Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    New Member
    Join Date
    Sep 2008
    Posts
    9
    Western PA
    John Deere 4300
    Default Thanks for help! Building 32x48 barn/cabin
    Been reading with interest here for the past 2 years about pole barn projects, cabins, etc-- looking for ideas & knowledge on what to do. Everyone who has been posting here has been very helpful and this has been a great source of information.
    finally, after over a year of planning-- we're on our way! Last week, the site was leveled, the bldg framed, septic system installed, and the steel went on! Concrete is being poured this week, the well get drilled this week as well-- looks like power will come next week.
    Attached Thumbnails Attached Thumbnails Thanks for help! Building 32x48 barn/cabin-barn_raise1-jpg   Thanks for help! Building 32x48 barn/cabin-barn_raise2-jpg   Thanks for help! Building 32x48 barn/cabin-barn_raise3-jpg   Thanks for help! Building 32x48 barn/cabin-barn_raise4-jpg
  2. #2
    New Member
    Join Date
    Sep 2008
    Posts
    9
    Western PA
    John Deere 4300
    Default Re: Thanks for help! Building 32x48 barn/cabin
    Here's some shots of the progress....
    Attached Thumbnails Attached Thumbnails Thanks for help! Building 32x48 barn/cabin-barn_raise5-jpg   Thanks for help! Building 32x48 barn/cabin-barn_raise6-jpg   Thanks for help! Building 32x48 barn/cabin-barn_raise7-jpg
  3. #3
    New Member
    Join Date
    Sep 2008
    Posts
    9
    Western PA
    John Deere 4300
    Goal is to have a barn-- to house tractor, ATV,s equipment-- and room to process deer! This is going up on property we bought for recreational use-- about 50 acres of great MidWestern deer hunting, and close to a state park with a beautiful lake. Recognized early on that this has to be a place that TheOneWhoMustBeObeyed would appreciate and be willing to hang out when the overly indulgent deer hunter wants to go to the woods.
    Here's some shots of the design goal: courtesy of another client my realtor has-- it served as my inspiration
    Attached Thumbnails Attached Thumbnails Thanks for help! Building 32x48 barn/cabin-barn_ideas1-jpg   Thanks for help! Building 32x48 barn/cabin-barn_ideas2-jpg   Thanks for help! Building 32x48 barn/cabin-barn_ideas3-jpg   Thanks for help! Building 32x48 barn/cabin-barn_ideas4-jpg
  4. #4
    New Member
    Join Date
    Sep 2008
    Posts
    9
    Western PA
    John Deere 4300
    more shots of the design goal:
    Attached Thumbnails Attached Thumbnails Thanks for help! Building 32x48 barn/cabin-barn_ideas5-jpg   Thanks for help! Building 32x48 barn/cabin-barn_ideas6-jpg   Thanks for help! Building 32x48 barn/cabin-barn_ideas7-jpg   Thanks for help! Building 32x48 barn/cabin-barn_ideas8-jpg
  5. #5
    New Member
    Join Date
    Sep 2008
    Posts
    9
    Western PA
    John Deere 4300
    Question: What is recommended for heat?
    I had originally considering doing the radiant heat in the concrete, then rejected it since it takes over 24 hours to get warm. Then thought I would use baseboard heaters and a wood stove-- I was advised to consider putting in a heat pump since it would give both heat and AC. Just not sure its worth the extra cost.
    I can see why housing starts are down-- this is EXPENSIVE for things like septic, water, tap fees for power. The price of the building was the cheap part!
  6. #6
    Super Star Member Thomas's Avatar
    Join Date
    Apr 2000
    Posts
    17,320
    Lebanon,NH.
    Kubota L2800HST w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
    Do I detect open barn dance welcome soon under the harvest moon.
  7. #7
    Platinum Member medicshawn's Avatar
    Join Date
    Oct 2007
    Posts
    660
    Central VA
    Kubota L3940 FEL HST
    For ideas related to the HVAC we might need to know how you intend to occupy it. Are you going to use it year round? Are you looking to keep it at a certain temperature and adjust when you're there? Is the HVAC only going to be used when occupied? Seems like there'd be the hassle of insuring the pipes didn't freeze in the winter if you don't leave the heat on year round. Might be a good idea to get some ideas from HVAC guys around there.
    BX1860 Mowing Machine
    L3940 FEL Sold
    B7800 TLB Sold
    IAFF Local 1568
  8. #8
    Super Member Iplayfarmer's Avatar
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Massey Ferguson 1215, Toro 266-H, Farmall Cub, Farmall A
    Quote Originally Posted by l8_apexer View Post
    How you heat depends on your plans. It sounds like this is an occasional use recreational place. You'll need something to keep your water lines from freezing, but you'll want something that can heat it up quickly when needed. I'd recommend a few electric baseboards to maintain a temp of about 40 degrees and a nice large wood stove for the quick heat. There's nothing like the comfortable heat that comes from a wood stove.
    I'd pass on the heat pump unless your summers get very warm. You have to consider the cost of purchase PLUS the cost of maintenance.
    From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
  9. #9
    New Member
    Join Date
    Sep 2008
    Posts
    9
    Western PA
    John Deere 4300
    Weekend use primarily-- please a week or two in the November-January timeframe. We are planning on having the pressure tank for the well and the hot water heater in an insulated closet that we would keep at about 50 degrees. The plumbing is going to be pex tubing, and set up so I can blow out the lines when I leave. We'd like to try and keep the place about 45-50 degrees when not there during the seasons (October-end of Jan) and then "winterize" it all and shut everything down for the balance of the winter.
    Is this a feasible approach- or should I plan on just having to keep it at 45-50 degrees throughout the winter?
  10. #10
    Elite Member
    Join Date
    Oct 2004
    Posts
    2,952
    limerick pa lycoming county pa
    kubota bx23
    Plumb every thing back to low points and drain there
    My cabin is off grid and in the boonies and I have 4 valves to drain the whole system inside and one in the well it just takes some fore thought.
    tom
    If it ain't broke we will help you brake it
    If it is broke we will help you get it fixed!
    https://www.facebook.com/joseph.t.mussington
Similar Threads
  1. P-model arch steel building project
    By Dirtnut in forum Projects
    Last Post: 03-20-2012, 07:56 PM
  2. Replies: 0
    Last Post: 11-30-2005, 06:48 PM
  3. Storage building
    By jcmseven in forum Rural Living
    Last Post: 11-23-2005, 05:13 PM
  4. Anyone put up a ARCH building before?
    By smilingreen in forum Rural Living
    Last Post: 01-25-2002, 02:01 PM
  5. Fire in metal building
    By Ranger in forum Rural Living
    Last Post: 01-08-2002, 10:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
