Page 513 of 598 FirstFirst ... 13413463503510511512513514515516523563 ... LastLast
Results 5,121 to 5,130 of 5974
  1. #5121
    Gold Member TnWV's Avatar
    Join Date
    Apr 2008
    Posts
    297
    Liberty,WV - Putnam Co.
    2003 Zetor 4341 w/FEL, 1970 MF 150, 2012 JD X530
    Default
    Obed,
    I have followed your thread from the very beginning, and just wanted say that you ave a absolutely beautiful home/property, and a remarkable take on life in general. I have learned a tremendous amount from this thread and thank you for taking the time to post all of it and for continuing it.
    I believe you have mentioned before that your roof pitch is an 8/12. Is this for all your roof lines, or just the main? How wide is your main house? I ask this because the roof pitch and roof detail are the last items up for debate in my own house plans. Do you have upstairs space or are the dormers just decorative/skylights? I like the way your dormers look in your recent pictures, and originally didn't think dormers would look right on an 8/12 roof. Yours looks fantastic?
    Tony
    1975 MF150
  2. #5122
    Super Member clemsonfor's Avatar
    Join Date
    Sep 2009
    Posts
    8,550
    Greenwood Co., SC
    Yanmar YM2000
    Default Re: At Home In The Woods
    Quote Originally Posted by Obed View Post
    I'm enjoying how green things are with all the rain we've had this spring.
    Attachment 318006 Attachment 318008
    I really like this view. The garden area can be seen in the background.
    Last fall we poisoned and reseeded much of the lawn that had weeds in it that we suspect came from the straw we used when we first planted the grass. Now we have a bunch of clover in the grass. I suspect the grass seed we bought had lots of unwanted clover seeds in it. Can't win for loosin'! You cant really see the clover in these pictures because the grass was freshly cut. However, the clover is there and turns much of the lawn white as the clover flowers.
    Dont forget the turkeys you have all over your yard!! They love clover, they could of brought the seed in and pooped it into your yard. Most of the ones i have seen cleaned or the 2 i have cleaned myself (not a good hunter or either i dont have good enough places) have the actual clovers in them not the flowers but the may eat flowers too? But they pick up seeds off the ground and have amazing eyes so i guess they can see the seeds which are the size of a seed tick.
    But i agree 24d kills all broadleaf weeds and does not harm grass species. So it will kill your clover, dandilions and other weeds.
    YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
    1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
    1991 Javalen 17ft w/same year 150 Johnson GT
    Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
  3. #5123
    Gold Member
    Join Date
    Sep 2008
    Posts
    339
    Central Virginia
    +1 on the 2,4d
    I've been using it + a liquid fertilizer in the spring for a few years now, and its really helping to keep the clover problem in check.
  4. #5124
    Elite Member Obed's Avatar
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    John Deere 4210 FEL BH
    Quote Originally Posted by srossman View Post
    you can always spray your lawn with 2-4-d to kill off the clover. I think that it takes at least two growing seasons to get a lawn looking nice. I redid half my lawn last spring, and this year, it looks better, but I still have some clover and other weeds that I'll be working on getting rid of through the year.
    Quote Originally Posted by clemsonfor View Post
    Quote Originally Posted by jdonovan View Post
    +1 on the 2,4d
    We may have to check out the 2-4-d. Thanks for the tip.
    John Deere 4210 (28 HP) FEL, BH, 6' Box Blade, Loader Forks
    At Home In the Woods
  5. #5125
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    Quote Originally Posted by TnWV View Post
    Obed,
    Tony
    Thanks for the kind words Tony. The main roof lines are 8/12 pitch. The dormers, front porch, and garage are 10/12. I don't ever have to walk on any of the 10/12 pitch roofs. I do need to go on the 8/12 pitch roof, for example when I clean the chimney and the dormer gutters on the back side.
    When we were designing the house, the house designer was trying to get us to build at minimum a 10/12 roof or steeper. So we put some blocks under a piece of plywood on the grass and simulated 10/12 pitch. I could not walk on 10/12 pitch. I was able to walk on 8/12 pitch so thats what we went with. 8/12 pitch is still a steep roof.
    The dormers are real. Our upstairs could be finished living space but we only plan to use it as an attic. Our house, including the garage, is approx. 75' x 40' give or take.
    IMO, the roof lines on many newer houses these days are too steep, too complex, too expensive, and too hard to maintain. Asthetics have their benefits but they shouldn't completely ignore practicality.
    Obed
  6. #5126
    Join Date
    Apr 2008
    Posts
    297
    Default
    Obed
    Thanks for such a detailed answer. I actually went back to the beginning of this thread and read the first 10 pages last night. I hope to break ground in the next month, but I am still waiting on material and sub pricing before finalizing my construction loan. The current cost of lumber is very discouraging!! It does seem to be dropping some though.
    My original plan has a 12/12 roof (cape code with 3 dormers). I like the look, but the cost is just too much for nothing more than future space. We have three bedrooms on the main floor and a full basement. I talked to the truss company today about going with a 9/12 over the house and 10/12 over the garage, still giving a nice sized bonus room over the garage but only attic space over the main house. The overall cost difference should be substantial.
    Sorry to derail your thread with my details, I'll start a new thread soon to share my building experience as so many others have been kind enough to do.
    1975 MF150
  7. #5127
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    Tony,
    Your future house sounds similar to ours. We did a 1 1/2 story with an unfinished upstairs to give us the option to add square footage if we ever wanted to sell the house. Otherwise, we would never be able to sell it for the building cost. Someone willing to pay for the 30 acres of woods would probably want a large house. We built the unfinished basement to provide the option for a mother-in-law suite. However, I doubt we'll ever use it for that so that was a big expense without a monitary payback. I do really enjoy having the basement as a shop but it is an expensive way to build a shop. Also having the "shop" in the basement limits when I can make noise down there due to waking people up.
    I love our house and love living here. However, sometimes I question the wisdom of spending so much for a place to live. I'm sure we could have cut costs in several places.
    Are you going to be the general contractor? Since you are going to build, there's some stuff in this thread that might help you not make some of the mistakes we made. I've been fairly open about showing the "oops" we encountered. You'll also get a good idea about what dealing with subs can be like.
    I do have one suggestion before you hire any sub. Please don't miss this suggestion. During the bid process, ask every sub/owner what percentage of the time he will actually be on site and working with his hands. Don't hire the subs who give you a vague or unacceptable answer. With very few exceptions, the subs with owners that were never on site provided noticeably lower quality than the subs/owners who did the work themselves or were on site working with their employees.
    Obed
  8. #5128
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    Quote Originally Posted by dave1949 View Post
    You can buy new pins. A 4-1/2" angle grinder will cut the nut easily, if you don't have one, it's a great addition to the arsenal that will get used again.
    Dave,
    I have to say THANKS for suggesting the angle grinder. I didn't know anything about them until you suggested it. I wish I would have had one a long time ago.
    Last night I sharpened my maul with the angle grinder.
    At Home In The Woods-img_0579-jpg At Home In The Woods-img_0580-jpg
    Obed
  9. #5129
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Dave,
    Obed
    You are welcome. The maul looks ready for work.
  10. #5130
    Join Date
    Apr 2008
    Posts
    297
    Default
    Tony,
    Obed
    My situation is very similar indeed. I am willing to give up the upstairs, but the basement is a must. This will be my forever home and I want the extra space for any future need that may come up.
    1975 MF150
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
