Page 2 of 26 FirstFirst 1234512 ... LastLast
Results 11 to 20 of 252
  1. #11
    Elite Member
    Join Date
    Apr 2006
    Posts
    4,560
    Wise county Texas
    Kioti DK 35 now
    Default Re: Circular paver driveway
    Quote Originally Posted by txdon View Post
    I will try to lay 1000 pavers a week and hopefully be done in 10 weeks. This makes my wife laugh considering I'm already 18 months into this project.
    18 months? I didnt realize this was a TXDOT highway project Your "Superintendent" may need to withhold funds pending the outcome of the timeline
    Quote Originally Posted by EddieWalker View Post
    I like the white look the best. You should just leave it like that!!!!
    Eddie
    And Don got the color so "even" too GOOD JOB!
    Don, that will look great!, can't wait to see all that labor payoff in some photos when finished BTW, Why didn't you pick a big project?? I think if I had to bend over that much, I'd be permanently crippled
    Dennis
    Due to recent budget cuts and the rising cost of electricity, gas and oil, as well as current market conditions, the Light at the End of the Tunnel has been turned off.
  2. #12
    Elite Member bindian's Avatar
    Join Date
    Feb 2007
    Posts
    3,350
    Willis, Texas
    Mahindra 6520 4WD
    The pavers are acme brick.
    Don,
    Is this the same Acme Co. that the Coyote uses to try to catch the Roadroader?
    hugs, Brandi
  3. #13
    Veteran Member crbr's Avatar
    Join Date
    Apr 2007
    Posts
    1,667
    East TN
    Kub - 2K6, B7800
    Looks good......
    ** Kubota **
    Psalms 86
    John 1:12-13
    Duraflap / Kaydenco not worth a hoot for service or products.
    "Google" is a proper noun, not a verb.
    If you mean what you say, then say what you mean, or just don't say anything
  4. #14
    Join Date
    Jun 2011
    Posts
    1,397
    CNH 4020
    Quote Originally Posted by MossflowerWoods View Post
    Don,
    I have had mixed results and tried various methods.
    My 2 cents is that when I allow sand atop the weed barrier, I get weeds in the sand above the weed barrier! And recently I re-did the walkway at one of my rentals and I put the weed barrier DIRECTLY under the white decorative rocks and it seems slightly better, but at the edges and anywhere "dirt" develops on top of the weed barrier I get WEEDS!
    I was hoping you had the answers and I would just copy you!
    Thanks,
    David
    We have found the weeds will appear in time regardless. Dust in the wind, bird droppings, and weed seed from near areas will always win.
    Best thing we have found is a little "Round-up" or similar spray when needed.
    Also the best way to control weeds under pasture fence lines.
    Ron
  5. #15
    Elite Member txdon's Avatar
    Join Date
    Jul 2003
    Posts
    4,648
    central Texas, Lee County
    Kubota L5030 HST, Farmall A
    Thanks for all the comments! I knew TBN would keep me laughing and going.
    I added a thin layer of sand today to "section 1" and washed it into the gravel. I also finished up the second cross curb to enclose section 1. Tomorrow I will compact again and haul in the final layer of sand that the pavers will set on.
    I will be using Paver Set - see photo - between the pavers. It has worked good on the porches, and still looks good after 2 years. It is keeping out the weeds and ants 98%.
    The pavers you see on the right are the thinner Lowe's pavers for sidewalks. The Lowe's pavers are easier to lay because of the tapered top side and the protrusions that leave a space in-between the pavers. I swept in the Paver Set between the pavers on the sidewalk. That project was a mere 750 pavers. The driveway pavers are more of the brownish color and the sidewalk pavers are more of a reddish color. Hopefully the different colors, paver placement pattern, and the curbing will keep the vehicles directed on the drive.
    Attached Thumbnails Attached Thumbnails Circular paver driveway-drive12-30.jpg   Circular paver driveway-paverset.jpg
    TXDon
  6. #16
    Elite Member beppington's Avatar
    Join Date
    May 2010
    Posts
    3,940
    N Cent FL
    Kubota Grand L3940
    Just occurred to me how many paver cuts you'll be making to follow the inner & outer radii of your drive ... HOLY COW! Good thing your heart is doing better!
    Please consider donating to the Cystic Fibrosis Foundation
    Kubota 3940
  7. #17
    Join Date
    Jul 2003
    Posts
    4,648
    A couple of pics from the sidewalk lay.
    The driveway pavers are on the porch at the bottom part of the last photo.
    Attached Thumbnails Attached Thumbnails Circular paver driveway-tools.jpg   Circular paver driveway-sidewalk.jpg   Circular paver driveway-sidewalkporch.jpg
    TXDon
  8. #18
    Join Date
    Jul 2003
    Posts
    4,648
    Quote Originally Posted by beppington View Post
    My heart is doing better, much better! At one point I was going to leave the driveway white. But I'm going strong again and am trying to finish this project by the one year anniversary of my heart attack.
    Since the drive-way pavers require a 1/4 inch space in-between each paver and because the curve is so long, I am hoping to lay the pavers longways and have very few cuts.....we will see together how that works out. If we decide to do a different lay all bets are off for the self imposed 10 weeks deadline (which by the way starts 1/1/12).
    The basket-weave pattern I used on the sidewalk is not good for curves as I found out by all the cuts required on that one long curved side.
    TXDon
  9. #19
    Elite Member
    Join Date
    Apr 2005
    Posts
    3,066
    nicholson, pa
    John Deer Lt160
    That will look great I am really impressed by it.
    What we would do is layout everything that we could and then spend a day doing cuts on a large job. We would have one person marking, one person running the pieces over and one cutting, the person running would get a workout taking pieces back and forth. A wet stone saw is worth its weight in gold for a job like that. I cant wait to see the finished pics. good luck.
  10. #20
    Elite Member MossflowerWoods's Avatar
    Join Date
    Aug 2011
    Posts
    4,846
    Ladysmith, VA
    Kioti DK50SE HST w/FEL, John Deere LX266 & STX38 Mowers. Stihl MS290 20" bar, & FS190
    W O W !
    If I were in your shoes, everything would be rectangular in exact ratio to the size of the paver...
    I simply do not have the patience to do what you are doing...
    And nothing I ever do will look that good either...
    Simply beautiful thus far sir.
    W O W !
    Be well,
    David
    Former Submariner & Army SGT
    2011 Kioti DK50SE HST, KL-401 FEL w/72" bucket, tooth bar, & Ratchet Rake, 2 rear remotes, canopy, WR Long RBG72 Grapple, Woods BB72X cutter & TSG-50 stump grinder, TSC PHD, & more to come. Mowers 2003 JD LX266 42" deck mower, & old JD STX-38 (12.5 hp).
    Managing 51 Acres of Virginia hills with ponds & streams, mature market timber, riding trails, horse pasture, long gravel drive, veggie garden, & yard.
Similar Threads
  1. Gravel driveway help.
    By mjncad in forum Projects
    Last Post: 09-25-2010, 01:21 AM
  2. Major Driveway Project, Opinions Please
    By dnels0n in forum Attachments
    Last Post: 08-17-2010, 08:09 AM
  3. Steep gravel driveway advice
    By scoutcub in forum Projects
    Last Post: 07-21-2010, 11:16 AM
  4. Building a Gravel Driveway
    By dfeck in forum Rural Living
    Last Post: 06-17-2004, 11:17 AM
  5. Gravel Driveway Re-hab
    By WVBill in forum Projects
    Last Post: 02-08-2001, 04:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
