Aight...it's been a VERY productive month here on The Old Goat Ranch...and hot as a anvil, just the way I like it...
For those of you unused to a Central Texas Summer, get out a hair dryer, turn it to the highest setting, point it at your face and then empty the bag from your vacum cleaner into it...it is a weak substitute for the real thing, but you'll get the gist of it...
Working outside takes a little planning...
Starting at sunup is the only way to go...hourly breaks for water and finishing up the days activities by about 2:30 has been working out pretty well...by then the heat is climbing past the 100f mark, shade is at a premium and it allows plenty of time for the enjoyment of that most delightful of habits...SIESTA...as well as afternoon trips for supplies...
...I moved South because of my dislike of cold...so I try not to whine too much about High Summer....but when the thermometer in the shade under the barn roof hits 100f, I do lose a bit of enthusiasm...
Heat or no heat, my helper and I just kept a steady pace and got all of the sheet steel and trim up, ...leak tested the roof...fixed the leaks...(!)...and those few screws just needed to be torqued correctly....best of all, the darn thing is starting to look a lot like the plan......now all I need is a month at "work" to recuperate from my hobbies...
Enjoy the pics, I know I sure am...
And as always....BE CAREFUL OUT THERE...
T
