Page 3 of 50 FirstFirst 12345613 ... LastLast
Results 21 to 30 of 495
  1. #21
    Super Member ronjhall's Avatar
    Join Date
    Apr 2000
    Posts
    9,676
    SE Michigan
    Kubota 2910 HST
    Default Re: The gully to pond project
    Quote Originally Posted by jinman View Post
    I don't know if I'll have it finished by the spring, but that first erosion swale should be filled by then. I figured you might want some stick time on the LB75.
    You know me. Doing tractor work is fun work.
  2. #22
    Super Star Member EddieWalker's Avatar
    Join Date
    May 2003
    Posts
    19,388
    Tyler, Texas
    Several, all used and abused.
    ... I also have a mountain of material that was dug out of my pond. I called it pond silt at the time, but it is quite water tight and I will cover the top layer of the dam with this. ...
    From what I understand, by definition, clay soil is made up of silt.
    I forget how big that dump trailer of yours is. Will you be loading it with the backhoe and hauling it with your other tractor?
    Eddie
  3. #23
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Quote Originally Posted by EddieWalker View Post
    Eddie
    Eddie, I will probably use the dump trailer to haul the silt across mostly level terrain, but currently I think I can work faster with the tractor's bucket since the place I'm moving dirt to is about 200 feet or less from where I'm getting it. Also, the TC45D with loader weighs about 5,000 lb. With the trailer loaded with over 4 yards, the TC spins all four wheels and can't pull it up hills like the severe inclines going into and out of the gullies. You just don't realize how steep an incline it is until you try to pull a 10k lb trailer up the slope. Since I can load 1-1/2 yards in the LB75's bucket, I can run it up the incline and dump it where I need the dirt as fast as using the dump trailer.
    BTW: I'm a little down today because I went to put fuel into the LB75 and saw something dripping underneath. When I pulled the side panel to the engine, I saw the drip, drip, drip from the injector pump. In the few days I've had the tractor, the injector pump has started leaking. The dealership is coming to pick it up. To quote Wroughtn-Harv, "Darn! Double DARN!" I'm sure you know the feeling well. Sigh. . . .
    Jim
  4. #24
    Platinum Member saracenas's Avatar
    Join Date
    Oct 2010
    Posts
    967
    Lithuania, EU
    Present: 2003 Kubota M9000 DTF. Sold: 1985 Kubota L2202
    Hi jinman,
    You indeed have a conception how to work out Your task, but wouldn't You like to think about the hiring of the big caterpillar dozer and to do Your job much faster? I guess even after dozer''s work You'll have a lot to do with Your machines.
  5. #25
    Join Date
    May 2003
    Posts
    19,388
    Tyler, Texas
    Since I can load 1-1/2 yards in the LB75's bucket,(
    That's impressive. Mine will only hold a yard. Heaped, I'm rated for 1.13 yards, but that's it. I thought you had to go up to the 100 plus HP backhoes like the JD 710 and the LB115 to get a yard and a half.
    Eddie
  6. #26
    Platinum Member gotrocks's Avatar
    Join Date
    Aug 2001
    Posts
    770
    Phenix City Alabama
    B-2910 delivered 8/23/01
    Jim, I wish you well with this project. Just took a few minutes and made you a merge of the four pics you posted.
    Did not get sky to match but was the best I could do on short notice.
    Hope you don't mind.
    The gully to pond project-smallpond-merge-jpg
    Plant a tree, help it grow; children need something to climb.
  7. #27
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    The LB115 bucket is 1.15 cu meters = 1.96 cu yd. I'd say that's close enough to 2 cu yd that you could call it that.
    You guys are really cuttin' me some slack. 1.15 cu meters = 1.5 cu yd. Nobody corrected me. You gotta keep an eye on me.
    Jim
  8. #28
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Quote Originally Posted by gotrocks View Post
    Thanks Norris; I don't mind at all. I was going to merge the photos but noticed the last one had white sky. I don't know why. It sure adds a lot to the picture to be merged like that.
    Jim
  9. #29
    Join Date
    Apr 2000
    Posts
    9,676
    SE Michigan
    Kubota 2910 HST
    The pictures do not show the true terrain of Jim's land. Some areas around his excavations cannot be crossed with his Mule. Would be very hard to walk.
  10. #30
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    I had to send the tractor back to my dealers "clinic" for some healing by the service manager. The injector pump developed a leak at the outlet manifold (see attachment) and while it was in the shop, they found the tractor sometimes would not start due to the shuttle switch being worn. They fixed the injector pump and put in a new $270 shuttle switch for me at no cost as well as gave me a new $50 air filter. They are really "steppin' up" to their promise to make this tractor work ready. All of this was done at no cost to me because I didn't haggle on the asking price. My best deal was to have the assurance of a well-working used tractor. I'm glad I did it that way. I know they made some money, but I have a good tractor and the good will of my dealership anytime I need service. That cannot be a bad thing. I'm very pleased.
    Now, it's back to the gullies next week to move some dirt. More pictures will follow to document my progress.
    Attached Thumbnails Attached Thumbnails The gully to pond project-lb75-injectorpump-jpg
    Jim
Similar Threads
  1. I finally started my pond
    By bindian in forum Projects
    Last Post: 01-28-2017, 01:13 PM
  2. Pond Qestion and advice
    By brin in forum Projects
    Last Post: 11-18-2009, 12:55 PM
  3. My house, barn and pond project
    By rexcramer in forum Projects
    Last Post: 01-17-2008, 04:07 PM
  4. Upcoming pond project question..
    By Chuck K. in forum Projects
    Last Post: 08-27-2007, 01:12 AM
  5. Something Fishy Going On
    By deerefan in forum Photos
    Last Post: 01-24-2006, 11:33 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
