Results 1 to 10 of 17
12-27-2011, 02:55 PM #1
- Join Date
- May 2010
- Posts
- 3,940
- Location
- of my
- Tractor
- Here
LED flashlights for tractor lighting - Will it work??!!!
Well, we're gonna find out. Preliminary write-up/ plan here, with pics, results & discussion to follow.
I bought a couple 3-packs of small but very bright handheld LED flashlights at HD. (The package comes with the 3 flashlights, 2 of the strap-on LED head lights, & 15 Everyready AAA batteries (3 for each light) for $14.00)
These little flashlights are very impressive! It dawned on me that I might able to line them up & mount them on my tractor's roof for added lighting since the loader blocks the headlights.
I've been hesitant to buy the standard fixed LED lighting units because 1) they are darn expensive, and 2) I wasn't sure what the beam result would look like or how bright they'd be. If I knew for sure I'd be happy with what I'd be getting, I'd pony up.
I'm going to attach 6 of these flashlights to a 2x4 & bolt that to my tractor roof with a single lag bolt going into each end of the 2x4 so that I can just reach up & pivot the whole thing up or down in order to focus the light where I want it in front of the tractor (in closer or out further away). Also, each flashlight will be mounted separately on a single bolt so I can rotate each one to point where I want it. I envision all 6 being oriented evenly across the front of the tractor for a somewhat uniform amount of light.
Last night I turned off my headlights & drove around using just one of these flashlights, & it was amazing. That 1 flashlight is as bright, or maybe even a little brighter than, my kubota OEM headlights. I'm excited to see the light output of 6 of these.
The on/off button is on the back of the flashlight, so I will have to reach up & hit 6 buttons if I want all 6 on at once. On the other hand, there may be times when I don't need all of them. We shall see.
Like many flashlights, these allow you to focus or widen the beam by turning the lens end of the flashlight.
Some things I wonder about:
- How long will the AAA batteries will last? I may wish these could be wired into the Kubota 12V system, & if I love this setup, I'll look into that.
- Will the flashlights stand up to the sometimes harsh bouncing of the tractor?
Anyway, pics & results to follow ... Do ya'll think it'll work?
The 2x4 mount will be bolted between the two vertical 2x4's in this poor pic I tried to draft up:
12-27-2011, 03:04 PM #2
- Join Date
- Aug 2011
- Posts
- 2,687
- Location
- Earth
- Tractor
- Deere
Re: LED flashlights for tractor lighting - Will it work??!!!
I'm a little confused on the purpose, is to have extra light to see or for safety purposes like a flashing light so people can see you?
Anyway I would expect it to work all right - it will brighten things up but in the long term I would get some actual LED headlights to wire around the top and wire it into the switch.
I would be curious to see how heavy duty your flashlights are seeing they are brighter then the kubota's - I couldn't imagine that great of battery life - especially with them being AA's but I guess only time will tell.
12-27-2011, 03:45 PM #3
- Join Date
- May 2010
- Posts
- 3,940
- Location
- of my
- Tractor
- Here
They're to help light my way. Sometimes I mow after dark, & the loader blocks the headlights. These lights will shine from a much higher location than the headlights, therefore will shine over the loader.
These little things are shocking as to their brightness. I don't know how to rate them as to "heavy duty" or whatever, but when one of them is equal to or greater than the Kubota headlights, that should give you an idea.
12-27-2011, 04:12 PM #4
- Join Date
- Aug 2011
- Posts
- 2,687
- Location
- Earth
- Tractor
- Deere
Originally Posted by beppington
Be sure to give an update after you get some more use though - if it works well I might due the same!
12-27-2011, 04:13 PM #5
- Join Date
- Jul 2006
- Posts
- 5,568
- Location
- Los Angeles / SW Washington
- Tractor
- PowerTrac 1850, Kubota RTV x900
LED do not "throw" a great distance. It is due to bulb design that is currently being worked out. To create a throw, wattage and numbers of bulbs are increased. Many people find staring down an LED light to be much more painful / bright at the same distance to a comparable incandescent bulb.
Might I suggest that you approach this differently. If you want, check on Ebay for led lights. I just bought a set of 60 LED flashing lights (Flashing has NOTHING to do with the light, it is the controller) and installed them as reverse lights on my quad. They came from China which is something I have started to change in my word, but they were $20 with shipping. Simple 12 volt wiring and an outdoor rated switch and I am in very bright business.
I did have to run a bead of caulk around the housing, but they work quite well.
Adding another note. I do not feel cheap LED's are ready for primetime. The good "work" led's are around $100. I am referring to design and comparison with an incandescent style flood lamp for automotive use.
Finally, I moved my lights to my canopy and am SO happy. With an FEL usual placement of lights are a waste IMO.
