Page 5 of 5 FirstFirst ... 2345
Results 41 to 45 of 45
  1. #41
    Member
    Join Date
    Jan 2011
    Posts
    37
    international harvester pay loader
    Default Re: attached garage heating ideas
    Your duct idea will not give you enough btus to give you enough heat. It will never be able to give you intermittent heat. It will have to run all the time to do anything worth speaking of. Same goes for the water idea. You could run a heat loop from your hot water heater to a used radiator. You would have to crank up the hot water heater to 160 minimum and use a mixing valve for your domestic hot water so no one gets scalded. Also you could not let the garage get below 32. You can get a williams wall furnace ( thats what I would do ). It is direct vent. No duct work. It used to cost around 500 for a 30000 btu furnace. You cut a hole in the wall, hang a bracket, then your good to go. You could plug in a few longhi oil filled radiators. It would set you back less than 100. Electric baseboard would be an cheep option. While the cost to run electric heat would be higher think of the amount of time you would be running it. If your talking a few hours a few days each week the extra cost would not be that much. A radiant heater would be the most cost efficient to run if you would run the heat all the time. Radiant heat does not do very well if you wanted to keep the heat low than raise the heat when you were in there. I have radiant heat in my shop along with a boiler which works iron radiators and a fan powered blower. The radiant tube heater runs a constant 45 along with the radiators which are in 2 other rooms. When I go into the shop and want to raise the temp I use the blower and the tube radiant heater to raise the temp in the main garage ( 30 x 25 x 16 ). I use the radiators in the paint room ( 30x16x8) and in the metal working room( 15x10x8). I use less than 320 gals of propane per year to keep place nice. This may sound stupid but I just started wearing a wool cap. I find that it is pleasant working with the temp set at 45 to 50. Tom
  2. #42
    Join Date
    Apr 2004
    Posts
    1,083
    Michigan
    Deere 3720 Cab eHydro , 455AWS, X749AWS, 2720, Kubota RTV900
    Over the years I've tried just about everything suggested so far but the OH gas furnace worked the best. You will have a day into the installation but when you are done it will heat the best with zero maintenance.
    Modine Hot Dawg Heater | QC Supply
  3. #43
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    5,217
    north idaho
    dk45se hst cab
    Quote Originally Posted by bironacad View Post
    Plasma cutter me likes that
    Heres that TSC UNIT HEATER:
    Regular Price: $649.99HEATER BIG MAXX 45000 BTU LP
    SKU # 215043
    Vendor Part # MHU45LP
    Brand: ENERCO MR HEATER CORP
    i have a similar 125,000 btu hanging unit...i use it for an hour to knock off the cold, then turn it off and can work for hours out there. and oh yes...i love my plasma cutter cnc table.....its comes to the rescue so many times over the years. its hard to see the table thru the gate, but its a 4x10 unit. heres a gate i built last year.
    Attached Thumbnails Attached Thumbnails attached garage heating ideas-p1301166.jpg   attached garage heating ideas-p7261324.jpg
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  4. #44
    Elite Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    2,758
    Central Square, NY
    2615 HST FEL
    I bought a used mobile home furnace (80,000 BTU) for my attached garage. On cold days I fire up the kerosene slamander and mobile home furnace (also runs on kero). After about a half hour I unplug the noisy salamander and the furnace will keep my garage at the 60 degrees I have it set for.
  5. #45
    Member
    Join Date
    Jan 2011
    Posts
    37
    What a fence. Tom
Similar Threads
  1. Questions about tractor garage
    By raykos in forum Projects
    Last Post: 08-23-2009, 01:37 PM
  2. Garage Renovation question
    By BrentD in forum Projects
    Last Post: 12-19-2008, 10:20 PM
  3. Garage Damage Prevention
    By bcarter in forum Owning/Operating
    Last Post: 08-09-2004, 03:35 PM
  4. using heating oil for fuel?
    By steve_niceguy in forum Oil, Fuel & Lubricants
    Last Post: 06-27-2004, 10:18 PM
  5. Help getting land ready for Garage
    By pccarroll in forum Projects
    Last Post: 05-24-2004, 12:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
