nickel plate
When I designed and built my 1280 s.f. shop, I didn't have the 5-1/8"x15-1/2" glulam beam figured in to the framing as it was not needed for the roof truss design. It was added after the roof was completed when I got the bright idea to some day install a moveable chain hoist and use the beam as a track. Before I set the beam in place, I screwed a 5" wide 1/4" steel plate running full length into the top of it to act as a skid and protect the wood surface. That was five years ago. A couple of weeks ago I finally got busy on the layout and construction of the traveler and the pully system.
The traveler is made up of 2x6s glued and sandwiched between layers of 3/4" plywood. The side guides are 2"x2"x3/16" angle iron with the tips bent out like a ski tip to avoid digging into the sides of the beam while being moved. There are two vertical through bolts that secure each piece of angle iron and the two grade 43 yoke chains which lay over the top of the traveler and attach to the chain hoist. An eyebolt on each end secure the two winch cables. On the base of the traveler I have screwed in a steel plate that the unit slides on. Also, both steel plate surfaces have been lightly greased.
Two (on sale for $16.99) HF 1000# hand winches work effortlessly to move the traveler each direction. I built the system to just move the hoist over to whatever is going to be lifted and when done, cranked back over to one end of the beam for out of the way storage.
The two sets of wire rope blocks are made by Tuf-Tug and sold at TSC. 5/16"x3" lags secure the 2x6 D.F. block bases.
I'm sure glad this is over with and actually works better than I expected because it took a lot of scary-to-me high ladder work.
