Results 1 to 9 of 9
  1. #1
    Join Date
    Nov 2010
    Posts
    68
    Kubota 3240
    Default Please advise interior barn wall cover
    See attached photo. I can attach more if requested/needed/deemed helpful.
    I hope you can see the insulation on the inside walls. The framing is all welded steel square tubing.
    We want to add something to the inside to protect the sheet metal, to protect the insulation, to provide something for attachments.
    I had planned on using 3/4" plywood, but now understand they are $30 or more per sheet. The spans are enough that if I go 1/8" I am going to need to add nailers for strength underneath. The 3/4" would provide their own strength.
    We put the cats in there for anti-mouse reasons. They have not torn up the insulation, yet, but it is a brand new barn.
    Please, I am looking for recommendations.
    Attached Thumbnails Attached Thumbnails Please advise interior barn wall cover-img_2082-jpg
    Kubota L3240, disc harrow, chain harrow, rear blade, plow (don't know), hay spear, box blade
  2. #2
    Veteran Member Birdhunter1's Avatar
    Join Date
    May 2004
    Posts
    1,327
    Murphysboro, IL
    Ford 3910
    Default Re: Please advise interior barn wall cover
    I have done part of mine with the same sheetmetal I used on the outside of the building, of course my wall gerters were 2' apart so I had no problem doing this. If you have a sawmill nearby you might look into rough sawn lumber at 3/4" thick.
  3. #3
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,032
    Central Ohio
    Kubota MX5100
    OSB is cheaper than plywood and will work just fine,
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  4. #4
    Super Star Member EddieWalker's Avatar
    Join Date
    May 2003
    Posts
    19,181
    Tyler, Texas
    Several, all used and abused.
    What is the distance that the posts are set at?
    3/4 plywood varies in price from $30 on up a sheet, depending on the finish quality of the wood. I would want the posts to be at least 4 feet apart to just use 3/4 plywood, and even then, I'd expect a fair amount of movement from it. On floors, you want no more then 2 feet when using tounge and groove.
    For long term, and to do it right, install purlins on the posts every two feet. Make sure to get them long enough to overlap your seams.
    Once you do this, you will be able to use just about anything you want on the walls. I like OSB. It's cheap, strong and has an interesting pattern.
    Eddie
  5. #5
    Join Date
    Nov 2010
    Posts
    68
    Kubota 3240
    Thanks for the replies, so far.
    • Eddie, I will measure later today (sun is not up here, yet and it is already raining--I hear you are going to get several more inches of snow than we will), but based on what I saw when I laid a piece of plywood against it, the span to the right of the ovehead door in this new picture is about 5-6 feet.
    • Regarding purlins: the contractor had said several of his customers used 1 x 4s to stiffen and provide nailers. I was wondering if that would be more, or less expensive than thicker sheets of whatever the covering is.
    Thanks again, to everybody.
  6. #6
    Join Date
    Nov 2010
    Posts
    68
    Kubota 3240
    I forgot the picture mentioned in previous post. Here it is:
    Attached Thumbnails Attached Thumbnails Please advise interior barn wall cover-img_2074-jpg
  7. #7
    Join Date
    Oct 2008
    Posts
    1,186
    Mid. Coast Maine
    7610 hst
    Most people around here just lay up 8' studs on the vertical 2' on center and then 1/2" osb.. The studs work good for the electrical and with the studs every 2' it's good for hanging stuff from,,
  8. #8
    Join Date
    May 2003
    Posts
    19,181
    Tyler, Texas
    The latest forecast is 100% for snow today. Tyler is expected to get 1 to 2 inches. From 20 to 30, it's supposed to have 2 to 4 inches and above 30 they are saying up to 8 inches of snow. I'm right along I-20 and figure to get more then Tyler. Whatever I get, I'm posting pics if it sticks!!!!!
    1x4's would work up to 4 feet, but after that, they will sag on you and not offer the support of stiffness that you want for the long term. 2x4's will work up to 6 feet, and 2x6's to ten feet. Ideally, I like to buy wood that will attach to three posts and overlap my ends so there is more strenghth. Same thing with building fences.
    Eddie
  9. #9
    Join Date
    Nov 2010
    Posts
    68
    Kubota 3240
    Eddie,
    The Canadian folks may laugh at this, but I am going to wait until it warms up a little, then go take some measurements. I tend to arrive home way after dark.
    Thanks.
Similar Threads
  1. BX24 leaking hydraulic fluid from rear cover
    By Just2quickz28 in forum Kubota Owning/Operating
    Last Post: 08-28-2008, 08:02 PM
  2. Demolishing Concrete Wall
    By centex in forum Projects
    Last Post: 10-01-2003, 09:55 AM
  3. Retaining Wall
    By RobS in forum Projects
    Last Post: 06-05-2003, 03:04 AM
  4. Neighbors wall colapsed (twice)
    By Paul_in_CT in forum Related Topics
    Last Post: 07-22-2002, 08:30 PM
  5. Mid PTO Cover
    By computerboy in forum New Holland Owning/Operating
    Last Post: 05-31-2002, 11:33 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
