Page 492 of 598 FirstFirst ... 392442482489490491492493494495502542592 ... LastLast
Results 4,911 to 4,920 of 5974
  1. #4911
    Gold Member
    Join Date
    Aug 2007
    Posts
    348
    southeastern PA
    Kubota BX2200, Gravely mower
    Default Re: At Home In The Woods
    and grease all fittings on the tractor and mower deck (pulleys). Check if the steering has a fitting as my Gravely does and it really makes a difference in the steering. I spray chain lube on my springs to prevent rust.
  2. #4912
    Elite Member Obed's Avatar
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    John Deere 4210 FEL BH
    I used my Dremel with a lawnmower sharpening attachment to sharpen (sort of) my lawnmower blades. The Dremel is really undersized for the task. The blades did end up kind-of sharp with some spots obviously still needing attention. Some guys have mentioned sharpening the blades with their angle grinders. I wonder how well that works?
    At Home In The Woods-img_0389-jpg
    John Deere 4210 (28 HP) FEL, BH, 6' Box Blade, Loader Forks
    At Home In the Woods
  3. #4913
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    Welder and Accessories Arrive!
    At Home In The Woods-img_0390-jpg At Home In The Woods-img_0401-jpg At Home In The Woods-img_0402-jpg
  4. #4914
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    I would be interested in a bench grinder for sharpening the mower blades, etc. Is there anything in particular I should look for when buying?
  5. #4915
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    Quote Originally Posted by clemsonfor View Post
    From your description of the state that the pulley and arm was in I think you found your problem. I too would replace the spring and put the old one in the spare parts bin for an emergency.
    clemsonfor,
    I ordered the spring and bought a belt. The spring was $7. Yikes!
    Obed
  6. #4916
    Platinum Member ENG18LT's Avatar
    Join Date
    Jan 2012
    Posts
    616
    Syracuse and Warsaw, NY
    Mahindra 5530 4wd
    Quote Originally Posted by Obed View Post
    Yeah Baby! Get some scrap and start to play, I mean practice. If there is one piece of advice to offer it would be make sure you have bare metal, get it to shinny metal first, even if it is new stock. Your welds will be much nicer.
    I have had better luck putting the blade in a vise and then using a 4" grinder.
    Good luck.
    Lee
    Long road home
    Mahindra 5530 w/ FEL, Bushhog 286 cutter, 8' disc, 2 bottom plow, pallet forks, 22' American trailer, geotextile carrier, PHD w/ 12" auger, tooth bar, landscape rake, trailer hitch, broadcast spreader, toolbar, cultipacker, grain drill, and more to come!
  7. #4917
    Join Date
    Jun 2006
    Posts
    142
    Michigan
    Allis Chalmers B
    Default
    Also my rule of thumb when I weld in a garage. I stay 30 min after I am done welding to make sure I didn't start a fire some were.
  8. #4918
    Elite Member dstig1's Avatar
    Join Date
    Apr 2010
    Posts
    2,844
    W Wisc
    Kubota L5240 HSTC, (Kubota L3130 HST - sold)
    Grinders are good for the rough stuff, but a file is a lot easier to control for getting the edge more even. I use both as needed. I sometimes go in between my bench grinder, angle grinder and die grinder depending on what will fit best.
    For bench grinder, you will find most in 6" or 8" size. Bigger is better in general (larger diameter wheel makes a less dished grind - flatter). A lot of times the wheels that come with them are the hard gray ones (silicon carbide?) that are really made for rough grinding, not sharpening. You can buy better wheels if you are picky about that. Lots of woodworking and metalworking shops will have better wheels for sharpening cutting tools.
    -Dave
    "Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
    L5240HST, QA, 824 Loader, 48" Forks, 48" Grapple, rear blade, box blade, landscape rake, Ancient Farmi Skidding winch
    Trailer - 10k/16' twin axle w/elec brakes
    2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
    My house build blog: http://stighouse.blogspot.com/
  9. #4919
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    Wait a minute Dave! Didn't you guys just talk me into buying a welder? (Not that I needed much convincing!) My wife says you guys just want some entertainment watching what we all know will be my feeble attempts at welding. She might be onto something.
    Obed
    That's why you don't post the bad stuff. Post your first decent weld then a pic of you destroying the metal to see if it holds!!
    Well, I posted our house build, the good, the bad, and the ugly. I don't think it will hurt my pride any more to post my welding attempts.
    Trust me as attentive to detail as you are, you will be welding in less than a few hours after you watch some vids.
    I picked up a welding book the from the library. The book was written in 1979 which seems pretty old to me. I don't know how much has changed in the welding field since then. The book has a chapter on Mig welding. There was barely a paragraph on flux core welding. I'm guessing that much of what is written about Mig welding will apply to flux core (with the exception of the gas part).
    Obed
  10. #4920
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    Quote Originally Posted by ENG18LT View Post
    Lee,
    Yes, I need to find a place to get some scrap metal. I'm not sure where to look.
    Obed
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
