Page 10 of 10 FirstFirst ... 78910
Results 91 to 100 of 100
  1. #91
    Veteran Member dstig1's Avatar
    Join Date
    Apr 2010
    Posts
    1,911
    W Wisc
    Kubota L3130
    Default Re: A(nother) Home in the (different) Woods
    Eddie - Thanks for the support!
    MJN - Thanks also, and yes I was wiped out after that week.
    PAGuy - That is the raging debate. The problem with an ex and the bucket is that it drops the rock when you start to uncurl. So you get no control. We may end up having to hoist blocks into place with straps and the bucket.
    Obed - the quarry pretty much just breaks them out. They are pretty consistent within a layer of the rock, but they do nothing to them to make them flat. "They grew that way" essentially....
    He dropped a new load of blocks today. I will need a couple more loads before we can go at it for the upper layer.
    -Dave
    "Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
    L3130HST, QA, 723 Loader, 48" Forks, 48" Grapple, Ancient Farmi Skidding winch
    Trailer - 10k/16' twin axle w/elec brakes
    2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
  2. #92
    Veteran Member Depmandog's Avatar
    Join Date
    Nov 2010
    Posts
    1,312
    Buckner MO
    2005 Kubota L5030 GST; Farmall 706
    Default
    Quote Originally Posted by dstig1
    No problem for an excavator with hydraulic thumb. You will need to size it accordingly based on lift height, needed reach and lifting weight.
    Your other option is an extending boom hi lift rough terrain forklift (telehandler)
    Dean
    "Get busy living, or get busy dying" - Morgan Freeman in "The Shawshank Redemption"
  3. #93
    Join Date
    Apr 2010
    Posts
    1,911
    W Wisc
    Kubota L3130
    I'm not as sure about the excavator with thumb as I used to be. It is not as good of a tool for this as you might think base don my experience. The proper tool is a large Excavator with a rotating clamshell like below but they are rare and very spendy.
    A(nother) Home in the (different) Woods-9-22-2012-12-20
    The telehandler did come up as one option. The possible problem there is that the first layer or two might not be directly reachable with the machine sitting down in front of the lower wall. The angle of the boom might be too high to get down to the ground on the upper deck after clearing the lower wall. Crude sketch of what I mean:
    A(nother) Home in the (different) Woods-9-22-2012-12-24
    If you can get the first couple layers in place somehow, then it should work great. You really need to carefully place rocks, not just drop or dump them in place.
    -Dave
  4. #94
    Join Date
    Nov 2010
    Posts
    1,312
    Buckner MO
    Default
    <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=281762"/>
    <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=281764"/>
    In regards to the excavator and thumb, a good operator wouldn't have any problems. Now he would set the rock and the bucket would be on the backside, so there would need to be enough room between the rock and the dirt. It's possible he could rotate the rock out away from the machine - but he would lose come control.
    The telehandler - yeah the lower row might be tougher. Your could move some dirt for it to ride up on. Also, different brands are constructed differently - with a higher mast connection location. You might find one that would work better than another.
    Dean
  5. #95
    Join Date
    Apr 2010
    Posts
    1,911
    W Wisc
    Kubota L3130
    I realized I haven't posted the final results of the wall. Here are a couple pics of the final result. This was wrapped up in Mid Oct. The guy who sold me the rocks did the placement of the upper deck with his excavator (deere 312L, I think?). It is amazing to watch someone who is an artist with an excavator work. He did things I really didn't think were possible. I was making backup plans for when his idea of placing the blocks with his ex didn't work. He did the last part of the wall (the upper deck) in a day and a half with help from me and another guy. Wow. I did the other 2/3-3/4 of the wall basically myself with the tractor and a rented skidsteer in a week or so.
    Here's the stats:
    Blocks: 200 tons
    Backfill crushed rock: 180 tons
    Length: 170'
    Max height : ~10'
    Here is the front view. Most blocks are about 36-48" wide, 14-18" tall, and 20-30" deep. Roughly 1500-2000 lbs each or so, I guess, though I never weighed any of them.
    A(nother) Home in the (different) Woods-wall_wide_ang_final_stitch-custom-.jpg
    There are two tiers to the left side of the wall. Here is a side shot that shows the second tier. Hard to see on the frontal shot, but you can if you look.
    -Dave
  6. #96
    Elite Member 94BULLITT's Avatar
    Join Date
    Feb 2011
    Posts
    3,847
    Frederick County, VA
    Kubota BX2360 & L4240 HSTC
    I just looked through your thread, I had not seen it before. It looks like you have made alot of progress. The wall looks really good. I also noticed we have the same chain saws kind of, I have a MS660 and a 034 super (3.6 cubic inch) which would be the equivalent of your MS362.
  7. #97
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    Front Range of Colorado
    JD 4200 C.U.T. & JD 130L Lawn tractor
    That's one he!! of a wall you built!
  8. #98
    Super Star Member EddieWalker's Avatar
    Join Date
    May 2003
    Posts
    13,611
    Tyler, Texas
    Several, all used and abused.
    AMAZING!!!! I sure wish I had rock somewhere close to where I lived. If it was just expensive, I'd buy it, but it's beyond expensive here. Congratulations, you created a thing of beauty.
    Eddie
  9. #99
    Veteran Member Obed's Avatar
    Join Date
    Dec 2006
    Posts
    2,430
    Anderson County, TN
    John Deere 4210 FEL BH
    Dave,
    Very nice job! You'll be proud of that wall for many years to come. It's satisfying to be able to look out over your work and appreciate it when you know you did it well.
    Obed
    John Deere 4210 (28 HP) FEL, BH, 6' Box Blade, Loader Forks
    At Home In the Woods
  10. #100
    Join Date
    Apr 2010
    Posts
    1,911
    W Wisc
    Kubota L3130
    Default
    Thanks guys. It was a ton of work, and I was pretty concerned about how the upper deck was going to happen for a while.
    Since it was going to be such a large feature, I really didn't want to do it from concrete retaining blocks as it would look too cold and industrial, IMO. I may do other walls with retaining blocks as needed, but that just didn't seem right for this one.
    The limestone is pretty common here. It has a lot to do with the same geography that is the source of a lot of the "frac sand" used in gas/oil fracking operations. That has become huge in the area...
    -Dave
Similar Threads
  1. Log cabin construction
    By gcp in forum Rural Living
    Last Post: 09-27-2010, 01:10 AM
  2. Replies: 18
    Last Post: 09-18-2007, 05:03 PM
  3. Replies: 10
    Last Post: 05-19-2007, 06:35 PM
  4. Backhoe Branson versus woods backhoe
    By farmyid in forum Zetor, Century & Branson
    Last Post: 08-06-2006, 10:39 AM
  5. Intruder in the woods
    By NoTrespassing in forum Rural Living
    Last Post: 02-01-2005, 10:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
