Page 483 of 598 FirstFirst ... 383433473480481482483484485486493533583 ... LastLast
Results 4,821 to 4,830 of 5974
  1. #4821
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Default Re: At Home In The Woods
    Obed, I have a shelf welded to the back of my boxblade with a hole for a ball. You could just as easily weld a receiver on top of the shelf. This will get you nearly level and even allow you to easily drop the hitch ball below the hitch and raise it up to hook up and disconnect.
    Attached Thumbnails Attached Thumbnails At Home In The Woods-1-hitchpad-jpg
    Jim
  2. #4822
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Or, there is the other end of the tractor
    Load-Quip 2in. Class 3 Hitch Receiver Clamp with Lift Ring, Model# 29211766 | Bucket Accessories| Northern Tool + Equipment
    $139 seems pricey but maybe there are less expensive ones out there.
  3. #4823
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    I weld hitch tubes on everything I have. Its cheap and handy. The one I use the most is the one on top of my FEL bucket.
    Chris
  4. #4824
    Super Member buckeyefarmer's Avatar
    Join Date
    Jun 2005
    Posts
    7,705
    MD
    Kubota L3940 L5030 MF205-4
    I have one that mounts on my pallet fork frame.
    2010 - L3940HSTC, QA FEL, BH92
    2010 - Husqvarna YTH24V48LS (the other orange)
    2005 - L5030HST,QA,FEL
    198x - MF 205-4
    1990 - Wheelhorse 212H
    2017-ratchet rake, 2008-KK Tiller, 2006-Pallet forks, 2002-Carryall, 2000-PHD, 1999 - Trailer, 1999-6' rotary mower, 1999-cultivator, 1998-KK Finish Mower, 1998-Blade,1992 - Troybilt tiller, 2 wheel barrows, assorted gardening tools,
    http://www.tractorbynet.com/forums/r...life-farm.html
  5. #4825
    Veteran Member PhysAssist's Avatar
    Join Date
    Aug 2011
    Posts
    2,387
    Upstate NY- see the BIG lake- look just below it...
    Kubota B2320
    Quote Originally Posted by jinman View Post
    Or, have him weld the shelf/flange just like Jinman's [with an appropriate hole drilled for the threaded shaft of the trailer ball] for you at whatever height will work best for you when your blade is at cruising altitude, unless there is something else you're likely to want to attach to the BB or scraper, then have him weld a section of 2" hitch tube onto it at that magical height.
    Or go whole hog and have him plasma cut a square hole into the back of the blades and put the tube through it, then weld it to both faces of the blade [with gussets for strength].
    JMHO,
    Thomas
  6. #4826
    Elite Member Obed's Avatar
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    John Deere 4210 FEL BH
    Jim,
    I really like your idea. I have forwarded the box blade picture with your modification to the welder. He is working up an estimate. Depending on price, I may get the scraper blade and the box blade both modified so I can pull the trailer using them.
    Thanks,
    Obed
    John Deere 4210 (28 HP) FEL, BH, 6' Box Blade, Loader Forks
    At Home In the Woods
  7. #4827
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    I would also like to fix the 3PH pins on the box blade. One of them is in particularly bad shape; it is loose and is bent. I am talking to the welder to see if he might replace them. I doubt I can get the nut off. Also, it looks like the hole the pin fits through is too large.
    At Home In The Woods-img_0342-jpg At Home In The Woods-img_0343-jpg
  8. #4828
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Quote Originally Posted by Obed View Post
    You can buy new pins. A 4-1/2" angle grinder will cut the nut easily, if you don't have one, it's a great addition to the arsenal that will get used again. The hole size looks like maybe someone changed to a lower CAT size? There might be bushings easily found to solve that. Tractor And Skid Steer Attachments For All Tractor And Skid Steer Manufacturers would be a place to start.
  9. #4829
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Here is a handy chart for 3pt pin sizes. That may help to know what to look for. Page 10 shows conversion bushings. You may be able to find pins with a built-in conversion step-up in the portion that fits through the hole in the implement arm.
    http://www.ricksagparts.com/3-Point_Linkage.pdf
  10. #4830
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    Quote Originally Posted by dave1949 View Post
    Thanks Dave. You may have steered me onto the right path. I suspect you are correct in that my box blade originally had a larger 3PH Cat size pin and somebody replaced the original pin with a smaller diameter Cat 1 pin. The bushings I have found for stepping down from a Cat 2 to a Cat 1 are all to long. If I could find a Cat 2-1 conversion lower link pin, I think that would work. The pdf link you provided at ricksagsparts.com showed a conversion link pin, but I don't know how to order it.
    I'll have to do some digging. I might just end up replacing the bent pin with another Cat 1 pin. It's not idea but might be good enough.
    Obed
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
