Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. #1
    Bronze Member markrahn's Avatar
    Join Date
    Jul 2006
    Posts
    52
    Wilson county Texas
    Kubota L3400
    Default Well house roof design help
    I built the 4 walls of the well house. 10' x 12' right now it is sitting on bare dirt. My plan is to level it on the 3" solid concrete blocks, about 3 on the 10' side and 4 on the 12' side. Form around the perimeter with 2x4, hang anchor bolts and pour inside floor with leftover concrete when they pour the slab of the house.
    But onto the roof. I was thinking of a roof, gabled, that had one side of it removable for pump service. I was thinking a few lag bolts to hold it on. My friend suggested to build the roof as a whole and then make the whole thing removable. That would take care of the peak getting sealed.
    Anyone ever made anything like this before? Any ideas, suggesstions?
    right now it is a topless pump house.
    Why did I build the 4 walls with no set plan for the roof? I needed to keep the wind off the well expansion tank cause it was freezing and thats how I roll sometimes you know - cart before the horse. ) I did plan the roof, just now thinking there may be a better, smarter way.
    thanks yall
    2010 Kubota L3400 with FEL 5' shredder 60" tiller 6' swivel blade cary all 2share middle buster
  2. #2
    Elite Member
    Join Date
    May 2010
    Posts
    3,940
    of my
    Here
    Default Re: Well house roof design help
    Here's the plan for my well pump house: 8'L x 6'W, walls 4'H with roof on top of that. 12-12 (aka 45 degree) slope). The face you see is the 6'W end. The door opening is only about 5.5'H, but hey, it's a well pump house.
    Well house roof design help-well_pump_house-jpg
    Attached Thumbnails Attached Thumbnails Well house roof design help-well_pump_house-jpg
  3. #3
    Super Member Iplayfarmer's Avatar
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Massey Ferguson 1215, Toro 266-H, Farmall Cub, Farmall A
    I'd be concerned about sealing the peak of a hinged roof.
    10' X 12' is a big roof to remove whole, but if someone is going through the roof for pump service, they likely have some kind of boom they're using anyway. If you do make the roof removeable, plan that into the structure. Add some extra diagonals and framing to keep the roof rigid after it's removed.
    From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
  4. #4
    Elite Member
    Join Date
    May 2010
    Posts
    3,940
    of my
    Here
    I thought about hinging mine at one of the lower edges, & also thought about making it removable. In the end, I just screwed it all down tight, decided it wasn't worth messing with, & if I must remove the roof, it's all un-screwable.
    Even on this "little" 8'Lx6'W well pump house, that roof would be a big thing to move, whether lifting off or even just tilting on hinges.
    (The pic I posted is of my new well; my current well pump house is hinged, but I can't walk into right it like this new one)
  5. #5
    Join Date
    Jun 2007
    Posts
    58
    Southern California
    Massey Ferguson GC2300
    My solution to the well shed roof access was to add a curbed skylight. I picked it up at one of the super hardware stores for well under $100. Of course, this works best when planned so your well and skylight aren't located at the ridge of your roof. It's easy to back off a few screws and lift the lightweight skylight off without compromising any watertightness.
    Southern California
  6. #6
    Super Member
    Join Date
    Apr 2006
    Posts
    6,484
    Wise county Texas
    Kioti DK 35 now
    If you put on a metal roof, you could put the seam of the 2 roof halves under the middle of one of the metal sheets, so you only have to remove 2 sheets of metal.
    That would still leave you allot of roof to lift off, that is a big pump house.
    Dennis
    "Winter 2013 a majority of the country is setting new cold records, Colorado is setting new record HIGH's"
    "If at first you don't succeed, skydiving is not for you."
  7. #7
    Elite Member
    Join Date
    May 2010
    Posts
    3,940
    of my
    Here
    Quote Originally Posted by Western View Post
    That is a definitely a big pump house!
  8. #8
    Elite Member
    Join Date
    Oct 2004
    Posts
    2,952
    limerick pa lycoming county pa
    kubota bx23
    Why do you have to remove the roof for service?
    Submersible poly pipe an a good door and window to feed the pipe out.
    If you have to have the well redrilled the whole place would be in the way.
    A farmer that I know had done the same thing and had to tear the whole place down to get the drill rig on top of the hole to drill his well deeper.
    he had a shallow well jet pump and tank in there originally.
    He went with a submersible and a tank in the basement no well house after that.
    tom
    If it ain't broke we will help you brake it
    If it is broke we will help you get it fixed!
    https://www.facebook.com/joseph.t.mussington
  9. #9
    Join Date
    Feb 2011
    Posts
    107
    Maine
    JD x749, LX277
    you could always use lags with a big eye in them. Fasten this to the lower edge of the inside of the roof members and fasten another set on the inside top of the walls so that they align. Then get yourself a piece of pipe or bar that could slide into all of the eyes. would work well and keep it roughly sealed especially if you brought the edge of the roof a little lower than the top of the wall. does that make sense? i could draw it up later. Would be a cheap way to do what you are looking for provided the roof wasn't too big and heavy!
    x749, 54 sb, 62 mmm, 48 bb, 6ft LR, 56" thatch, 250lb spreader.
    LX277 - 42" mower, it just mows.
  10. #10
    Join Date
    Oct 2010
    Posts
    1,379
    NHtd75
    To avoid a well house altogether, ask your driller if it's too late to change to a pitless adapter and put the pressure tank in the garage.
Similar Threads
  1. Replies: 94
    Last Post: 01-30-2011, 12:52 AM
  2. Do I need/should I get a new roof?
    By RobA in forum Rural Living
    Last Post: 04-13-2008, 10:05 PM
  3. New House - Central Air
    By Alan L. in forum Related Topics
    Last Post: 09-07-2006, 07:38 AM
  4. Help - need new roof, 2:12 pitch
    By 450EXC in forum Rural Living
    Last Post: 08-28-2006, 07:20 PM
  5. New Shingles For Roof
    By Golfgar4 in forum Related Topics
    Last Post: 04-02-2005, 09:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
