Well Pump Planing???
   / Well Pump Planing???
I see no mention of a pressure tank? Size of drill casing? Size of pipe down to connect said pump?Be certain the wiring is correct to the motor.
This is my pressure tank.
Shop WellSaver 25-Gallon Pressure Tank at Lowes.com
I'll have to measure the casing.
The pipe coming out is 1.25" or 1" not sure.
It currently is pumping fine just trying to be prepared and to accout for future irrigation needs.
Here are some pics of the well from when I replaced the pressure tank.
   / Well Pump Planing??? #13
In the first picture, what does the well tag say?
E/S
   / Well Pump Planing??? #14
Your electrical connectors sure look rough, make sure none of them are loose or close to touching. Bugs love to get on top and mess up the contact, don't leave any openings on switch, ahla ducttape...
   / Well Pump Planing??? #15
Years ago Jacuzzi had an Aqua Genie system that ran as long as water was used. It used a 1 gal tank. It was the state of the art back then. It didn't cycle at all. Today I have to use a pressure regulator to make my own version. It works very well. Also there is a great difference between a Lowes pump and a name brand, Gould , Jacuzzi , etc. They cost more but they are made of brass and SS parts where the cheaper models are plastic and not repairable. Also a 3 wire pump has parts above ground that can be repaired where the two wire has to be pulled and the motor replaced. My 2 cents worth.
E/S
Well it's a bit different than what I remembered being told, but I've been known to get facts turned around.
The tag states:
  1. Date - hard to read (house was built in 1990)
  2. Depth - 150
  3. Casing depth -130
  4. Diameter - 6
  5. Screen Interval - blank to blank
  6. Gravel Depth - looks like 0.2 (may just be zero) to 20
  7. Static water Level 30
  8. Yield - 50 GPM
   / Well Pump Planing??? #17
With that info, now you can size the pump. To run your house you can do just fine on 10 gpm. If you are going to irrigate, pond, ect. you can run the 26 gpm pump.
How much you run depend on $, at higher gpm you need more storage, electrical and probably larger pipe.
How big is the power source for your existing pump?
E/S
   / Well Pump Planing??? #18
I'd sell one of my dogs for 50 GPM. kidding.
But seriously, that is amazing production. I'm going to have to sink a second well (mnay X deeper than that) just to have 10 GPM combined.
What does the static water level of 30 mean?
Does itmean the number of feet of water in the well when not pumping?
2016 Kenworth T270 Truck, VIN # 2NKHHM6X1GM110171 (A51572)
2016 Kenworth T270...
NEW LandHero Mini Stand up Skid Steer (A53002)
NEW LandHero Mini...
John Deere 5425 4x4 Tractor with Loader (A51573)
John Deere 5425...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
