36 PM   #1 (permalink)
Default Wood post paint
Any suggestions for white paint for pressure treated fence posts? I saw TSC has a Homestead and Valspar brands. Any thoughts on those?
Eric_Phillips is offline   Reply With Quote
Old 09-07-2009, 10:03 PM   #2 (permalink)
Default Re: Wood post paint
valspar makes good paint.
__________________
Erik
Mahindra 3510, box blade, pallet forks, 6' KK mower...
Erik_in_Hoyt is offline   Reply With Quote
Old 09-08-2009, 10:54 PM   #3 (permalink)
Ièd suggest opaque wood stains vs paint!
Paint is a skin that when it cracks or splits will trap water while a stain will powder and simply erode.
Paint will need scraping or sanding to recoat later on, while an opaque stain simply wants a recoat.
Might be wrong, but that is my 2 cents.
PILOON is offline   Reply With Quote
Old 09-09-2009, 09:13 AM   #4 (permalink)
That was another thought, paint or stain. The stains usually say 3-5 years before they need redone. Will the vertical surface last longer? Which sill last longer paint or stain?
Old 09-09-2009, 01:27 PM   #5 (permalink)
paint will hold it's color longer - and likely stay put longer.
opaque stain will protect from UV nearly as well as paint but not crack, peel, trap water, etc...
semi-opaque/semi-transparent have good UV inhibitors, protect from moisture, etc..
transparent stain will provide protection from water, but not UV.
plus, stain can be sprayed on every 3-4 years rather than brushing on of paint.
__________________
Erik
Old 09-09-2009, 01:37 PM   #6 (permalink)
Elite Member
I'd use stain and a airless sprayer. Both Sherman Williams and Home Depot Behr Premiums are excellent. with pressure treated you have an adhesion issue unless it is "seasoned" and and dries out.
Andy
AndyMA is offline   Reply With Quote
Old 09-09-2009, 02:02 PM   #7 (permalink)
If you paint, you'd probably have to prime first. Also like Andy said, it would need to be dry first. If you paint over wet wood the water will push the paint off trying to get out.
oliver28472 is offline   Reply With Quote
Old 09-09-2009, 03:03 PM   #8 (permalink)
I would try the stain route. I have used Cabot stain specifically made for pressure treated(PT) wood with good success on fencing and decking. Every few years I wash, dry, and restain. On the paint side of things I have used exterior acrylics with lasting success over any oil based paints. The seasons and climate change wreaks havoc on oils. Good quality wood(cedar, redwood, etc) holds acrylic paints well and they do last 6-8 years. For PT wood I would stick to a good quality stain. Based on what I have heard from others I would also consider Sikkens.
Haoleguy is offline   Reply With Quote
Old 09-09-2009, 09:26 PM   #9 (permalink)
Maybe it's not applicable in your situation, but I remember reading that PT needs to age a bit before painting or the paint tends to peel?
I personally would stain it for the reasons others have already mentioned.
2manyrocks is offline   Reply With Quote
Old 09-10-2009, 05:28 PM   #10 (permalink)
nolefan's Avatar
I built a PT picket fence around my front and rear yards about 12-13 years ago. I used Behr's solid stain (pinto white) after letting the fence age for over 6 months. It held up pretty well for about 7 years and then I had it resprayed at that time. Still holding up pretty well and that is with the heat and humidity we have here in S Fla. Looks like paint but doesn't have the gloss finish and it doesn't peel just kinds of starts to wear away. I pressure sprayed it before re-staining the second time.
__________________
Kubota RTV 900, Kubota L2800HST, 5' Rotary Cutter, 6' Box Blade, Toothbar
nolefan is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Page generated in 0.06018 seconds with 9 queries
