Go Back   TractorByNet.com > General Forums > Projects
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 11-20-2009, 08:51 PM   #1 (permalink)
Default Cut 2" thick patio pavers
Putting in a small patio for the wife,we have all straight sided paver's and one of the finshed edge's will have some curve to it,what is the best way to cut these rounded edge's for a novice. Thanks for your input
__________________
Doing the difficult in a day,The impossible takes slightly longer
redharley is offline   Reply With Quote
Old 11-20-2009, 09:04 PM   #2 (permalink)
Super Star Member
EddieWalker's Avatar
Default Re: Cut 2" thick patio pavers
When I first started doing pavers, I rented a wet saw designed for bricks. It has a table on it that slides under the saw blade, and it cuts them super fast and clean. For the rental fee, it's a very nice tool to have for the day. For smaller jobs when I didn't want to rent a wet saw, I use a diamond blade in my 7 1/4 inch circular saw. It's dusty, but the diamond blade cuts them pretty easily. The real trick is holding them in place while making odd cuts. Now I also have a 14 inch metal cut off saw that I put a diamond blade in when doing allot of pavers. Renting a wet saw would be nicer, but the cut off saw is paid for and it does a nice job. The only drawback is that it's dusty and you have to be careful on some of those odd cuts.
Eddie
__________________
Link to my thread creating Lake Marabou. http://www.tractorbynet.com/forums/p...ting-lake.html
EddieWalker is offline   Reply With Quote
Old 11-20-2009, 09:23 PM   #3 (permalink)
Duffster's Avatar
__________________
"If everyone is thinking alike, someone isn't thinking." George Patton
Duffster is offline   Reply With Quote
Old 11-20-2009, 09:26 PM   #4 (permalink)
Quote:
Can you run the edge course perpendicular and follow the curve and make you angle cuts in the field to help conceal the edges...
I think it looks nice when the border pavers are uniform...
ultrarunner is offline   Reply With Quote
Old 11-20-2009, 09:33 PM   #5 (permalink)
Elite Member
Builder's Avatar
For small jobs, I like a mini grinder with a diamond cutter wheel. You can buy a nice mini grinder for under $75. Diamond wheel is ~$20. You can also buy masonry abrasive wheels for ~$3 each to round off the edges.
You can cut part way through the paver with the diamond cutoff wheel then take a brick hammer and tap the waste side and it'll just break off.
__________________
'07 Kubota M-7040 4x4 tractor: 70HP, Hyd-reverser, 4in1 q/a FEL w/ aux. hyd, Cab-AC, 2 remotes, R-1's, rim gaurd.
'00 New Holland LB115 4x4 Backhoe: 108HP, Powershift. Cab-AC, 4WD/4WS, posi front/rear axles, 4in1 FEL, X-hoe, Aux hammer hydraulics.
'05 Challenger MT285B 4x4 CUT: 48HP HST, Cab-AC, 4in1 q/a FEL w/ aux hyd, 2 remotes, R-4's.
'07 GMC 3500 4x4 Crewcab SLT: Dmax/Ally, utility body.
'92 IH 4800 4x4 Dumptruck: DTA-466 250HP high torque, airbrakes, 7-spd, 12' dump, 33K/56K GCWR.
Builder is offline   Reply With Quote
Old 11-20-2009, 11:13 PM   #6 (permalink)
Elite Member
JB4310's Avatar
How tight a bend are you planing? you would not cut a curve in the outside edge of the brick you would normally just relief cut the inside corners as you made a radius.
On my own front walk I have a tight turn, I did the border with the bricks on edge then ran the inside courses straight into the curve and just cut the corners to keep a tighter joint. the bricks don't change direction with the bend. That only works with a short walk, it wouldn't with a long walk. It would work with a curved edge of a patio though, since all the bricks would normally be going in one direction.
I've only done a couple of small paver jobs but I can't imagine a situation where you needed to cut a curve in the brick unless you need a super tight bull-nose corner.
If you do have to, as suggested, the smaller diameter diamond blade would be best.
__________________
JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 61"HD & 73" high volume bucket.
FORD 1700; 2 WD, 2600 hrs.
JD 320; Hydra lift, 48" deck and 48" snow blade.
JB4310 is offline   Reply With Quote
Old 11-20-2009, 11:23 PM   #7 (permalink)
Charlesaf3's Avatar
Location: Boston & Martha's Vineyard, People's Republik of Massachusetts
tile wet saw. Cuts bricks just fine. Doesn't even cost that much, I bought a knockoff at home depot eons ago and have gotten a lot of good use on it. Little pumps go pretty frequently but they are cheap.
I've done some brick designs with them - compass roses and the like, and its worked like a champ.
Grinder... I dunno. I'd rather get good with a brick hammer, much faster, equally likely to blow the bricks apart. Brick hammer isn't that tough to get ok at, though its pretty impressive to watch someone talented do it.
__________________
Charles
Kubota B3030
Kubota M59 w/hydro thumb
Neat stuff - ATI Preseeder, Hydraulic PHD, Wallenstein BX62r Chipper, Millonzi Grapple, CA 4n1 Bucket. Delta Hook Rear QA system.
Too many other random attachments to list (or to own, per my gf) and a really bad tool addiction. But at least I haven't bought a dump truck or bulldozer. Yet.
Charlesaf3 is offline   Reply With Quote
Old 11-21-2009, 12:11 AM   #8 (permalink)
jenkinsph's Avatar
Just completed a brick paver patio last weekend for one of my customers will take some pictures tomorrow.
I use a small cheap wet tile saw works great and is easy to setup and use ($110).
What I find is more important is to take the time to do a good job grading and packing before you ever lay the first brick.
__________________
Steve
Deere 4520 cab, 110tlb cab, 820 canopy, L130 lm
J Deere; 673 tiller, MX6 rotary cutter, 31B phd, 47 7' rear blade, PC1072 field cultivator, custom 8' landplane, custom 3pt 8' harrow, Leinbach 7' landscape rake, DR 3 pt chipper, Countyline subsoiler, Turbospin 450 spin spreader, Frontier; BB1284 boxblade, R66 rock bucket, 72HD materials bucket, 48" rail pallet forks, PA30 planetary auger, quick coupler buckets, I Match, topntilt, Big Tex 12PI 20' trailer, F550 diesel xlt.
jenkinsph is offline   Reply With Quote
Old 11-21-2009, 07:00 AM   #9 (permalink)
Super Star Member
Egon's Avatar
Angle grinder with the concrete blade will also work.
__________________
Egon
50 years behind the times
Livin in a
Worn out skin bag filled with rattlin bones
Egon is offline   Reply With Quote
Old 11-21-2009, 08:03 AM   #10 (permalink)
Elite Member
Builder's Avatar
That's right. Proper preparation is 95% of the key to a good outcome.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Page generated in 0.09997 seconds with 9 queries
