If you recall, I tried to tack weld two 1/4" thick pieces of steel together without success. My welds were not penetrating the metal. My flux core welder was set to High current with the wire feed on the fastest setting.
So last night I practiced laying some beads on the 1/4" thick metal using various wire feed speeds. I rechecked my welder manual and a welding book. Both indicated that to get more penetration, I should increase the wire feed speed. The book said (for a Mig welder), increasing the wire feed speed will increase the current which will improve penetration. However, my failed tack weld attempts last time were done at the highest wire feed speed which just piled up the weld material on top of the metal without good penetraction.
I cleaned off my metal with the angle grinder.
I then made some new practice beads. My first bead on the bottom of the picture below was made using the fastest wire feed (9.5 out of 9.5). Penetration was not good. The second bead from the bottom was made using a very slow wire feed speed (2 out of 9.5). Penetration was much better (contrary to the advice in the welder's manual). The third and fourth beads from the bottom were made using a middle wire feed setting (5 out of 9.5). The 5 speed setting seemed to make a good bead.
Below you can see the penetration.
I set my welder at 5 out of 9.5 and attempted more tack welds. My first new tack welds did not penetrate.
I cleaned off the bad welds and tried again.The first weld got good penetration. Unfortunately, while welding the second tack weld, the metal pieces pulled apart leaving a gap.
I cleaned off the metal and tried again. The first tack weld penetrated ok.
The second tack weld did not penetrate.
This time I did not clean off the existing tack welds and just welded another tack weld beside the previous weld. This one penetrated ok but resulted in a lot of extra metal.
This is where I stopped. Next time I'm going to try to finish welding the two pieces together. I may lower the wire speed from 5 to maybe 2 or 3 on my first attempt.
