Results 1 to 3 of 3
  1. #1
    Silver Member Marty38's Avatar
    Join Date
    Mar 2011
    Posts
    111
    L111/sc2400
    Default Adding on to a Log Home
    I'm currently living in a 30 year old ranch LogHome built in 1979. Im curious if anybody has added on rooms with another section of Log or even stick built, to an existing building. I'm thinking of going out with a master bedroom bath suite. I'm not sure if I want sheetrocked walls on not
  2. #2
    Elite Member MotorSeven's Avatar
    Join Date
    Aug 2005
    Posts
    4,033
    NE TENN (Hancock Co)
    Kioti DK40SE Hydro
    Default Re: Adding on to a Log Home
    I have seen stick built additions to log homes...they don't look so good. I would try and run down the same profile of log and build it to match. Depending on where the doorway is going to go(load bearing or not) you may or may not have to do some bracing. Many old log homes were build then all window and doors cut out afterwards.
    2008 KIOTI DK40Se Hydro
    1978 Sling Blade/wood handle
  3. #3
    Elite Member
    Join Date
    Dec 2002
    Posts
    4,595
    Foster, RI
    Mahindra 3016
    Quote Originally Posted by Marty38 View Post
    Here is a section I added to my log home many years ago. How it looks has much to do with the style of log home and what the siding is used on the new addition. On this addition I used 1" planking the same width as the logs. Because my logs are milled uniformly, this transition is almost seamless. I first carved into the logs to accept a 2x8 nailer.
    Attached Thumbnails Attached Thumbnails Adding on to a Log Home-pa252011-jpg
Similar Threads
  1. Adding a fireplace/ Chimney to an existing home
    By goodoleboy in forum Rural Living
    Last Post: 06-04-2016, 08:28 AM
  2. Home made 16HP v-twin log splitter
    By maxfior in forum Build-It Yourself
    Last Post: 10-22-2010, 03:53 PM
  3. DIY Log Home
    By jcook5003 in forum Projects
    Last Post: 08-31-2010, 12:10 AM
  4. Can't log on at home
    By psj12 in forum News/Feedback
    Last Post: 06-07-2010, 08:59 AM
  5. Log Home
    By Cabindweller in forum New Member Introductions
    Last Post: 05-14-2010, 01:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
