Page 469 of 598 FirstFirst ... 369419459466467468469470471472479519569 ... LastLast
Results 4,681 to 4,690 of 5974
  1. #4681
    Super Member Robert_in_NY's Avatar
    Join Date
    Aug 2001
    Posts
    8,545
    Silver Creek, NY
    Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
    Default
    Quote Originally Posted by Obed View Post
    Bob,
    At some point I want to replace the PVC pipes and valves near the filter with all copper. When I get around to that task, I may add a 2nd filter.
    <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=300323"/>
    Obed
    While I'm not a fan of pvc generally is there a particular reason you want to replace it? If it isn't leaking I would leave it alone.
    God must love stupid people; He made so many
  2. #4682
    Elite Member MotorSeven's Avatar
    Join Date
    Aug 2005
    Posts
    4,033
    NE TENN (Hancock Co)
    Kioti DK40SE Hydro
    Default Re: At Home In The Woods
    17gmp is good & I agree, if you keep getting debris, raise your pump at least 10'.
    2008 KIOTI DK40Se Hydro
    1978 Sling Blade/wood handle
  3. #4683
    Elite Member Obed's Avatar
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    John Deere 4210 FEL BH
    Quote Originally Posted by MotorSeven View Post
    I should clarify. The pump is 17 gpm. The well when dug supplied about 10 gmp.
    John Deere 4210 (28 HP) FEL, BH, 6' Box Blade, Loader Forks
    At Home In the Woods
  4. #4684
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    Quote Originally Posted by Robert_in_NY View Post
    Robert,
    The pvc stop valves have not been reliable and have had a tendency to leak when using them. Thus, we hesitate to operate them. I would like to replace the PVC valves with nice dependable copper stop valves. So when I replace the valves, I might as well get rid of all the plastic downstream of the pressure tank.
    Obed
  5. #4685
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    I ran a couple Cat 5 network wires from the office to other rooms in the house, one to the LR and one to the guest bedroom. Wireless network connections are slower and less reliable than hard-wired connections. I eventually want to put a patch panel in the hall closet and run all the network wires to that central closet. So the two wires I just ran are somewhat "temporary".
    Running wires through the exposed trusses in the basement is pretty easy but still takes a little time. When we built the house, I installed empty low voltage boxes in all the rooms and left a pull string running through the wall and subfloor.
    At Home In The Woods-img_0130-jpg At Home In The Woods-img_0133-jpg At Home In The Woods-img_0135-jpg At Home In The Woods-img_0136-jpg
    Wiring the jacks just requires matching the wire colors to the color coded wire terminals.
    At Home In The Woods-img_0137-jpg At Home In The Woods-img_0138-jpg At Home In The Woods-img_0140-jpg At Home In The Woods-img_0143-jpg At Home In The Woods-img_0144-jpg
  6. #4686
    Join Date
    Aug 2005
    Posts
    4,033
    Kioti DK40SE Hydro
    I pre wired too and bought the Cat tool w/connectors. Right now we are all wireless & it's fast enough for us, so I'm not going to route or hook cat wire up unless I really need it.
  7. #4687
    Elite Member CurlyDave's Avatar
    Join Date
    Dec 2005
    Posts
    4,480
    Grants Pass, OR
    JD TLB 110
    Rick,
    The well is 300 ft deep. The pump is set at 280 ft deep and is rated at 17 GPM.
    We talked to the well driller and also to the pump installer. The well driller is major country and can be tough to understand. He said he had had several customers who are also reporting issues with sand/grit in their water. The well driller and the pump installer both said to watch it and if it continues, they recommend that the pump be raised 20 ft higher in the well.
    Obed
    Obed:
    Raising the pump is one tried & true method of reducing sediment in well water.
    There are two other things to look at.
    The first is the possibility that the clay seal at the top of your well is leaking and that ground water is entering the well. This usually happens in the wet season and can only be fixed by replacing the seal. Raising the pump is far less expensive and is the first thing to try. If it is neither the pump height nor the seal, one last chance is to pack the well with gravel. This is an extreme step and is irreversible. If it doesn't work, you are out of other chances. My well driller says it is very effective most of the time, but I have not had the courage to try it.
    40 Acres on a hill - fantastic view. JD 110 TLB, 4-n-1, 12" bucket, 18" bucket, Addington thumb, rock bucket (doubles as root grapple)
    Not only do we not understand the universe, if someone explained it to us, we would not know what he was talking about.
    Isaac Asimov
  8. #4688
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    Rick,
    I went overboard at our previous house and hardwired Cat5 and cable to at least two different walls in every room in the house. In our new house, I decided I would wait to run wires until I actually have a need. Wireless in our house is adequate for most internet access. If I need to connect a device to our network that does not have a wireless adapter or wireless is too unreliable or slow, then I will run a wire.
    Obed
  9. #4689
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    Quote Originally Posted by CurlyDave View Post
    Obed:
    CurlyDave,
    What is a "clay seal" and how can it be fixed? Raising the pump 20' will cost us approximately $150.
    Obed
  10. #4690
    Join Date
    Aug 2009
    Posts
    235
    NW Georgia
    Kubota B3200
    "Since our filter is so easy to flush, cleaning it out every so often isn't a big deal as long as the sand isn't causing other problems (i.e. ruining our water heater, etc.)."
    Obed,
    We have clay silt in our well (NW Georgia) and we had to get a large back flushing filter. It is basically a water softener several layers of aggregate instead of resin beads. It works well and we never have to touch it. However, we only got 10 years out of our first pump because the silt slowly ground the impellers away. I can imagine what sand would do!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
