mpowrd
I just had a small landside take out some of the bedding at the edge of my driveway. A section of driveway about 20 feet long now has a gap below it about 1 foot high and 2 feet wide (going into the driveway). It looks like there's still good bed material directly under the asphalt.
Until I can get in there and figure out what kind of retaining wall and fill I'll need longer term, I want to support the edge of the driveway to prevent the asphalt from cracking and to help take some of the traffic load. Right now I can detour to the uphill side enought to avoid the voided area, but sooner or later the propane truck needs to get up there.
I read that I could use sand bags filled with a sand and cement mixture that could be stacked in the void dry, then wet down so they harded up. Do you think I could get the same result stacking paper sacks of concrete mix or do I need the porosity of the burlap sand bags to get them to bond?
Thanks for the advise.
