NSBound
I decided that I needed more storage space. My garage is packed, and I have tractor stuff strewn all around the yard, I had a vinyl shelter in the way in the driveway all winter (it did a good job but it got in the way when clearing snow), and I had my boat parked outside all winter.
I considered a stick-built out-building, and then I got a flyer on the mail from Future Steel Buildings. Future Steel - Residential & Commercial Arch Steel Buildings . They had some good prices and the overall orice would be cheaper and last longer than if I just built a wood building.
So, I ordered one 20' wide X 25' long, 11'6" high in the centre, closed on the rear only, open at the front. At least that's for now - I'll see what this winter brings and decide if I have to close in the front too.
So the 6 steps -
1. Excavate. I wanted the building right where there is a bit of a hill. I figure I took out about 8 dump truck loads of soil and redistributed it around my property. I'll be making some rock gardens and flower beds that will use a lot of it.
2. Get 2" rock for the base. After the 2", I finished off the base with some 3/4 special (clear).
3. Get the cement guy in to set the forms and wire mesh and rebar.
4. Get the slab poured. It's 1 foot deep around the perimeter and 18" wide, tapering to 4" in the floor area. I used 4000 psi cement and I needed 13 yards.
5. Start assembly. I used the "regular duty" pallet forks on the tractor to unload the skids of parts off the huge flatbead truck that delivered them to my driveway. The tractor's loader limit is 2350 lbs, and the pallet forks limit is 2000 lbs, but with a bit of a grunt, it picked up 2400 lbs off the truck and carried it, sloooowwwwly, in the driveway. Oh, also, it helps to have a neighbour with staging.
6. Finish assembly. It took 3 people 3 days to put it all together. There are 2100 nuts and bolts holding this building together, and it's anchored into the cement at every rib. It will never blow away!
So the 6 steps -
