Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 50
  1. #1
    Super Member bindian's Avatar
    Join Date
    Feb 2007
    Posts
    6,955
    Willis, Texas
    Mahindra 6520 4WD
    Default Cedar post fence
    A couple of months ago, I asked (in the South forum) where I could get cedar posts cheap. Lee (Weldingisfun) offered to let me take all I could cut down and trim. I will be using these cedars for a fence from my barn along my driveway and curving past the pond. Back on April 10th I was at his Goat Ranch and we worked hard. I cut the trees down and he drove his tractor and we both trimmed. Hard thing about it was we had to chain and pull the trees off a draw over a stream. We would have had a lot harder time loading my trailer if it was not for Lee's Mahindra 4500 and loader. We sat the loader bucket over a bunch of logs and wrapped a chain around them and the bucket to sling the logs to my trailer. Here are a few photos from unloading the trailer this afternoon and stacking the cedar. I counted 45 posts anywhere in size from 12 inches down to 4 inches and about a dozen braceing posts. I used the Big RED Beast to unload without breaking a sweat.
    hugs, Brandi
    Attached Thumbnails Attached Thumbnails Cedar post fence-4-23-10-unloading-cedar   Cedar post fence-4-23-10-stacking-cedar   Cedar post fence-4-23-10-six-twelve   Cedar post fence-4-23-10-cedar-logs
  2. #2
    Elite Member CurlyDave's Avatar
    Join Date
    Dec 2005
    Posts
    4,480
    Grants Pass, OR
    JD TLB 110
    Default Re: Cedar post fence
    A lot of posts there.
    Two questions:
    1. Do you debark those before using or do you use them as is?
    2. Do you burry the big end or the small end?
    40 Acres on a hill - fantastic view. JD 110 TLB, 4-n-1, 12" bucket, 18" bucket, Addington thumb, rock bucket (doubles as root grapple)
    Not only do we not understand the universe, if someone explained it to us, we would not know what he was talking about.
    Isaac Asimov
  3. #3
    Join Date
    Feb 2007
    Posts
    6,955
    Willis, Texas
    Mahindra 6520 4WD
    Quote Originally Posted by CurlyDave View Post
    Two questions:
    CurlyDave,
    I will debark them. I salvaged a cedar log from Hurricane Ike debris back in 2008 and the bark is falling off of it now. Why would I want to bury the small end?
    hugs, Brandi
  4. #4
    Join Date
    Dec 2005
    Posts
    4,480
    Grants Pass, OR
    JD TLB 110
    Brandi:
    Somewhere I read about people installing them small end down for a reason which escapes my tired old brain at the moment.
    I was hoping you might know.
    Isaac Asimov
  5. #5
    Join Date
    Dec 2007
    Posts
    1,461
    Eastern Ontario
    Jinma 284(Spirit fel), MF 135 (MF200 fel)
    I pile the posts to cure for a year or so and then the bark comes off with little effort. I have put little and big ends in the ground -- not sure it really makes any difference -- just depends on what fits in the post hole
  6. #6
    Join Date
    Feb 2007
    Posts
    6,955
    Willis, Texas
    Mahindra 6520 4WD
    Quote Originally Posted by studor View Post
    I got 2 or 3 of my Dad's draw knives. They peel bark most easily.
    hugs, Brandi
  7. #7
    Veteran Member weldingisfun's Avatar
    Join Date
    Dec 2006
    Posts
    1,751
    West Bell County, Texas
    Mahindra 4500 4WD w/FEL, and Scotts S2048 lawn tractor
    The guys around here who work with cedar logs commercially use a 3000 psi pressure washer to debark. If you have access to one, you might give it a try. Don't have one myself so I can't testify to their effectiveness.
    Glad you got it all home OK.
  8. #8
    Join Date
    Feb 2007
    Posts
    6,955
    Willis, Texas
    Mahindra 6520 4WD
    Quote Originally Posted by weldingisfun View Post
    Thanks Lee! It sure was easier unloading then loading. Only problem I had was getting all the logs with the big ends in the same direction. All my trees slowed that process. I rent a pressure washer every few years to clean off my wood deck and anything else that needs it. I was going to rent one this summer, but sooner now.
    hugs, Brandi
  9. #9
    Join Date
    Nov 2005
    Posts
    2,314
    Casey County, Kentucky
    Years ago I hauled Atlantic White Cedar posts out of Canada into New York state for farm and vinyard use. The mill in Canada would put a point on the butt end (kind of like a big pencile sharpener, lol) and leave the bark on. There were two sizes, one about two or three inches or so and the other five or six or so.
    I would think the heavier butt end down would be best for a good anchor. That is the only way I ever saw it down, pounded or drilled.
  10. #10
    Veteran Member mikim's Avatar
    Join Date
    Feb 2001
    Posts
    2,416
    Paige Texas
    NH TC45
    I've used both a draw knife and press washer to debark my cedars....can't say which I prefer ...bit of a toss up. The press washer is a little easier but sure makes a heck of a mess....a lot more than the draw knife even.
    Mike
Similar Threads
  1. How far do you stretch a fence?
    By slim in forum Projects
    Last Post: 09-11-2017, 09:09 PM
  2. Post driver???
    By InlineDieselFan in forum Attachments
    Last Post: 11-16-2006, 05:02 PM
  3. Setting cedar split rail fence posts...
    By bandit67 in forum Projects
    Last Post: 11-09-2005, 12:14 AM
  4. Plastic fence post maker...
    By dixiedrifter in forum Build-It Yourself
    Last Post: 08-25-2004, 07:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
