RxRatedZ71
Gold Member
Well we made some good progress today. My father came out and we got all 4 corner posts concreted into place. That was a serious task. One post in particular had 10 bags of sack-crete. I had dug the holes and spaced them 10'OC, which I had mis-calculated and not taken into account the girt thickness on the exterior walls. Therefore, the corner posts had to be adjusted to 39'6" by 29'9". After adjusting their positions, some postholes had extra space and used more concrete. Before you ask, yes, I believe in filling the holes with as much concrete as possible. The largest hole was actually on my post that needed the most reinforcement. I had to bring in 2.5' of fill dirt at that corner, embed some massive 500lb rocks for anchor, then pray that my auger would reach the virgin, untouched soil beneath the pad.
Unfortunately, we did not rent a mixer for the concrete, so it was done by hand then poured in, load by load. I think we'll check into the mixer for the remainder of the holes. We got the south 40' wall up and I'm on my third course of girts. I've cut me a preacher to help mark their spacing and placement. I just tack a nail into the marked line on the post and then rest the girt on top. Then I'm able to nail them up by myself in a quick manner.
I bought some "cool ties" tonight and plan to try them out tomorrow. They are a special neck-bandanna that had beads in them to retain coolness and release it slowly throughout the day. Hopefully they will help keep my core temp down and make these high temperatures just a little more tolerable.