CarlPower-Trac 1850, grapple, hoe, 90" mower, 72" box blade
12-27-2011, 05:24 PM #6
- Join Date
- Dec 2011
- Posts
- 252
- Location
- Haverhill, MA
- Tractor
- MTD 660, 690 - John Deere 60, 70, 108, 2 of 111, 111h, STX38
Hi, I hope this will help you
I recently put 6 LED's in my Lawn Tractor (See Pix below). Got them on Ebay for $6.45 for 2 of them. It's called H7 Car 102 3020 Chip SMD LED about 400Lumen each Example... Ebay Item number: 330661662827.
NOTE: Do NOT get the one that is 3528 Chip SMD LED, they suck alot of power and give you less light.
I made 2 just regular light, and then 4 on High Beam with a switch on my Tractor. Mouse over the Pix to see Descriptions and Info. Also I enclosed a Sample of Solar Light Encloser I remade, maybe give you some idea...
I suggest you to buy the 10W LED Spotlight / Floodlight (Last Pix) also it's Waterproof, it's cheaper $24.00 on Ebay (Even Cheaper now $19.00 Item number:120827918357) and you can just hook it to your 12V Lights on your Tractor, just put a switch so you can turn off and on that is all, also rated at 1000Lumen Cool White, which is bright and I might put it on mine soon... For Back Up in the Snow Storm
I think you bought what I did at HD, it's called CREE LED if i'm correct. They are bright for their 1W. But they said the Battery will last only 2 Hours most, for 3xAAA. Another thing you can do with these is Connect them in Series... That way you can use them right from your Tractor 12V. Just connect them 3 each since they are rated 4.5V per bulb.
Any questions, just ask... I have done bunch of LED's... Including my house and I have pix to prove it, LOL
Hope that will help!Last edited by rgs03833; 12-28-2011 at 04:46 PM.
12-29-2011, 11:21 AM #7
- Join Date
- May 2010
- Posts
- 3,940
- Location
- of my
- Tractor
- Here
The flashlights mounted to the 2x4 (2x4 not cut to length yet; or painted!):
12-29-2011, 11:29 AM #8
Those lights look like one I have a buddy gave me. He got a 3 pack at costco and I will say these lights are IMPRESSIVE for the price. Very very bright. Does yours have 3 brightness sightings?
Kubota L4400 - Land pride rear scraper blade, 6 foot landscape rake, 72'' Frontier Box Blade, Land Pride 60'' finish mower, Land Pride Q/A pallet forks, County Line Carryall built to haul and loaded R-1's
Kubota RTV500
Kubota BX23S
Previous Tractors: 1978 B7100, 2009 B3200, 2013 BX1870
12-29-2011, 11:38 AM #9
- Join Date
- May 2010
- Posts
- 3,940
- Location
- of my
- Tractor
- Here
12-29-2011, 12:42 PM #10
beppington
I've Quite a few of those same lights you are using . I'm mostly using them on firearms as they have a 1" OD housing and fit in "scope" rings easily. Some of the ones I have, have the on/off button on the end and can be swapped out to a pressure switch.I'm not sure you will get the throw out of them ?
And you'll probably need to stock up on batteries . But the Idea of being able to have a mounted flash light on the tractor that can be removed and used @ the machines is goodto have.
A few months back I bought a black 4 M candle power spot light @ Tractor Supply~$20 It was a p.o.s. Retured it and bought a 3 million candle power with a silver housing for $8.00 and it was a much better light. It's 12V rechargable and cig lighter plugable throws a beam out 300-400 yards x 30 yards flood.I have 2 100watt K/C lights on my tractor already but if they burn out I'll be using one of these spots on it then.
Ak972"brush mower,72" finish mower 10' bh w/ thumb,48" forks,QT 72" toothbucket/loader w/grapple,72" kk tiller,72 " pto snow blower ,84" custom drag blade tph, 70" scraper tph, 80 ton home made tire shear QT, QT stump bucket 48", 2 ton 4x4 dump truckw/w,M35a2"duece" w/w,& a 72QT "beautiful" carry all... and some top secret impements
Similar Threads
B3030 Work light problem
By smfcpacfp in forum Kubota Owning/OperatingReplies: 7Last Post: 01-21-2010, 09:37 PM -
New guy looking for advice - CUT for brush hog work
By lungdoc in forum Buying/Pricing/ComparisonsReplies: 9Last Post: 09-10-2008, 12:24 PM -
Work Boot Info/Opinions
By Jarrett in forum Related TopicsReplies: 31Last Post: 05-11-2008, 01:22 PM -
Question for the tractor electricians
By RFB in forum CustomizationReplies: 38Last Post: 02-21-2008, 04:50 PM -
Installing JD forward lighting kit and rear work lights?
By bam747 in forum John Deere Owning/OperatingReplies: 2Last Post: 07-07-2007, 10:44 PM
