Simple solar panel tracking system
   / Simple solar panel tracking system #1
spurlocktool
N. California
Kubota BX1500, BX2230
I'm not sure if this is the right place to post this project - maybe it should be over at the Rural Living Forum since it doesn't involve tractors? My apologies if that's the case, but it is definitely in the build-it-yourself project category.
I have two water wells on my property with 24 volt DC submersible pumps powered by photovoltaic (solar) panels. The pumps are hooked up PV direct; in other words there are no batteries in the circuit, the panels power the pumps directly. Since the pumps only run when there is sun on the panels, to maximize well output I need to maximize the hours of sun exposure. Having the panels rotate throughout the day to track the sun's movement does that. Since my wells are low gallons per hour, being able to pump for more hours per day can increase production by 40% in the summer. Commercial PV panel tracking systems are available but quite expensive, so I came up with a simple low tech method that has worked perfectly over the years. PV direct water pumping really benefits from tracking, especially in the summer when you typically need more water and the sun moves across the sky in a bigger arc. But any small solar panel installation would benefit from the same system. I also use pump controllers with linear current boosters, which dramatically increase pump speed during low light conditions.
My system uses the weight of water in a 5 gal. bucket to rotate the PV panel four times a day. The PV panel mounts with two pivot bolts to a triangular frame so it can rotate through 90 degrees. Springs pull the panel toward the east, while the bucket pulls a rope to rotate the panel toward the west. A battery powered irrigation timer is set to add water to the bucket four times per day. Each time it does, the bucket pulls harder against the panel, rotating it to a new position. At the end of the day a separate timer drains the bucket, and the springs rotate the panel back facing east again for the next morning. The PV frame mounts to a tower with adjustable struts so I can manually adjust the north/south tilt flatter in summer and angled more southerly in winter.
Calibrating the timer and springs was simple. I just went out at around 10:30 a.m., manually turned on the fill timer, and noted how long it needed to run to rotate the panel the right amount. I repeated this at 12:30 p.m., 1:30, and 3:30 and programed the timer accordingly. I used three springs that engage successively to apply more resistance as the panel rotates. The springs and bucket connect to the panel with ropes, guided by small pulleys. Half of an old bicycle rim attached to the panel works like a big pulley so the ropes pull on the panel at a constant radius. The panels track consistently, even on windy days. I imagine another method would be to use a linear actuator or gate opener powered by a sprinkler timer (the type that turns sprinkler valves on and off). In my case since I am pumping water I had water supplies near each well. Since solar systems are so expensive, it really makes sense to maximize system performance with tracking.
   / Simple solar panel tracking system #2
Very ingenious.
   / Simple solar panel tracking system #3
spur,
That's ingenious and fun to make, etc. But what percentage of the PV panels output is used to operate the setup? If you barely had the power to run the well and needed tracking to actually run the well, would it have made more sense to just run two panels with no tracking and had all the power go to the well?
Tracking is a way to increase collector effectiveness, but I find all the fiddling around, extra machinery and power used to run the tracking system seems like a net loss compared to the lower, off peak efficiency, but higher peak output of a larger, non tracking system with the same overall initial cost.
What's your take on it?
   / Simple solar panel tracking system #4
Pretty ingenious
   / Simple solar panel tracking system #5
Raspy,
Thanks for your reply. My tracking system works by water pressure, not electricity, so there is no extra use of power from the panels. The well storage tank is on a hill, so the water pressure is from gravity. Only about 4 gallons of water needs to be pumped each day to operate the tracker, which is insignificant when I'm pumping up to 1000 gallons per day.
If I had a high producing well it would be possible to use a faster pump/higher wattage PV array without tracking to get the same amount of water per day as I currently produce with a lower power system with tracking. But all of my wells are low producing. They have to be pumped very slowly since they refill slowly, so more hours of pumping is the only way to maximize output.
Kays, yes that freon system is still around and works just as you described. Expensive though, and I'm cheap and like to build things, hence my water powered system.
   / Simple solar panel tracking system #8
Spur, Very clever & simple. I've some panels to mount when I retire next year & was thinking of a tracking system using photocells in tubes running timers/motor. Not sure your system would work for me at -40F. How much efficiency do you think you get vs static mounted panels?
I've also seen panels with mirrors on each side to intesify light which also need to be "aimed". MikeD74T
Mike, when I've compared total amount of water pumped with my panels fixed versus tracking, there is at least a 40% increase during summer, much less during winter since the sun doesn't move in such a large arc across the sky.
For water pumping and similar uses, a linear current booster is another big performance booster. During periods of low light (early morning, late afternoon, any time a cloud comes over), these solid state controllers trade off extra voltage for increased current, giving the pump motor enough torque to start and run at least slowly instead of stalling. So the combination of an LCB and tracking makes a huge difference in useful work done by the PV panels.
   / Simple solar panel tracking system #10
I haven't tried it on solar panels but on a solar heater a sheet of white styrofoam (or any white material) placed horizontally at the bottom of the panel increases the temperature within the panel 25°F in short order.
Tradewinds Power Unit (A50120)
Tradewinds Power...
2017 Polaris 500 Ranger Diesel Utility Cart (A53421)
2017 Polaris 500...
2010 JLG E450AJ TELESCOPIC/SCISSORING MANLIFT (A52707)
2010 JLG E450AJ...
UNUSED FUTURE FT-FR60 60" SIDE SHIFT FORKS (A57193)
UNUSED FUTURE...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A57192)
2014 MACK ELITE...
UNUSED FUTURE BS72 72" HYD BOXBROOM SWEEPER (A57193)
UNUSED FUTURE BS72...
