Page 507 of 598 FirstFirst ... 7407457497504505506507508509510517557 ... LastLast
Results 5,061 to 5,070 of 5974
  1. #5061
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Default Re: At Home In The Woods
    You can extend your welder's power by putting a 45* chamfer on the edge, the upright piece in your practice pics. That allows you to get down into the joint a bit deeper on the first pass. Then you would build up on that weld.
    Your tacks looks like you had aimed too much at the upright piece, which will heat/puddle faster than the flat piece. Something to compensate for.
  2. #5062
    Super Member clemsonfor's Avatar
    Join Date
    Sep 2009
    Posts
    8,592
    Greenwood Co., SC
    Yanmar YM2000
    YEa something is not right there with your technique? It should atleast penetrate something? I have welded 1/4 several times and you can melt the corners of the stuff down easy, and again i have the same welder??? Try what Dave said, grind that verticle peice on the end that your joining at a 45 deg angle, kind of like your making a blade on the end you want to join. This will then thin that end out and aim into that crack that is formed when you stand the verticle onto teh horizontal ppiece. I think DAve hit it on the head and i am just repeating what he said in mor words.
    But i agree looks like you aimed to high on the verticle, maybe had the torch to far away and did not move it, causing the weld metal to just pile up on it self??
    EDIT: I am at work but i looked for some pics of some repairs i have made to my bushhog and could not find any on my phone or my work PC. I may have some at home or on the SD card that use to be in my phone. I will look, i cant take any right now as the tractor and hog is at the farm 3 hours away.
    As far as the Boxblade your probably going to have to take your grinder and grind out the crack on it so that there i like a "V" where the crack is. You sure its 1/2 steel?? yea just looked at a ruler i bet it is 1/2 inch.
    Now that i look maybe i was welding 3/16 steel?? But even that i could melt it no problem so i would thing that i could melt 1/4 pretty easy. I have welded some big nuts on an implement as a spacer and i bet it was 1/4 inch steel there and it melted no problem.
    YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
    1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
    1991 Javalen 17ft w/same year 150 Johnson GT
    Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
  3. #5063
    Elite Member MotorSeven's Avatar
    Join Date
    Aug 2005
    Posts
    4,033
    NE TENN (Hancock Co)
    Kioti DK40SE Hydro
    Obed, that's almost zero penetration....not hot enough. How may amps is your welder and do you have it set on "high or Max". Also, do not run it on an extension cord unless it's a 10 gauge and shorter then 25'.
    2008 KIOTI DK40Se Hydro
    1978 Sling Blade/wood handle
  4. #5064
    Platinum Member catdozer's Avatar
    Join Date
    Sep 2011
    Posts
    510
    Indiana
    Bobcat CT235
    Default
    You have your wire turned up way to much. Turn down the wire and turn up the heat. You are just melting the wire instead of melting the metal.
    Bobcat CT235 with Deere Imatch, And a very bad addiction of attachments
  5. #5065
    Join Date
    Apr 2011
    Posts
    740
    SW Ohio
    John Deere 3032E
    agree with catdozer
    you need the wire speed down to maybe half as to have your amperage melt the metal and wire is just a filler
    looks to me like you just melted the wire with no melting of the parent material
    any weld prep should have a chamfer so you penetrate the parent material and your wire is a filler
    you should be able to do 1/2 steel as long as you have a chamfer v ground almost thru and might take 2-3 passes
  6. #5066
    Join Date
    Sep 2009
    Posts
    8,592
    Greenwood Co., SC
    Yanmar YM2000
    Another trick to weld something that is to thick for a welder is to preheat it, but with out an OXy torch you cant get to hot but anything would be better than nothing, you could try and heat with mapp gass but i think that thaat weld is to longs and your torch woudl not get hot enough to do much good, maybe if you heated one spot and tacked it and kept tacking?? But i think you will get it you just have to keep messing with it.
  7. #5067
    Join Date
    Feb 2012
    Posts
    732
    Germanton, NC
    Kubota MX5100F IH McCormick Farmall 140, Massey Ferguson 135
    As a former weld tester for the Navy, given proper prep of the two pieces and proper technique, one can weld very thick material with multiple passes. I will give +1 on beveling your stock, upping he amperage and slowing your wire speed.
    Since this is a practice weld, I suggest welding the outside of the angle first. The other thing is to make sure the gap between the two pieces is as small as possible.
    Keep trying, I still make some ugly welds from time to time.
  8. #5068
    Elite Member Obed's Avatar
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    John Deere 4210 FEL BH
    Quote Originally Posted by catdozer View Post
    Quote Originally Posted by Beltman60 View Post
    agree with catdozer
    I have two settings, current (high or low) and wire speed. The current was on high. The wire speed was on the fastest setting. Slowing down the wire speed makes sense. I'll try some stuff tomorrow. The welder manual says to increase wire speed if you are not getting penetration. That would seem backwards to me but the manuel is clear about that. I'll try some practice beads on flat 1/4" metal without trying to join anything together. Once I figure out how to get some penetration, I'll try to join two thick pieces.
    Obed
    John Deere 4210 (28 HP) FEL, BH, 6' Box Blade, Loader Forks
    At Home In the Woods
  9. #5069
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    We added a grab bar in the shower for my mom.
    At Home In The Woods-img_0472-jpg At Home In The Woods-img_0473-jpg At Home In The Woods-img_0500-jpg
  10. #5070
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    I bucked up a dead red oad tree that fell over.
    At Home In The Woods-img_0475-jpg At Home In The Woods-img_0476-jpg At Home In The Woods-img_0477-jpg
    I got some poplar from the log stack.
    At Home In The Woods-img_0480-jpg
    This guy was sunning himself on a log.
    At Home In The Woods-img_0479-jpg
    I started working on the "roof" for the round stack.
    At Home In The Woods-img_0488-jpg At Home In The Woods-img_0490-jpg At Home In The Woods-img_0491-jpg
    I split some pieces into "shingles" and started positioning them around the top of the stack.
    At Home In The Woods-img_0492-jpg At Home In The Woods-img_0493-jpg
    I still need split ans stack some more "shingles" on the top but this stack is close to being finished.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
