Obed,
A couple of things re: your 'new' old mower. First, you're getting there, and a 24 year old mower is made of better, thicker, stronger materials than one made today. The blades need to be SHARP! As guys have stated, you want them to CUT the grass, not mash it down or shred it, because that makes your entire lawn prone to disease. And you want to cut only 1/3 of the length of the grass at each mowing or disease, drought and sun can and will kill it. Best lawn is a properly watered and cut lawn that can breath, doesn't have a thatch build-up and is healthy due to regular cutting and watering, from the sky or your sprinkler.
I was surprised when I took my blades in from my 61" Scag Wildcat and had the local Scag dealer look at them. Before I even got them placed on the counter he said: those are bent!
I said: What?!:confused2:
He said: you need 3 new blades!!! I said: 'do you have them and how much?' He said: a lot of $, (he, he,:laughing
and sold me three blades, and a few other things.
My point is that I hadn't looked at the blades as far as whether they were straight or not. And, bend blades do NOT cut properly, leave weird grass contours on the lawn, and most of all if the blades are not SHARP, Straight, and BALANCED, on the little pyramid balancer, they will do damage to the spindle bearings and those will cost way more than a mere pulley. Remember the price of the idler arm spring!
Your Kubota mower will thank you for cleaning off the deck after every cutting to keep the belts and pulleys and spindle bearings from overheating due to their not being able to cool properly from all the grass, leaves, etc. from blocking air flow.
On the grease gun storage I wrap the end of the nozzle in a plastic baggie and use a rubber band to secure it so it will not leak. Then I put it on the wall in the grease gun hangar I got at TSC for the purpose of hanging a grease gun on the wall. Or you can use a nail and put it between the handle and pump arm and basically get the same result.
For your BB pin repair I would say you could use an oxy/actelene torch setup complete with hoses, tanks, roll around cart, and goggles, gloves, etc., Oh, yeah, a bench grinder with wire wheel and stone wheel too! Oh, and a bench vice too, for sure. And the little balancing pyramid to round out your next purchase! Look at it this way, if you bundle it, then the wife can't complain as often...:laughing:
Actually you could MAYBE use a small propane torch, self igniting model, with a MAPP gas tank -(yellow tank) (which is like 5 times hotter than propane, to heat up the bent flange to then bang it straight with a sledge hammer). And you might be able to make some bushings, to fit the pins to the oversized holes too.
I'm not a metal guy, so someone else with more knowledge on this subject could comment on whether that might work, or not.
