Page 14 of 21 FirstFirst ... 411121314151617 ... LastLast
Results 131 to 140 of 206
  1. #131
    Super Star Member EddieWalker's Avatar
    Join Date
    May 2003
    Posts
    19,195
    Tyler, Texas
    Several, all used and abused.
    Default Re: A(nother) Home in the (different) Woods
    Most Impressive!!!! Thanks for the update. Having OSB on the inside walls will make it easy to organize everything.
    Eddie
  2. #132
    Elite Member wmonroe's Avatar
    Join Date
    Nov 2005
    Posts
    3,383
    Southwestern, PA
    1958 Ford 961 Powermaster
    Default
    Awesome building! How thick did you go on the floor?
    Kubota L5240 with loader and backhoe
    1958 Ford 961 Powermaster LP
  3. #133
    Elite Member dstig1's Avatar
    Join Date
    Apr 2010
    Posts
    2,814
    W Wisc
    Kubota L5240 HSTC, (Kubota L3130 HST - sold)
    Thanks, Guys!
    The slab was kind of all over the map as the clown who graded it (ahem ...me...) left a lot to be desired in terms of consistency... In my defense I needed help to do that right, and didn't have any, so I made do solo. It is nominal 5.5" but frankly varies from 3.5 to ~7" in the low spots. Let's just call it "sufficient" shall we There is a 16"d x 20" wide thickened edge also for the footing.
    -Dave
    "Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
    L5240HST, QA, 824 Loader, 48" Forks, 48" Grapple, rear blade, box blade, landscape rake, Ancient Farmi Skidding winch
    Trailer - 10k/16' twin axle w/elec brakes
    2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
    My house build blog: http://stighouse.blogspot.com/
  4. #134
    Gold Member Kubota Tee's Avatar
    Join Date
    Dec 2009
    Posts
    267
    Hudsonville, MI
    Kubota L3540HST-3
    Default
    Been following your thread and I must say that you have taken on a big project, but one that will be highly satisfying! Thanks for the details on the thickened perimeter, but wondering if those dimensions are a factor of your local frost depth, building size/height, both, other factors? I like this approach as an alternative to a pole building approach or traditional footing and frost wall method. I'll have my own outbuilding project coming up in another year or so and am getting great ideas from your project and others here on TBN!
    The other thing I was wondering about was the channel that you formed in along the edge where the SIP wall was set. What's the purpose for this channel?
    Thanks for documenting your project and I love all the pics! Great Job.
    Thomas (aka Kubota Tee)
    Kubota L3540 with LA724 FEL.,HD Bucket with bolt on cutting edge, Custom FEL Forks, Taylor Way 7' box blade, 6' gill rake, Custom Tree Scoop, 6' Woods finish mower, custom FEL attached snow plow.
    Toro Z Master 6000 with 60" mower deck
  5. #135
    Join Date
    Apr 2010
    Posts
    2,814
    W Wisc
    Thomas, The foundation was designed using the Shallow Frost-Protected Foundation Guide (attached below, or search online for it - free). It works based on your local climate conditions, so have a look and you can decide if it makes sense. In this case, it saves me digging and pouring 4' stem walls with footings, so it is a huge savings in both time and materials.
    Good eye on catching the step in the slab. Because the wall on that side was going to be buried below grade partially, we wanted something to help counteract the sideways pressure from the ground at the bottom of the wall. The step makes the sill plate bear directly into the slab, so it is well supported at the bottom this way. The center wall is a shear wall that is also tied into the slab with a thickened footing of it's own, and the roof trusses are designed to be part of the lateral resistive structure for this. Enercept had an engineer they used to deal with all that.
    Frost protected shallow footing guide.pdf
    -Dave
  6. #136
    Join Date
    Apr 2010
    Posts
    2,814
    W Wisc
    So while I've been spending most of my time working on the shop building, the house site got started somewhat. I had the excavator dig the foundation pad and then the concrete guys go the footing and foundation walls in. Here's a few shots of it.
