HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Projects
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 11-07-2009, 07:35 AM   #21 (permalink)
jimmyj's Avatar
Default Re: New roof - Light or dark shingles
Once my shingles are done we are going with steel. We've put steel on our outbuildings and it is great. No more shingles on this Ponderosa!
__________________
Kioti CK30 HST TLB (The Great Pumpkin)
Allis Chalmers 616 HST w 60" MMM
Lotsa other toys that keep me broke too!
jimmyj is offline   Reply With Quote
Old 11-07-2009, 09:08 AM   #22 (permalink)
New Member
I have been in the roofing industry for 15 years now. Lighter the better, reflects heat and will not absorb heat which will wear out faster. Want to replace your roof in 7 years, buy 25 year black shingles. Staples were outylawed here in Canada years ago. Shingles are old technology, but metal is thrice the price.
uniongoon is offline   Reply With Quote
Old 11-07-2009, 12:02 PM   #23 (permalink)
woodlandfarms's Avatar
Quote:
Originally Posted by JB4310 View Post
I've put a couple of rubber roofs on. It's the industry standard on commercial low slope roofs around here. It's incredible stuff but not really applicable to pitched residential roofs.
Metal roofing has come a long way in the last few years, alot of styles and colors to choose from, if your looking for something other than asphalt shingles.
JB.
Thanks for the info JB. The salesman said the roofs were really great as well. Our pitch is something like 1 to 12 or 1 to 16. It isn't much. Our big thing is we have to insulate the vaulted sections as all they have is a 3" thick piece of particle board (It acted as a roofing and ceiling material). And to add to the insult we have all sorts of edging that is impossible to flash. So far contractor have quoted us $15K for a 1700 sq ft house due to the labor involved...
__________________
Power-Trac 1850, grapple, hoe, 90" mower, 72" box blade
woodlandfarms is offline   Reply With Quote
Old 11-07-2009, 12:14 PM   #24 (permalink)
jimmyj's Avatar
Quote:
__________________
Old 11-07-2009, 12:29 PM   #25 (permalink)
The number one enemy of a shingled roof is poor ventilation, esp on vaulted roofs. Vaulted roofs should have insullation trays installed prior to the actual insulation. Soffitts should be properly vented, gable vents are a big plus and an attic ventilator is an even bigger plus.
It gets so hot and humid here that 'continous soffitt' venting is common. Some even put ridge vents on along with gable vents. I am not a fan of ridge vents, unsightly and an avenue for water penetration. I do have continous venting in the flats of my soffitt, gable vents in every gable, one ventilator and I plan to install another next spring, R-39 insullation, and "reflecta shied" roof decking.
I have GP 30 year Onyx shingles, 5 years now, still look like new. I had the same shingle on my last house but it was build with no gable vents, not enought soffitt vents, and a ridge cap. The shingles were faded after 5 years and the new owners recently replaced the shingles, less than 15 years on a 30 year shingle. Fungus was a horrible problem on that house as well.
I just don't believe that you can too much attic ventilation, within reason.
herd is offline   Reply With Quote
Old 11-07-2009, 01:42 PM   #26 (permalink)
JB4310's Avatar
The problem is the epdm is nothing to look at, just flat black rubber, but in your case if you can't see the roof, it might work out.
The incredible thing about all these new single ply materials is that they come in rolls as wide as 20' and 100' long so far less seams compared to other materials, did my old 3000 sq ft shop roof with only 5-6 seams. Also it's impermeable to water unlike asphalt shingles or rolled roofing. those attributes make it the first choice for flat (the proper term is low slope) roofs.
JB.
__________________
JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 61"HD & 73" high volume bucket.
FORD 1700; 2 WD, 2600 hrs.
JD 320; Hydra lift, 48" deck and 48" snow blade.
JB4310 is offline   Reply With Quote
Old 11-07-2009, 03:25 PM   #27 (permalink)
The EPDM samples we have are colored. I have to find the brochure, they still weren't very pretty, but there was white, brown, silver and black as I remember.
__________________
Old 11-07-2009, 10:20 PM   #28 (permalink)
we put a whit pvc roof on a roof at work and the surface was amazingly cooler than the black rubber roof beside it.
The only problem with you need a #10 welding shade to work up there in the summer with the reflection.
tom
__________________
Any day that I don't learn something new is a wasted day!
tommu56 is offline   Reply With Quote
Old 11-07-2009, 11:24 PM   #29 (permalink)
My experience is a lighter shingle will outlast a darker shingle.
__________________
L3130HST,FEL
L5030HST,QA,FEL
MF 205-4
KK Finish Mower, 6' rotary mower, Pallet forks, PHD, Blade, Carryall, cultivator
buckeyefarmer is offline   Reply With Quote
Old 11-08-2009, 07:50 PM   #30 (permalink)
Elite Member
BobRip's Avatar
I have heard of some car companies that will not warranty a black paint.
__________________
Bob Rip
Pessimism is easy. Optimism takes a lot of work.
BobRip is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.19836 seconds with 9 queries
