Page 11 of 26 FirstFirst ... 89101112131421 ... LastLast
Results 101 to 110 of 252
  1. #101
    Super Member
    Join Date
    Apr 2006
    Posts
    6,484
    Wise county Texas
    Kioti DK 35 now
    Default Re: Circular paver driveway
    Don, just save yourself allot of extra work and put a sign at the gate that reads
    "PLEASE LEAVE SHOES AND TIRES BY THE MAILBOX"
    BTW, I have seen some impressive brick drive ways in Dallas that appear either "glazed' side up or " sealed", not sure which, but they do have some kind of sheen. I bet the brick supplier you bought from has a good idea what sealer may work on their brick though.
    Dennis
    "Winter 2013 a majority of the country is setting new cold records, Colorado is setting new record HIGH's"
    "If at first you don't succeed, skydiving is not for you."
  2. #102
    Join Date
    Jun 2011
    Posts
    2,323
    CNH 4020
    Quote Originally Posted by Western View Post
    Don,
    I agree with Dennis, of course I usually do, see your supplier...
    It has been too many years since I've had a surface like that to mess with and new products are always coming out. If you could cover what is laid with something, without it causing mold, you could have it done all at once. I know they spray and or roll some of the stuff on that gives the sheen, in these parts.
    I also know from experience that you can only turn a paver over once to hide
    a mess and even then the color may be drastically different because of
    fading. I always keep spares of stuff like this. A few years from know you will never be able to match the color or the size of what you have now.
    Ron
  3. #103
    Join Date
    Jun 2011
    Posts
    2,323
    CNH 4020
    This might give you a clue regarding what you are doing now or don't need to do, if you seal.
    [ame=http://www.youtube.com/watch?v=14h9ITL_img]Paver Sealer - YouTube[/ame]
  4. #104
    Elite Member
    Join Date
    May 2010
    Posts
    3,940
    of my
    Here
    If you scroll to the end of the video to see the before & after pics ... I think I like the before better. The after kinda looks plastic coated to me.
  5. #105
    Join Date
    Jun 2011
    Posts
    2,323
    CNH 4020
    Quote Originally Posted by beppington View Post
    I believe it is available in shiny or dull.
    Remember anything subject to daylight environment isn't going to look like a fresh coat too long. Leaves, mower crap, spills, oil, mud, tire marks, dog and skunk pee will all have an opportunity to visit; they will just be easier to get off without staining.
    Just my humble opinion, "Lookin out for the folks" as Bill would say.
    Ron
  6. #106
    Super Star Member txdon's Avatar
    Join Date
    Jul 2003
    Posts
    10,624
    Central Texas
    Kubota L5030HST, Hustler FasTrak
    UPDATE:
    Section 3 is complete. It is in the shade of the big oak tree and can be used as a patio also.
    Section 4 is an interesting section because it contains the drain for the circle.
    I loaded the drain with pavers so it would not float when the cement was poured. I also taped the top grill and installed it so the wet cement would not bend in the drain and make the top grill impossible to install when it dried.
    I poured the cement underneath and 6" on either side of the drain in one pour. The cement is 7" thick.
    I put on an end cap and drilled holes in it to allow the water in and keep out the snakes out.
    Attached Thumbnails Attached Thumbnails Circular paver driveway-section3-jpg   Circular paver driveway-section-4-drain1-jpg   Circular paver driveway-section4drain2-jpg   Circular paver driveway-section4drain4-jpg
    TXDon
  7. #107
    Join Date
    Jul 2003
    Posts
    10,624
    Central Texas
    Section 4 - reinforcements arrive!!!!
    Section 4 was started this morning with the welcomed help from Ron!
    By the end of the day we had placed about 600 pavers and half of section 4 is complete.
    Attached Thumbnails Attached Thumbnails Circular paver driveway-section4one-jpg   Circular paver driveway-section4two-jpg
    TXDon
  8. #108
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Hey Don. Is that one of those South Texas day laborers you have in the first photo? I hear he speaks English with a accent.
    Jim
  9. #109
    Elite Member
    Join Date
    May 2010
    Posts
    3,940
    of my
    Here
    Is that pacerron?
    If so, is he changing to paverron?
  10. #110
    Join Date
    Jun 2011
    Posts
    2,323
    CNH 4020
    Is that pacerron?
    Negative...
    Pacerron is built more like jinman and still eats too much animal fat.
Similar Threads
  1. Gravel driveway help.
    By mjncad in forum Projects
    Last Post: 09-25-2010, 02:21 AM
  2. Major Driveway Project, Opinions Please
    By dnels0n in forum Attachments
    Last Post: 08-17-2010, 09:09 AM
  3. Steep gravel driveway advice
    By scoutcub in forum Projects
    Last Post: 07-21-2010, 12:16 PM
  4. Building a Gravel Driveway
    By dfeck in forum Rural Living
    Last Post: 06-17-2004, 12:17 PM
  5. Gravel Driveway Re-hab
    By WVBill in forum Projects
    Last Post: 02-08-2001, 05:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