    Digging the foundation
    A(nother) Home in the (different) Woods-excavating-house-3-medium-jpg
    A(nother) Home in the (different) Woods-excavating-house-5-medium-jpg
    A(nother) Home in the (different) Woods-excavating-house-1-medium-jpg
    Footing Forms
    A(nother) Home in the (different) Woods-footing-forms-6-medium-jpg
    A(nother) Home in the (different) Woods-footing-forms-4-medium-jpg
    -Dave
  7. #137
    Join Date
    Apr 2010
    Posts
    2,814
    W Wisc
    Pouring the footings
    A(nother) Home in the (different) Woods-pouring_footings_house-1-medium-jpg
    A(nother) Home in the (different) Woods-pouring_footings_house-6-medium-jpg
    2 different concrete companies on the same site!! Fight! Fight! Fight!
    A(nother) Home in the (different) Woods-pouring_footings_house-11-medium-jpg
    A(nother) Home in the (different) Woods-pouring_footings_house-12-medium-jpg
    A(nother) Home in the (different) Woods-pouring_footings_house-13-medium-jpg
    A(nother) Home in the (different) Woods-pouring_footings_house-17-medium-jpg
    -Dave
  8. #138
    Join Date
    Apr 2010
    Posts
    2,814
    W Wisc
    And then the walls. This is about 50% walkout, so half of the walls are just frost footings below grade.
    Forms out the wazoo!
    A(nother) Home in the (different) Woods-forms-foundation-2-medium-jpg
    All ready to pour. Minor detail here in that I showed up a bit late and there were concrete trucks already on site. I asked the crew where the step (essentially a brick ledge) in the footings were. Got the blanks stare and then the foreman went "oh SHEET!" and they had to scramble to get that in place while the trucks were waiting. They were about 10 seconds from starting the pour when I asked that. Just in time!
    A(nother) Home in the (different) Woods-forms-foundation-3-medium-jpg
    A(nother) Home in the (different) Woods-forms-foundation-7-medium-jpg
    And the pouring with the pumper truck again. They prefer to use that for just about everything they do as it saves a ton of time, so they actually split the cost with the customer.
    A(nother) Home in the (different) Woods-forms-foundation-10-medium-jpg
    A(nother) Home in the (different) Woods-forms-foundation-11-medium-jpg
    A(nother) Home in the (different) Woods-forms-foundation-12-medium-jpg
    That's about it for now. Working on drywall on the shop now that we passed rough electric and framing on that building. Trying to wrap up drywall in the next couple weeks. SIPs panels for the house have been delayed so we have been waiting for those to show up. It looks like we may get them finally on Aug 30, so we can start moving forward with that, hopefully in time to get it enclosed before the snow flies....
    -Dave
  9. #139
    Join Date
    Nov 2005
    Posts
    3,383
    Southwestern, PA
    Default
    Nice! Getting the footers and foundation is a big step. The delay waiting for the panels will just give the concrete a few extra days to cure.
  10. #140
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Looks good, Dave. It shouldn't be too hard to get closed-in before the weather turns nasty.
    I'm sure it's a good feeling to see concrete progress. If I ever do another build, not likely, but I would interview the concrete contractor by saying "show me your equipment." I think outfits that try to do the form handling on a shoe-string equipment budget end up with, can only attract, the least skilled crews. Yours looks reasonably well equipped.
Similar Threads
  1. Log cabin construction
    By gcp in forum Rural Living
    Last Post: 04-05-2014, 01:48 AM
  2. Replies: 18
    Last Post: 09-18-2007, 06:03 PM
  3. Replies: 10
    Last Post: 05-19-2007, 07:35 PM
  4. Backhoe Branson versus woods backhoe
    By farmyid in forum Century & Branson
    Last Post: 08-06-2006, 11:39 AM
  5. Intruder in the woods
    By NoTrespassing in forum Rural Living
    Last Post: 02-01-2005, 11:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
