Results 21 to 30 of 2109
11-04-2009, 10:30 AM #21Gold Member
- Join Date
- Apr 2009
- Posts
- 250
- Location
- Henderson, GA
- Tractor
- 1974 Ford 3000 and 2009 John Deere 5101E Limited
Re: The Log house Project begins........
I look forward to reading about it. My wife and I have similar plans.
11-04-2009, 06:52 PM #22Elite Member
- Join Date
- Aug 2005
- Posts
- 3,169
- Location
- NE TENN (Hancock Co)
- Tractor
- Kioti DK40SE Hydro
The footers got poured today. Some how we ended up with an extra 2.5-3 yards of crete. I could have raised heck and pointed fingers....or........
my wood drying shed now has a concrete floor
The crete trucks had some interesting moments trying to turn around the site...it made me nervous & I was just watching!
RD2008 KIOTI DK40Se Hydro
1978 Sling Blade/wood handle
11-04-2009, 07:35 PM #23Elite Member
- Join Date
- Oct 2005
- Posts
- 2,711
- Location
- Catt county New York
- Tractor
- Kioti DK35, Ford 8N, Oliver Cletrac
When I poured the runners for my pre-fab home, I had to rent the biggest bulldozer I ever say to haul them up the hill, we had so much rain that summer that even the bulldozer left ruts in the lawn over 10" deep and about 18" wide.
I can't control my day but I can control my attitude.
11-04-2009, 09:49 PM #24Elite Member
- Join Date
- Aug 2005
- Posts
- 3,169
- Location
- Tractor
11-08-2009, 08:02 AM #25Veteran Member
- Join Date
- Aug 2008
- Posts
- 1,941
- Location
- Ohio
- Tractor
- Yanmar LX4900//Cub 7532//Cub Yanmar SC2400
Rick;
Beautiful piece of property. I have a similar property due north of you (in Ohio) that is nearly identical....northern 1/4 is sloped down to a small pond and creek, the rest is wooded. I bought a dozer and started clearing out a homesite. Still debating on what kind of house to build. I will try to do as much myself as I can, don't think I'm as skilled as many of the guys here to do everything!
One question....why block over poured walls? Mostly cost? Looking forward to the project!
Frank
11-08-2009, 08:41 AM #26
11-09-2009, 08:04 AM #27Elite Member
- Join Date
- Aug 2005
- Posts
- 3,169
- Location
- Tractor
"One question....why block over poured walls? Mostly cost? Looking forward to the project!"
Frank, they would have been at least $5K extra in cost. I know thats not a lot in the big scheme, but with no building loan, $5K is crucial to my build.
As far as the trees go, I will thin all the small stuff under 4", the rest stays as we want privacy over view. It was more important for my wife to be able to see the creek and initialy wanted to build on the creek. I wanted to be up even higher on the next ridge up for a view down the valley. The creek side is the North side of the steep ridge....no sun for 3+ months out of the year(NO Thanks). So, this site is 75' above the creek on the South side, on a shelf that gets full sun year round(well whatever sun that can get thru the trees) & turned out to be a really good compromise. From the "proposed deck" we will have a view of over 300' of creek 75' below us.
11-09-2009, 08:45 PM #28Platinum Member
- Join Date
- Nov 2008
- Posts
- 603
- Location
- Brampton, On\lot Powassan, ON Canada
- Tractor
- Kubota B4200\MF 135\Kubota B3200
I am about 5 years away from building my retirement home. You have a great piece of property. Sorry if I missed anything in the thread but are you planning on going off Grid? I have some nice building spots but the cost to bring in Hydro means I would have to look at Wind\Solar\Generator. My son and I took advantage of a good storm to see what it would be like to build something out of logs. It took two years of every 2nd or 3rd weekend in the summer months to build a 10x14 shed! Anyway I am now convinced I will build a super insulated frame home and either Brick or stucco cause I would just croak if a forest fire came through. Also no Evergreen within 100 yards!
The sawmill will be a God send. I notched one side of my logs with a chain saw.Unimogdave
11-09-2009, 11:36 PM #29Elite Member
- Join Date
- Aug 2005
- Posts
- 3,169
- Location
- Tractor
Dave, I have checked into solar...$28K for a grid tired system, add $4k more for batteries. Wind is a no go here and hydro...well, I have a big creek, lots of flow, almost zero head. I am pondering some type of paddle wheel contraption, but that's on the back burner.
So, it looks like my savings will be in no A/C, and all wood heat with a water coil on the wood stove. I don't mean to insult those here on solar, but it seems to be only for those that can afford to shell out big $.
Your shed looks great....but....you have to loose the OSB doors
11-10-2009, 07:20 PM #30Platinum Member
- Join Date
- May 2009
- Posts
- 782
- Location
- SE MI
- Tractor
- Bobcat B200 TLB
You might be surprised at how much mileage you would get out of a system like this:
Medium AC Off Grid Cabin Solar Power System
- 6 Kyocera KD135GX-LP135 watt solar module
- 1 IronRidge UNI-TP/08LL Top of Pole Mount
- 6 Lay-in Ground Lug with Stainless Screw (1)
- 2 MC4 10 AWG - 30' cable extension
- 1 MidNite MNPV-3, 3 Position Combiner Box
- 2 CBI OBPV-15 DC Breaker 150 VDC din-rail mounted
- 1 Outback FM60 & Breakers installed on Magnum E-Panel
- 1 WSS Magnum Power Center MS2012/1, 2,000 watts 120VAC
- 1 Magnum ME-BMK Battery Monitor installed on Magnum E-Panel
- 1 4/0 - 120" UL Cable, Battery/Inverter (black)
- 1 4/0 - 120" UL Cable, Battery/Inverter (red)
- 4 2/0 - 12" UL Cable, Battery Interconnect (black)
- 6 2/0 - 18" UL Cable, Battery Interconnect (black)
- 8 UPG UB-GC2 AGM 200 aH 6V Battery
For about $8600 before getting any money back from the government. The prices on this kind of equipment are very favorable right now. A little conservation and planning goes a long way.
