Results 4,391 to 4,400 of 5183
11-05-2012, 02:13 PM #4391Elite Member
- Join Date
- Jul 2006
- Posts
- 4,198
- Location
- South Central OK
- Tractor
- Kubota Grand L-4610HSTC
Re: At Home In The Woods
Yup, backhoes are expensive to own. An alternative to removing tree stumps with a backhoe (and not using explosives) is to use the FEL to dig at least half way around the offending tree and cut the trunk off below grade level. Rounup if there is regrowth. Alternatively, if cut off above ground and treated with stump destroying chemicals the stump will soon be a non problem. The main chemical is salt peter (potassium nitrate) available as stump chemical at Walmart etc.
To a man whose only tool is a hammer every job looks like a nail.
Of course, if you already have a backhoe it is more fun than the other methods.
PatNever wrestle with a pig (however titled) as you just get dirty and the pig has all the fun.
11-05-2012 02:13 PM # ADS
11-05-2012, 04:57 PM #4392
Salt peter? That is an interesting way to get rid of a woody......
Originally Posted by patrick_g
Pun intended...... If you don't understand, then you never were in the Military......LOL
RT"A Marine is a Marine. I set that policy two weeks ago there is no such thing as a former Marine. You're a Marine, just in a different uniform and you're in a different phase of your life."
Gen James Amos, Commandant of the Marine Corps.
NRA Basic Pistol Instructor,SC CWP instructor, NRA,USPSA, Marine Corps Association, and Marine Corps League Member. I support the 2nd Amendment, don't you?
11-05-2012, 04:59 PM #4393Super Member
- Join Date
- Jul 2009
- Posts
- 6,751
- Location
- Georgia - Mt. Vernon by The Store just 5 miles east and right by the big oak tree then to the creek.
Bob
NH - TC-29 , FEL, Bush hog, Bush hog brand finishing mower, Post hole digger, 6' Back blade, sub-soiler, Pallet forks, 20KW PTO Generator , 21 hp Murray Mower
JD -3020 with FEL and a 16 HP. K-Grow Lawn Tractor (bought from K Mart 1994) and runs great !
11-06-2012, 08:00 AM #4394Elite Member
- Join Date
- Jul 2006
- Posts
- 4,198
- Location
- South Central OK
- Tractor
11-06-2012, 08:01 AM #4395Elite Member
- Join Date
- Jul 2006
- Posts
- 4,198
- Location
- South Central OK
- Tractor
11-06-2012, 01:25 PM #4396Veteran Member
- Join Date
- Dec 2006
- Posts
- 2,443
- Location
- Anderson County, TN
- Tractor
- John Deere 4210 FEL BH
It's kind of sad. After we finished building the back porch, I was determined to spend some time on it. The combination of cool temps and a stiff breeze caused me to dress for the occasion. Underneath my coat, in the picture I am wearing a full-body snowmobile suit. I was quite comfortable and enjoyed the entire afternoon parked on my back porch. If you look closely, you can see TBN on the laptop screen.
11-06-2012, 02:09 PM #4397Super Member
- Join Date
- Jul 2009
- Posts
- 6,751
- Location
Bob
11-06-2012, 05:27 PM #4398Platinum Member
- Join Date
- Jan 2012
- Posts
- 502
- Location
- Syracuse and Warsaw, NY
- Tractor
- Mahindra 5530 4wd
Obed, what did you do to get power to the house? I just got sticker shock from the power company. We need to bring PRIMARY line underground to a transformer, then secondary underground to a meter pedestal. Power company wants 8k and they don't provide the underground wire, I have to buy and install in 4" schd 40 pvc, set the transformer pad, and set meter pedestal on my own, above the 8K to the power company. Basically the $8k gets the power across the road, sets the actual transformer and makes the connection. UGH.
Lee
Long road home
Mahindra 5530 w/ FEL, Bushhog 286 cutter, 8' disc, 2 bottom plow, pallet forks, 22' American trailer, geotextile carrier, PHD w/ 12" auger, tooth bar, landscape rake, trailer hitch, broadcast spreader, toolbar, cultipacker, grain drill, and more to come!
11-06-2012, 09:27 PM #4399Veteran Member
- Join Date
- Dec 2006
- Posts
- 2,443
- Location
- Tractor
ENG18LT,
Originally Posted by ENG18LT
Our transformer is sitting on the ground 900 feet from the street. High voltage wire was run inside of conduit from the street to the transformer inside of conduit 4 ft underground. Beside the transformer is our meter pedestal. The pedestal is 100 feet from the house. We ran two 220V lines, each line in its own conduit, from the pedestal to the two breaker boxes in the basement.
The power company provided the wire, conduit and transformer and pulled the wire from the street to the transformer. We dug the trench (we paid our excavating contractor to dig the trench). We paid the power company $5K + our power bill can be no lower than $110/mo for 5 years. If we use zero KW in a month, our bill is still $110. We probably use about $80 worth of KW each month on average so we are paying an extra $30/mo for 5 years to pay for our long power line. The power company did not provide any installation service or materials downstream of the transformer. We had to provide all materials and labor downstream of the transformer with the exception of the power company provided meter that we install in our electrical pedestal.
From your description, I'm not sure how far the transformer will be from your house. You will want that transformer to be as close to your house as possible so you can minimize the length of the expensive 220V lines between the transformer and you house. High voltage primary wire can be smaller than lower voltage lines so you will want the 220V lines to the house be as short as possible.
I hope I answered your question. There is a significant cost associated with being a long way from the street. That's why many farm houses are located very close to the road.
Obed
11-07-2012, 06:59 AM #4400Super Star Member
- Join Date
- Jul 2011
- Posts
- 10,947
- Location
- Yanceyville, North Carolina
- Tractor
- Kubota L4400
The PUPIL who does not surpass his Master, fails his Master.
