Need help with Corduroy road
   / Need help with Corduroy road #1
josephny
Hi,
I've been searching and am so happy to have found this thread describing the building of a corduroy road:
http://www.tractorbynet.com/forums/projects/153596-building-road-whoulda-thunk-itd.html
I have my own problem project and sure would appreciate some help.
I have about 100 acres in Sullivan County, NY, shaped as a rectange of about 4,500' by 1,200'
About 3,000 feet back, the ground is low and wet and over the decades (centuries?), an incredible wall of rhodedrum of grown -- about 12 feet high, and about 300' deep.
The ground has about 2-3 feet of peat-like stuff -- very soft, spongy ground, likely on top of clay (the dirt around the area is heavy with clay).
I've been trying to break through for years.
First with a dozer hired with a guy, who got a few feet in and refused to continue out of concern the dozer would sink.
Then I hired a guy with a mini-excavator and we walked into it a bit and said he could do it. I said 'are you sure you won't get stuck' He said 'anyone who gets their machine stuck shouldn't own a machine' Could hours later, he came walking out and had to get his buddy with another machine to pull his stuck machine out.
So I have a path that goes about 1/2 way through (150') that I can walk just fine, as long as I stay to the sides and dance around the softer middle (5' wide path created by the excavator), but I can't ride an ATV on it because it's too soft and wet. Then it stops -- where the excavator did.
This past summer, I took my chain saw and loppers and opened up a very small, difficult walking path through the remaining 150'. There's fallen trees and wet area and no way for an ATV to pass.
Past this area the land elevation rises sharply and reveals 30+ more acres of mine that I'd sure like access to.
So I've been reading and researching how to make it so I can pass with an ATV and the only thing I've come up with is a corduroy road of 6-8" diameter tree logs.
I've never done this, and getting manpower up there is difficult.
I was hoping the more experienced guys on this board could share some hints, tips, suggestions, warnings, etc. on how to get this done. I'd like to get this done in April, or May if it's still too cold.
All I've thought of so far is to find a few guys to work for a few days with me (I don't have the guys, but I'm looking), bring the chain saw, loppers and some hand saws back there and have at it. I could certainly have a truckload or 2 of gravel brought to the property, and shuttle it with my little trailer behind the ATV to the site (3,150' feet from where the dump truck would have to leave it.
Thanks very much,
Joe
Here's a picture -- Yellow is the outline of my property, others are paths.
   / Need help with Corduroy road #2
It sounds like you have a plan. Have you asked your family if they could help out? Sometimes it can be a fun way for family to help each other out.
Is your land inaccessable at all times of the year or you havent checked yet? I have certain parts of my land I can't use in late fall and spring until I finally got a foot of wood chips down for a path and so far its still holding up for a couple years. I suspect that in another couple years, I will have same issue again as it decomposes. That is ok as I can get the county or power company to drop a couple loads again so I can spread with my tractor. Perhaps you could do the same if you have access to lots of brush?
If you were closer, I'd come and help for awhile as I am currently unemployed.
   / Need help with Corduroy road #3
I've heard about rubber tires being bolted together for swamp maps. :D
Might not meet with rubber tire disposal hierarchy approval though??:confused:
There's no family who could possibly help unfortunately.
I'm only there from May through September (and not even full time during that period). Spring is the wet time with all the snow melting.
I see Ontario is 4 hours -- too bad, as I'd love some skilled help with a tractor!
I don't know if I need anything on top of the logs, or whether rocks or wood chips or brush or something else is best.
The flak I'd get from friends/family/neighbors would be too great.
And, I'd need a substantial amount of fill to make it a nice walking/riding path.
The rubber makes great sense though -- all natural :thumbsup:
   / Need help with Corduroy road #6
Joe,
I'm no expert and can only speculate about the amount of gravel you would need. But I do think it would take a long time to haul it that distance in an ATV trailer. Any chance of getting closer to the wet area? (You mentioned that someone had accessed the area with a dozer.)
Did you run across this publication in your research?
Trail Construction and Maintenance Notebook, 0023-2839-MTDC, Trails in Wet Areas
Steve
Joe,
Steve
Yea, I'm not looking forward to hauling 2 truck loads of gravel in a trailer that can handle about 10 cu-ft per load (given the weight).
I saw that publication, and a number of others. I did not find one that I felt had instructions any more explicit and details than:
Cut 6-8" diameter trees into 5' lengths
Lay them next to each other
tie them together or run a long log on each side and stake it down
Dig drainage areas on each side
top with soil/gravel/brush
There may not be much more detail, but for someone who's never done this, and doesn't have much experience in general with land moving, it'll definitely be a learning experience.
   / Need help with Corduroy road #8
Joe,
Just curious. What tree species will you be using for the logs? Some may rot faster than others.
Steve
Joe,
Steve
I hadn't thought about it.
These woods are mainly pine, hemlock, beech and birch (though I can't be any more specific).
My understanding is that if the wood is underground, or better, under water, the lack of oxygen will prevent decomposure and mean that they'll last for decades.
Frankly, however, we'll take whatever treese are nearby and lay them as best as possible, and, without machinery or experience, I'll be very lucky to have a passable road.
   / Need help with Corduroy road #10
Wouldn't winter time(everthing froze)be the time to do this??
2025 14ft. Bi-Parting Driveway Gate (A59231)
2025 14ft...
2017 Toyota Hybrid Camry Sedan (A59231)
2017 Toyota Hybrid...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
2013 Chevrolet Silverado 1500 Pickup Truck (A59230)
2013 Chevrolet...
2008 Freightliner B2 School Bus (A59230)
2008 Freightliner...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
